Multi effects or individual pedals???
What do you guys think are the best???For gigs..........Best sound? Best quality? Ease of operation? Most dependable? I've been thinking about a Tonelab instead of my pedalboard....
I think part of the equation is what you're playing. I pretty much play my sound so I prefer individual effects for many reasons;
-Flexibility -Ease of use (this may seem backwards, but if I want to alter a setting I just dial and done, don't have to go through a menu, then save) -Dependablity (if something dies just pull it out, everything else is ok) -Quality, you can upgrade individual pieces over time My friend has a cover band and the multi effects with amp modeling is perfect for him because he dials in the sounds of many different bands/songs. Individual effects/pedalboard would not work well for him. |
The only pedalboard that KILLS 99% of ANY stompbox out there is the VOX TONELAB SE.
If you can get it (I think VOX has stopped making it) do it,you won't be sorry. I've been a total stompbox freak for all my life & spent thousands of dollars in stompboxes ,now days the only thing I use is my TL SE & a good compressor & I sound MUCH better.... |
#4 (permalink) | |
“I crawl like a viper through these suburban streets..." |
![]() Doctor of Teleocity
Multi-effects units seem to work best as long as you avoid the overdrive sections in them. Once you include the built-in OD settings all bets are off. I would strongly suggest using an external OD pedal when using a digital multi-effects unit. Many of the built-in effects are very good and quite useful in a live situation.
I Prefer individual pedals. It means im not paying for effects that im not going to use.
Livin' youre dreams, Woah you on top. My mind is aching, Lord it wont stop. Thats how it happens livin' life by the drop. |
"I would strongly suggest using an external OD pedal when using a digital multi-effects unit."
+1 That's exactly what I use...multi effects unit (mostly for delays, reverbs and modulation effects) with analog compression, overdrive and distortion boxes. Pro:Provides a lot of sound versatility Con: Not so good if you want to adjust things "on the fly". |
I have the Tonelab SE. You can still pick one up on ebay.... I got mine for $350 last year. I've spent thousands on digitech stuff over the years....they have great verbs and time based effects, but they haven't gotten anywhere near the Vox as far as tube feel and tone. It really rocks...especially if you have a tube power amp...something not too loud that you can really push. You can hear mine here for a rock lead tone, or here for a country-ish tone.
All that said, if I had the money and the time to experiment, I would probably go with a combination of pedals, digital rack effects, and a switcher system that made it all act like a multi effects pedal....so that hitting one switch reset the whole signal chain just the way I want it. It would probably cost something like $5000.00 to get everything, and a few months of spending time obsessing on it to get it right....I just don't have that kind of scratch, so I'll use my multi-fx. Peace! ~Shawn |
I have a Tonelab desktop with VC-12 controller. I like this configuration because it gets the electronics isolated from what you're stomping (spilling?) on. If you must go Tonelab, I can't recommend this enough as the VC-12 is a BEAST! But, I also have a Boss BCB-60 loaded with Boss compact pedals.
I would go back and forth between the two sometimes, but I have to say, I really do prefer the BCB-60 with individual pedals more now days. Everything is out in the open, and everything is easily tweakable with no interpretation of "oh, this is an overdrive pedal, this knob really should be this, and that knob is that". It's also easier to adapt is someone throws a new song at me. I don't have to go flipping through patches and such. Plus the chances of the whole thing breaking at once is real slim. If a pedal goes out (they're Boss, I won't hold my breath), I only have to replace one and tweak it's settings. I like the Tonelab at home when playing alone and experimenting, but when playing out with others where things change and time is valuable, I always prefer the individual pedals, and haven't used the Tonelab out of the home for a while. Personally, it turns out to be a real time-sink goofing around with it. I sure do love the volume and expression of my VC-12 though, and it does take up less floor space than the BCB-60. Maybe someday if I ever have an unchanging set list in an unchanging enviornment where I won't have to tweak knobs, I might introduce it back in.
1995 Fender Telecaster Special / 1997 Fender Deluxe Series Powerhouse Strat 2004 Dr. Z Carmen Ghia 2x10 in Red / 2004 Fender Blues Junior Acoustic: 2002 Taylor K14CE / 2006 Fender Acoustasonic DSP Junior |
I've always been an individual pedal guy. IMHO the drawback of multi processors is two fold...
1. Each effect (chorus, flange, delay and especially overdrive/distortion) has it's own "Q" and character. You may love the chorus, but the flange not so much. The compressor might be fine, but the overdrive is not so hot. For me, even with the sophisticated editing on a lot of these units, it can be really hard to get the effect to sit right if it isn't reasonably close out of the box. Eventually, you wind up with a multi processor AND a bunch of pedals to "fill in the gaps". With individual pedals you pick what's just right for your taste and set up. If you change amps/guitars/gigs, swap out an overdrive for one that works better with what you need. 2. Generally speaking, multi effects don't feel the same as pedals when you play through them. Arguably, the sounds may be getting more and more organic, but the feel is something that's they're still a ways off from nailing down. I would agree that the Tonelab is pretty much as close as it gets though, if you go down that road. Joseph
www.myspace.com/joecurtisband/ Overheard at a gig... "The guitar could be louder... I have no idea how, but I'm sure it can be done..." ;) |
The tonelab definitley sounds like a amp not fizzy like other modelers.
.http://www.youtube.com/watch?v=4A4SM...elated&search=
slip-slidin away___ |
i am with sax4blues:
if you play like in top 40 coverband and you have to provide a whole varity of sounds, then a good ! multieffect tool is the easier way to go and with one step you can change via midi your complete sound. if you´re playing more or less one style i´d choose single pedals. as said, if f.e. one breaks down, take it out and play on, you can adjust individually your pedalboard and most single pedals are better than a multibox. take care zoppotrump :O)
may the twang be with you ! |
#14 (permalink) |
he multieffectbox that i can imagine to use in a life situation would be a boss me-50. that can be used in a manual mode. everytime i tried to use multis in a band situation, was a diaster. banks and patches and all is just too much for me.
I stepped on a power cord during a gig once and unplugged my multieffects unit in the middle of a song. OK, dumb move. I plugged it back immediately, but the problem was that when the power was cut it automatically reverted to its default settings... resulting in a significant drop in volume. I had to page through the presets to find the setting I was using for that song. fortunately it was a bluesy drag sort of thing that the singer, bassist and drummer could handle while I tried to get my rig running again... and I got the sound back just in time for my solo... which, I have to say, was a lot more intense than it had been in rehearsals, due to my frustration! But anyway, it's a cautionary tale... single effect stomp boxes don't reset themselves if there's a power interruption...
#17 (permalink) |
I have had rack units, floor units, you name it. I lack the patients required for anything more sophisticated than a tube amp and a couple pedals. Here's a hint, if your VCR has been flashing 12:00 for the last 2 years, just buy stomp boxes...
#18 (permalink) |
Give me stomp boxes anytime. I've tried several multi-effects deals and disliked them all. Too much involved to change effects on the fly plus the tone is much better when tweaked with individual pedals. My good friend has three multi effect gizmos that he is constantly peckerin' around with. I guess if your a tech-savvy person it may work for you.
the man said "son,get yourself an honest guitar... get a fender telecaster" |
#19 (permalink) |
Do you really need to choose one vs. the other? Just use what you're most comfortable with, as there are advantages to both.
It's nice having one simple package where you don't have to dicker with hooking everything up, but I like my single stomps too. For studio stuff, I prefer vintage and boutique pedals. Generally they sound better, and no worries about stuff getting spilled on them, etc. For any of the local-type gigs I might do, my Boss GT8 is much easier to tote and set-up, and I don't have to worry so much about it getting damaged or stolen. They are relatively cheap, consistent, and easy to replace. If you're curious about using multi-effects, find a well-reviewed one like the Vox Tonelab, Boss GT8, or Zoom G9.2tt, and learn to use it at home first. Anything that you're not comfortable using will be a liability at a gig, so there is no "one size fits all" answer here... If you're happy with what you've got, then just stick with it. The idea that multi-effects "reset" when the power goes off may be valid for some models, but that's not an issue with my GT8. It remembers your presets even with the power off, and comes on at the exact setting it was at when the power went off. I don't know if this is applies to any other modern multi-effects units. It seems that a lot of players have this elusive "perfect tone" in their imagination, and they think that once they get it, they'll be done. I've been down that road a couple times, and while you might find a tone you can be satisfied with, there are always going to be new ideas and tone tweaks to enjoy. For myself, I've found I get better results (and spend less money) if I just worry about getting good quality tone with pro-level gear that's readily available to me, rather than chasing some elusive concept of "holy grail tone" that some clever marketing executive conjured up... Boss GT8 Demo: http://www.youtube.com/watch?v=9Ciww3Aoc2c |
#20 (permalink) |
Personally, I prefer pedals for a couple reasons. First, if I just need distortion for something, then I'd much rather just have to bring one pedal than a rack, and then just use one effect from the rack. So I like the flexibility of pedals. Secondly, while a many effects on rack gear can sound good, I've never found one where all the effects sounded good, as there always seems to be a few that just don't take the effect to where it should. However, it has been a few years since I messed around with any rack effects, so maybe the technology has improved...
RAMA LAMA FA FA FA |
