Eddie's got you covered. But now consider what you can do with the other side of the switch. You have four sections altogether (four-pole, five-throw) on a Superstrat switch; two are used for the pickups, and now a third one can be used for the tone controls. Run a jumper from the output to your volume control, and send it to one of the remaining poles of the switch. Then connect the first tone control to throws 4 and 5 so that tone control will only operate for neck and neck+ middle. Lastly, connect your second tone control to throws 1, 2, 3 so the second tone knob will work only for middle, middle + bridge, and bridge pickups.
This avoids the overlap that occurs with standard Strat wiring where both tone knobs are operating in position 4 (neck + middle) and the sound gets muddy.
#6 (permalink) | |
Using your diagram, if I wanted to replace position 3 with N+B: Purple connections stay the same 1st pole: 1 - white/no connection 2 - green/from middle pickup 3 - gray/from lug 4 4 - gray/from lug 5 5 - gray/from neck pickup 2nd pole: 1 - red/from bridge pickup 2 - red/from lug 1 3 - red/from lug 2 4 - green/from pole 1, lug 2 5 - white/no connection Is that correct? |
Didn't know there was such a thing as a two-pole, five-throw switch, what you refer to as a single wafer superswitch, waddayaknow. I thought the switches were either a standard Strat switch (two-pole, three-throw, make before break, five-detent) or a super switch (four-pole, five-throw), so I assumed (and all that comes with that) you had a four-pole job there.
