A/B/Y box and signal strength - Telecaster Guitar Forum
Old October 16th, 2013, 09:18 AM   #1 (permalink)
Jupiter's Avatar
I'm thinking about splitting my guitar signal to run it into 2 amps. I was wondering: is there attenuation of the signal when you do this? Is it a lot? If I don't need the A/B function, can I just use a Y-cable for this purpose, or do I need some diodes and wires and junk in between?
Jupiter is online now   Reply With Quote
Old October 16th, 2013, 09:39 AM   #2 (permalink)
waparker4's Avatar
If there is attenuation of the signal I haven't noticed it because said signal is getting amplified by two amps. I suppose the input impedance of the two amps will be in parallel so the resulting impedance will be lower, but I have not experienced any degradation of sound as a result of using my A/B/Y box. If you are worried about it you could run your Y cable off the output of a buffered pedal like a Boss tuner. Actually a Boss tuner is an A/Y pedal so just use one of those if you got one.
waparker4 is offline   Reply With Quote
Old October 16th, 2013, 11:15 AM   #3 (permalink)
PumpJockey's Avatar
You would notice a lower impedance effect if you put effect boxes *after* the split (in other words, for one of the amps only). A lot of stomp boxes won't deal with a lower impedance. High end A/B/Y boxes like the Fulltone fix this, others don't.
If all your effects are before the split you should be fine.
Teles, Esquires, Strats, Specials, SGs, Jrs, Champ, Princeton & Deluxe… Life is good when life is loud.
PumpJockey is offline   Reply With Quote
Sponsored Links   #
Old October 16th, 2013, 12:43 PM   #4 (permalink)
I think it's best, and quite easy, to use a pedal as a splitter. The tuner suggestion is good. The Bad Monkey has two outputs. Many stereo pedals in bypass give you dual mono out.
FenderLover is offline   Reply With Quote
Old October 16th, 2013, 12:55 PM   #5 (permalink)
Lowbassnotes's Avatar
I run my ABY last, haven't ever noticed any wierdness in signal strength. I sure like stereo, 2 amps of completely different flavors is tons of fun when you switch back and forth. When I hit combine it sounds really flush like a wall of sound with a real spatial thing going on.
Lowbassnotes is offline   Reply With Quote
Old October 16th, 2013, 06:08 PM   #6 (permalink)
Coldacre's Avatar
I've been using a BOSS LS-2 for 10+ years.... to run 2 amps live. great little unit.
Coldacre is offline   Reply With Quote
Old October 16th, 2013, 06:11 PM   #7 (permalink)
artdecade's Avatar
How are you doing that...? I didn't know you could do that with the LS-2.
C'mon Everybody!
artdecade is offline   Reply With Quote
Old October 16th, 2013, 06:35 PM   #8 (permalink)
p8t8r's Avatar
You can do that and many more. LS2 is a hidden gem, I've got a couple.
Left hand guitars look good only in a mirror
Transparency is for colordeaf
p8t8r is offline   Reply With Quote
Old October 16th, 2013, 08:08 PM   #9 (permalink)
blackguts's Avatar
I have the fulltone aby soft touch, and all I do all day is mess around with the possibilities such a simple defice opens up. Sometimes I wonder about using a Strymon Flint to drive two amps and what I could do with that.
blackguts is offline   Reply With Quote
Old October 16th, 2013, 11:02 PM   #10 (permalink)
soulman969's Avatar
I think with a quality A/B/Y box run after the effects chain you shouldn't experience any problems or at least I haven't noticed any with mine and it's a Whirlwind.
CS Nocaster; Nashcaster; Squier CVC; Squier CVC/FSR, Nashville Tele; Lenti Cavalier Esquire; Epi ES339 Pro, Epi '56 Gold Top, Taylor 214ce-dlx; Roland Cube 40xl; Roland Blues Cube; Egnater Tweaker; Bugera v5; CV JBass; CV PBass; tc BG250 Bass Amp; Zoom B3.
soulman969 is offline   Reply With Quote
Old October 16th, 2013, 11:27 PM   #11 (permalink)
Jupiter's Avatar
Thanks guys. I was going to say that I don't have any pedals that can split the signal, but I just realized I might!
Old October 16th, 2013, 11:40 PM   #12 (permalink)
Coldacre's Avatar
what did you think the LS-2 was for?
Old October 17th, 2013, 08:58 AM   #13 (permalink)
artdecade's Avatar
I thought it was for setting up two effects loops (w/ lots of options) - not for splitting a signal between two amps. It only has one output... I have to look at the manual! Ha.
EDIT - Oh I see now. You can actually just send the signal to all three outputs. That's pretty swift!
C'mon Everybody!
» Random Photo for Guests
Artcore
» Recent ThreadsGuests
Fender Logan Custom Guitars
