Old July 25th, 2007, 11:29 AM   #1 (permalink)
Does anyone use the boost on the Fulldrive?
Just curious, I originally bought a Fulldrive (a long time ago) because it was a "2 in 1" pedal. I love the first channel but have never found a good use for the second, mostly because I can only set the level (nothing else). So does anyone use it?
Just curious.
Steve McGinnis is offline   Reply With Quote
Old July 25th, 2007, 02:10 PM   #2 (permalink)
Daddy Elmis's Avatar
I use mine all the time. The I use the overdrive "half" to add dirt to either a clean amp setting or really dirty up a "just overdriving" amp. The boost is set to push everything to lead territory. I don't use the comp cut setting as the pedal is much more "amp like" without the compression.
With a ss amp, I think the boost would only allow a volume bump for leads. With a tube amp, it does wonders.
Daddy Elmis is offline   Reply With Quote
Old July 25th, 2007, 07:24 PM   #3 (permalink)
DavidP's Avatar
What Daddy said...
mine also gets regular use, with boost set to 1 o'clock.
barely in tune and teetering on the brink of oblivion...
DavidP is offline   Reply With Quote
Old July 26th, 2007, 07:26 AM   #4 (permalink)
ruger9's Avatar
I've got my amp set at breakup, so I usually use only the OD side of the FD2. However, if I want heavier gain, like for some ZZ Top or 80's hair metal, the boost does wonders. A little noisy with my amp set the way it is, but still cool.
Old July 26th, 2007, 11:53 PM   #5 (permalink)
i use leave the boost on all the time. when The boost by itself does nothin until left side is on. i prefer both at all distortion times with an occasional added bd-2 in that mix
telerocker5150 is offline   Reply With Quote
Old July 27th, 2007, 03:33 PM   #6 (permalink)
Rusty's Avatar
same here...
i use it to get more of what the od side was already leaning towards...and with my rig that boost side gets ALMOST as dirty as a RAT. i'm a big fan of the fulldrive...
Rusty is offline   Reply With Quote
