#123 (permalink) | |
Here's a picture of my board with almost everything on it and almost ready to go.
The last thing to go on (for now) is a Loopmaster true bypass looper down at the lower left on the board. It will allow me switch pedals or multiples of pedals in and out of the signal chain and not have to worry about them sucking tone when I don't use them. It will also stop me from having to do the stompbox 2 step cause the pedals all stay on and are switched in and out from the Loopmaster. So all controls are right there at the bottom of the board except for the tuner and compressor. The pedals are a Korg DT-10 tuner, Maxon CP-101 compressor, Dunlop volume pedal, Dunlop Crybaby wah, Dunlop Q-Zone, , Pro Co Rat,Maxon OD-808, Electro-Harmonix Small Stone Nano, Maxon CS-505 Chorus and a CMATMODS Deelay. Sometime in the spring I'm planning on adding one last pedal to the board. It's a BoBro pedal made by Bobbe Seymour in Nashville and it basically creates a resonator guitar sound on an electric. It's made for pedal steels but should work just fine on an electric. The board is connected to the amp via a [webmaster edit] product name removed due to threatened legal action[/edit] that allows me to consolidate both power and signal chain into one cable and keep the power for the pedals behind the amp and out from under foot. They're powered by a Godlyke PA-9. The pedals are all attached to the board with brackets and screws so they don't move around or fall off ( and can't be stolen on a gig)and will be wired from below for a really clean top with George L's cables. ![]() Also, I have an old friend who owns Cloud 9 Covers who is going to make me a custom case for it out of ballistic nylon with hard inserts.
Home Grown's MySpace Page Quote:
#126 (permalink) | ||
#127 (permalink) |
my new smaller pb that I use in the studio together w/ a great BOSS ME 50 multieffector (I was using a far larger one w/ many effects that were useless to me before.... Jampedals germanium fuzz>omega fuzz>jampedals dynossor comp>Boss Tu2>Digitech Synth Wah>Stamps Driveomatic>SIB Vibromatic>BOSS PH1R Phaser>Semaphore tremolo>Digitech Digidelay |
#130 (permalink) |
Hey Tom A.
I would sure be interested in what kind of mods you did to your pedals. BTW, nice board. Bob
It don't mean a thang if it ain't got that TWANG!!!
#131 (permalink) | |
#132 (permalink) | |
I must admit, I monitor this thread. Pedal boards are so cool |
#133 (permalink) |
New Year....New Pedalboard!
Here's the latest configuration of mine. Camera phone pic, so....it's a bit blurry:
![]() Boss TU-2>Barber Tone Press>Barber Silver LTD>Blackstone Appliances Mosfet OD>BYOC Overdrive (with selectable clipping and filter cap mods)>TC Electronics VPD1>Fulltone Clyde McCoy Deluxe Wah>Ernie Ball Volume>Maxon Pro+ Phaser>Keeley TR-2 Trem>Boss DD-20 Giga Delay>(not pictured) BBE Sonic Stomp>Barber Launch Pad Almost sounds like overkill when you write it all out like that
www.thegearspy.com |
#134 (permalink) |
Scaling back...
Here's the December 2006 edition. Now in an easy-to-carry bag:
And inside: Far Left: Stompbox (powered by a Radio Shack PZM mic). This is actually a box that I stomp on for percussion. Runs into a small mixer and then into a SWR LA12 bass amp. Thump! Signal Path: Peterson Strobostomp (upper right) --> DeMarco Electronics Klonebender MKII (lower right) --> HBE Germanium Treble Booster (lower left) --> Rocktron Short Timer (upper left) --> 70s Silverface Champ modded to Tweed Specs |
#135 (permalink) |
Klonebender
Missfortune,
How do you like your Klonebender II? (Duh, you must like it...it's on your board.) Any comments? Have you any experience with the III from DeMarco? I'm looking for a Tone Bender-clone. Thanks.
Dave. #5258 |
#136 (permalink) |
Dave,
I really like it...so much so, there are two of them in my house. My daughter "borrowed" the first one so I ended up buying another. I wrote a pretty comprehensive review over at HC: http://reviews.harmony-central.com/r...bender+II/10/1 (It's the first review on the page.) I haven't tried the MKIII version, but I'll bet it's pretty good as well. Rick DeMarco has been great to work with. The first unit had a compenent go bad and Rick made it right in no time. He has been prompt in replying to email messages and the build didn't take too long either. I recommend his stuff (for whatever that's worth!) mike |
#138 (permalink) |
Here's mine!
Here it is. I have been watching this thread for a while and have seen some cool stuff. This is what I have been using while I figure out what I want to keep, what to sell and how I like it set up. I am hoping to build a nicer board when I decide to stick with a particular setup for a while.
Peace, Bob
