Old November 18th, 2007, 11:57 PM   #401 (permalink)
Tadeo_Gómez's Avatar
I have only this 2:
. Retro-Sonic Analog Delay
. Fulltone Fulldrive 2 - 10Th Anniversary Mosfet Edition
I build this Custom Mini Power Supply:
I need a Wah and tuner.
Thanks
Tadeo_Gómez is offline   Reply With Quote
Old November 19th, 2007, 03:15 AM   #402 (permalink)
Teleblooz's Avatar
Originally Posted by Tadeo_Gómez View Post
I have only this 2:
Thanks
Nice looking box. Sweet old Tele too.
“I crawl like a viper through these suburban streets..."
http://www.myspace.com/teleblooz
Teleblooz is offline   Reply With Quote
Old November 21st, 2007, 12:47 PM   #403 (permalink)
JJ
JJ's Avatar
JJ is offline   Reply With Quote
Old November 21st, 2007, 05:23 PM   #404 (permalink)
jfm
jfm is offline   Reply With Quote
Old December 8th, 2007, 03:24 PM   #405 (permalink)
Big Lug's Avatar
With the installation of a Weber California in my DRRI my board has changed to accommodate the new sonics. That, and the aquisition of a pedal that has blown a MI Audio Blues Pro off the board:
Tele >> Teese RMC-1 wah >> Loooper A/B box >> (A) RGW Bad Bob booster >> RGW Dirty Dan >> Maxon chorus >> DRRI (with California speaker; Mercury Magnetics output and power transformers; NOS Marconi power and GE preamp tubes; JD Newell solid pine cabinet).
Love playing straight into the amp. On 5-6 on the volume she opens up nicely to reveal the tele's charm with a bit of an attitude.
The Bad Bob gives a great clean boost and smacks the front end of the amp nicely in doing so. When some "true grit" is needed the Dirty Dan steps up to the plate.
That Dirty Dan should be outlawed.
"Get your facts first and then you can distort them as much as you please." - Mark Twain
Big Lug is offline   Reply With Quote
Old December 8th, 2007, 04:06 PM   #406 (permalink)
xjazzy's Avatar
Later version:
The Twin Tube its "THE" OD pedal. Great sounding pedal. When I bought it I was thinking on selling the Jekyll & Hyde but they complement each other and they're both great pedals. Now I have more than 6 choices of sound and that's amazing!
I use a DRRI.
Still got the Twang!
myspace.com/jpmartins
xjazzy is online now   Reply With Quote
Old December 9th, 2007, 04:13 PM   #407 (permalink)
goldtopper's Avatar
Wish this were mine. It's Brad Avery's from the Third Day show yesterday....
ΜΟΛΩΝ ΛΑΒΕ
goldtopper is offline   Reply With Quote
Old December 9th, 2007, 06:22 PM   #408 (permalink)
Originally Posted by jfm View Post
jfm - Welcome and great looking board.
Two questions -
- Who makes your blue patch cables? They look terrific!!!
- How much noise or tone suck does the Dano add and do you need to run it thru a loop?
Thanks
Gear List (with Pics)
csapo is offline   Reply With Quote
Old December 11th, 2007, 12:26 AM   #409 (permalink)
64Strat's Avatar
the current mess.....
been rearranging the pedals and signal path. it ain't real pretty like some of y'alls but it sounds good.
the key pieces are the EB VP jr., H&K Tube Factor, Teese RMC1, Radial Plexitube, Digitech Flange, Phaser, Chorus, Delay, over to the rack for the Lexicon MPX100 and the BBE Sonic Maximizer, then back to the Eventide Time Factor (Midi pedal controlling the Eventide and the Lexi) and one of it's outputs goes to one of the Marshalls or old Laney heads whichever suits at the time and the other output goes to the AB Both switch that controls the two combos, one of which is a '72 SFVR, the other is a Laney LC50.
The Tube Factor stays on Factor 1 all the time, the Lexicon provides a light amount of reverb, the BBE is set for a moderate amount of processing all the time and everything else is to taste and what the music needs.
It's still evolving.
update.....
I re-routed the signal path today, back the way I had it previously. On the front end, the volume pedal, Wah,Tube Factor and Radial Plexitube to the '72 Marshall Super Bass. Then I tap off of the Hot Plate that is between the Marshall and the 4x12 cab and run that line out through the BBE and Lexicon, then over to the time based pedals (chorus, phase, flange and delay) on the board, then to the Eventide and stereo out of it to and AB switch to the 2 combo amps. Much better when stepping on the Marshall hard, the combos get the cranked amp flavor and the time based effects still sound really good on the wet half of the rig.
64Strat is offline   Reply With Quote
Old December 11th, 2007, 05:52 PM   #410 (permalink)
waters's Avatar
waters is offline   Reply With Quote
Old December 12th, 2007, 06:30 PM   #411 (permalink)
bit old now, as i have got a pedaltrain 2 instead of the piece of plywood i was using (planning to get another pedaltrain to get everything on a board), same pedals though.
Tele/Strat > MXR Blue Box > Zvex Fuzz Probe > Effector 13 Torn's Peaker > Boss PS-2 Pitchshifter/Digital Delay > Boss DD-3 Digital Delay > Digitech Whammy reissue > Electro Harmonix Small Stone > modded Boss DS-1 Distortion > Frantone Sweet > Boss BF-3 Flanger > Catalinbread Semaphore Tremolo > Electro Harmonix Deluxe Memory Man > Marshall Echohead > old Marshall JMP
as you can probably tell, i like fuzz and delay, probs using more pedals than i really need, but i'll change how i play songs and what sounds i use every gig and practise.
3rd Storey Chemist
Haze is offline   Reply With Quote
Old December 13th, 2007, 05:52 PM   #412 (permalink)
After Christmas the delay is coming off (maybe) and a Barber Tone Press is being added. (It's a little cleaner wired these days)
telecaster911 is offline   Reply With Quote
Old December 15th, 2007, 07:10 PM   #413 (permalink)
telewhammyfreakshow's Avatar
Been a while since I've been around, my board has changed a thousand times but this is it for now. (Just have to finish wiring it up)
telewhammyfreakshow is offline   Reply With Quote
Old December 15th, 2007, 11:12 PM   #414 (permalink)
missfortune's Avatar
Current version:
Peace,
missfortune
http://www.soundclick.com/professorf...ightycowwolves
missfortune is offline   Reply With Quote
Old December 16th, 2007, 01:27 PM   #415 (permalink)
gillibi's Avatar
Was this for a very long time...
Now it's this, just waiting on some more George L's.....
Strats, Teles, LPs, 335>Rangemaster clone, Marshall overdrive, Echoplex clone, Leslie clone>modded Fender combos
gillibi is offline   Reply With Quote
Old December 17th, 2007, 04:23 PM   #416 (permalink)
jfm
csapo....
the cables are DiMarzio (patch) & George L
The Dano is not bad at all re: noise, I have a Boss NS-2 & don't need it. Tone-suck on the board in general depends on the pick-ups/guitar & settings. I do plug straight in with some guitars, sometimes, not often enough to have a bypass yet but I'll probably do that soon. I've messed with the order a bunch and like this one currently.
The Reeves doesn't have an effects loop & I haven't used this board with an amp that does.
Old December 20th, 2007, 07:14 PM   #417 (permalink)
Guitarmoog's Avatar
Here's a pic of my redesigned board.
I now have two T-Rex boards. One small one has my essentials - Wah, Diamond J-Drive TR boost and OD, '69 Fuzz, Comp, Tuner. This is to grab-and-go for jams and small gigs. The second board is larger, with the stranger, less essential stuff. The loop pedal is a Toadworks Roundabout, and the a/b/y is a Morley for selecting between amps. Power is from two T-Rex Fuel Tank Juniors velcroed securely under each board. I was having terrible hiss problems, but the isolated power from these seems to have sorted it out. The amp switch is for the channels and tremelo of a Peavey DB210, and the other amp out goes to an old silverface Princeton non-reverb.
The two Dano pedals and the whammy are in separate loops using the Toadworks Roundabout.
Here it is split - one cable from the tuner to the Keeley TS9 links them.
And here are some arty-type shots:
It's taken me ages to arrive at this setup. I needed a bigger board than the larger of these two, but didn't want to have to carry a massive thing about all the time.
I also discovered that you can run the two EHX pedals of one EHX adapter with a daisy chain cable. Annoyingly, they really do need 9.6V, and just won't work well with 9v from 1-spots or the T-Rex juniors. No problems so far off one EHX adaptor though.
Guitarmoog is offline   Reply With Quote
Old December 21st, 2007, 10:45 AM   #418 (permalink)
teleclem's Avatar
nice boards there..
teleclem is offline   Reply With Quote
Old December 24th, 2007, 03:21 PM   #419 (permalink)
thirteendevils's Avatar
Fender American Telecaster, Martin 0015, Fender Blues Jr (jj's+Vintage30), Euthymia Crucible fuzz Si, Tonefactor Huckleberry Fuzz, Roger Mayer Voodoo-Vibe Jr, Zvex Wah Probe, Dinosaural Tube Bender, Retrotone Treble Booster,
Boss DS1, Boss DM2, Boss DD6.
thirteendevils is offline   Reply With Quote
Old December 24th, 2007, 03:26 PM   #420 (permalink)
Ed P's Avatar
thirteendevils, welcome and I dig the simplicity of your pedalboard!
Ed
Ed P is offline   Reply With Quote
Old December 24th, 2007, 03:56 PM   #421 (permalink)
Thanks! Merry Christmas!
Old December 26th, 2007, 12:46 PM   #422 (permalink)
Middleman's Avatar
Just finished this rev. 1 version. I will add a longer snake in the future with a multi plug that screws in the side so I can remove the bypass switch bar. This setup includes a radial DI which allows long distance runs to and from the amp. These road cases with their foam inserts are great. Most of the wiring is hidden. I am going to route the power chord out the side at some point to make things cleaner. It's a work in progress but already road worthy.
Middleman is offline   Reply With Quote
Old January 1st, 2008, 03:26 PM   #423 (permalink)
I made a change or two before wiring it up, I'm still not quite happy with it. I think I may swap the flanger out for a phase or vibe
Old January 2nd, 2008, 10:30 PM   #424 (permalink)
tweedtone's Avatar
My latest rewiring brainstorm resulted in this...
Signal chain is:
Seymour Duncan Pickup Booster (usually on resonance setting 1)
Fulltone Clyde Standard
Loop-Master Bypass strip
Tuner out to BOSS TU-2
Loop 1: Luxury Drive -> Mi Audio Blues Pro...for solo/heavy crunch
Loop 2: Ibanez MOSTORTION MT-10 (in yellow case, rehoused by FXDoctor) for lite crunch and sparkle
Loop 3: Marshall Echohead (on either Tape Echo or Multi-Tap)
Loop 4: Marshall Reflector (on Spring)
out of Loop-Master
BOSS TR-2 Tremolo (stock, may replace with Marshall Vibratrem, I dunno)
all connected to amp via Pedalsnake (great product!)
Between SD Booster and wah is Loop-Master Tap Tempo switch for Echohead.
Coiled up below the tuner is a TRS cable which goes to a BOSS FS-6 for when I want to use my Vox AC-15CC's onboard trem or reverb. When I have the stage room and the gig warrants, I loke to use the Vox and a Deluxe Reverb side-by-sde, setting the Vox's trem's Depth all the way up, yielding a cool quasi-stereo tremolo.
tweedtone is offline   Reply With Quote
Old January 6th, 2008, 01:38 AM   #425 (permalink)
PraiseCaster's Avatar
It aint much, but here it is (I just finished putting it together):
It's a Coffin Case, but I like to call it "me pirate case matey! Arghhhh!"
I go either Tele or LP into my TS808 RI, >> Boosta Grande, >> Marshall Regenerator (set to phase shifter), >> CH1 Super Chorus, >> BBE Sonic Maximizer, >> Morley Lil Alligator Volume Pedal, >> Planet Waves Tuner, >> Heavily modded Pignose G40V Amp, pumped through a Celestion Vintage 30.
I have a surge protector/power strip tucked under the riser. I had to cut about 3 inches off the riser to accommodate my setup.
My Sonic Stomp is always on. I call it my secret weapon.
My chorus is also always on. I barely have it cracked on: I dont go for the pink floyd effect (soaking wet), rather just a little damp.
My TS808 gets stepped on the most. My amps single channel, and I dial in the best "Clean" I can get. The TS808 provides all my OD, so I am constantly on and off with it.
I think I have enough room to squeeze two or three more pedals on there. I'm checking out compressors now, and I want a delay too. Dont know what the third one will be, or if I even get a third one. It's got to fit into the tone I hear in my head. If it dont, it wont make it onto the board.
PraiseCaster is offline   Reply With Quote
Old January 8th, 2008, 02:41 PM   #426 (permalink)
P-Nutz's Avatar
Finally got mine photographed ...
Peace.
"When I think back on all the crap I learned in high school, it's a wonder I can think at all. And though my lack of education hasn't hurt me none, I can read the writing on the wall." Paul Simon, Kodachrome
P-Nutz is offline   Reply With Quote
Old January 8th, 2008, 08:54 PM   #427 (permalink)
waters's Avatar
Just added the crunch box a few weeks back so I cleaned the board up when I had the pedals off it. Looks to clean now I need to get some shoe junk on it. Below are some of the pedals I use occasionally.
Old January 9th, 2008, 03:23 PM   #428 (permalink)
picker61's Avatar
Where can I get a board like Joel Terry's..that is a pedal board
picker61 is offline   Reply With Quote
Old January 10th, 2008, 04:00 PM   #429 (permalink)
hudpucker's Avatar
This week's incarnation:
I don't care about the rules. In fact, if I don't break the rules at least 10 times in every song then I'm not doing my job properly.
--Jeff Beck
hudpucker is offline   Reply With Quote
Old January 11th, 2008, 02:58 PM   #430 (permalink)
After over a year of tinkering and toying with stuff I finally put together something i'm happy with. Here it is.
Clockwise from top left:
Fender Pedal Tuner
Soundchangers! Cloverdrive
Dunlop Crybaby Standard Wah
Soundchangers! Fuzz Ball Silicon Fuzz
Soundchangers! Orange Crush-Pressor
Boss MIJ Super Overdrive
Marshall Vibratrem (Modded by indyguitarist.com)
The little junction box on the right is a true bypass loop that bypasses the entire pedalboard. For my needs and budget, the single loop works better than a large true bypass strip, with this setup I can activate multiple pedals and bring them all into the signal chain at once.
russpurdy is offline   Reply With Quote
Old January 11th, 2008, 08:05 PM   #431 (permalink)
justapasinthru's Avatar
the current version
then into the fender tube reverb.....which may dump into the echoplex...maybe...
"And it came to pass that when the minstrel played, the hand of the LORD came upon him"...2nd Kings 3:15
justapasinthru is offline   Reply With Quote
Old January 11th, 2008, 09:22 PM   #432 (permalink)
iowa's Avatar
Hey Russ, what's the story on the Soundchanger pedals. I've never hreard of them and I can't seem to find them on google?
iowa is offline   Reply With Quote
Old January 12th, 2008, 11:55 AM   #433 (permalink)
Mine is homemade and ugly, but I like it. I now have a Zen Drive pedal on board.
Texas Picker is offline   Reply With Quote
Old January 12th, 2008, 03:58 PM   #434 (permalink)
The Soundchangers are built and handpainted by yours truly. The Cloverdrive is a clone of a tubescreamer, the Fuzz Ball is a clone of the a '70 silicon fuzz by a certain boutique manufacturer, and the Crush-Pressor is a clone of an Armstrong Orange Squeezer.
If anyone is interested, I do custom designing and hand painting on pedal enclosures. I will also build pedals to order.
Thanks for checking them out!
Old January 14th, 2008, 01:36 AM   #435 (permalink)
Here's my current rig...Diamond Comp>Modified Vox Wah>Eternity>Tim>Ceriatone JTM45.
Sometimes I use a AC and RC instead of the Tim just to change the flavor a little. For my simple set up I use a Fulltone Fulldrive and my sweet lil SF Vibrolux which has been Blackfaced. Tone to die for
poipounder57 is offline   Reply With Quote
Old January 15th, 2008, 06:19 PM   #436 (permalink)
lukeness's Avatar
So every forum I visit has one of these threads... I love em! Here's my contribution:
lukeness is offline   Reply With Quote
Old January 15th, 2008, 08:54 PM   #437 (permalink)
Oh man, GREAT looking bound thinline Esquire!!!!!
How about a bit of info on that baby?!?!?!?
Old January 15th, 2008, 09:00 PM   #438 (permalink)
lukeness's Avatar
Here ya go:
http://www.tdpri.com/forum/telecaste...ontent%29.html
Old January 16th, 2008, 05:54 PM   #439 (permalink)
Tim73's Avatar
Having not used effects much, I recently had another thread here where I got some advice. Not being a Marshall amp user I'm suprised at how well I get on with their pedals. The Danelectro Tuna Melt / Boss Compressor were TDPRI recommendations, the Fender pedal is a tuner & the Native American Smurfs were a personal touch!
Born in the '70's & in my mind, still living there now...
Tim73 is offline   Reply With Quote
Old January 26th, 2008, 09:41 AM   #440 (permalink)
piaggio's Avatar
what do you think is missing in this pedalboard ?
hello everybody !
this is my beloved pedalboard...I'm a tele -wisher, I plan to
get one this summer.
I think the best tele ever heard is on the "younger than yesterday"
album played by clarence white.
now, I need your advice :
a) there is something really missing in this pedalboard ? (I really like my ac-30 amp crunch, so maybe not an OD)
b) what the best settings for the cs-2 ?
piaggio is offline   Reply With Quote
