Old December 30th, 2006, 01:58 AM   #1 (permalink)
Big White Tele's Avatar
Any Bad Cat or Dirt Box pedal users?
Hi, Any one using a Bad Cat or the Matchless dual OD pedals? Any opinions? Thinking about one for my Dual pro, Deluxe reverb setup. Thanks very much!!!
Big White Tele is offline   Reply With Quote
Old January 3rd, 2007, 06:46 PM   #2 (permalink)
BluesOwl's Avatar
Hot Box
I gotta Matchless Hot Box that I don't use (cuz I gotta matchless Lightning combo that gets me what I need).
The hot box seemed to have the hard rock (Chieftain) matchless flavor. I downtubed the 12AX7s to 12AU7s and it helped, the OD is less shred and more creamy now. But I still don't like it. It sounds much different than the OD I'm getting out of the 15watt Lightning (it has 12AX7 preamp tubes) and I AM driving the pre-amp section vs. the EL84 output section.
It plugs into the wall and has a built in transformer. It adds some background noise. I've heard that modifying the unit to have the transformer in a separate box helps with that issue...but I'm not going to go to the trouble of doing that.
I always wanted to try a Dirt Box as I thought it may have a preferable OD sound. Can you tell of any diff.s between the Hot and Dirt, that you know of?
I think the concensus is that there are better OD boxes than the Matchless and Bad Cat boxes.
I'll probably sell mine...they still seem to command a high re-sale value.
I've a Keeley Katana clean boost (has a FAT switch too) that I like.
Another I want to try is a Klon Centaur.
BluesOwl
BluesOwl is offline   Reply With Quote
