Old November 15th, 2005, 09:49 AM   #1 (permalink)
Dating Dyna Comp's
In the last two years I have collected 2 MXR Dyna Comp's through various trades. Both look old. Both react quite differently as well when I use them.
The "newer" one sounds a little brighter, but the compression doesn't really kick in until the knobs are around noon.
The older one compress's like son of a gun. I can barely get the right knob past 9 o'clock without noticing the compression.
I was just curious as to how I would date them?
"Yeap, I like the American Standard Telecaster, I can even live with one a them PCB amps, and I even use one a them mul-tie-effects things too."
Darrell is offline   Reply With Quote
Old November 15th, 2005, 01:49 PM   #2 (permalink)
Re: Dating Dyna Comp's
Would like to know that too.
I recently bought a used one, block logo, no LED and no adaptor jack so I suppose it's an 80's (?).
Noe Lee is offline   Reply With Quote
Old November 16th, 2005, 02:45 AM   #3 (permalink)
TeleTubby's Avatar
If you can get in to see them, the back of the pots should be coded with the manufacture date of the pot. Try here for a brief intro into source-date codes- scroll down the page a bit. Let us know what you find out!
"Bless my cotton socks, I'm in the news..." Saint Julian, circa 1980.
TeleTubby is offline   Reply With Quote
Old November 16th, 2005, 12:51 PM   #4 (permalink)
I would like to try this, but I'm very clumsy and I'm afraid to break something.
Any hints on how to do it? Or should I ask someone who's more handy than me?
Old November 20th, 2005, 01:27 AM   #5 (permalink)
All I know is I've got one from the late 80s that's just like your second one - perfect at 9:00, ridiculously squished anwhere above that.
Mike Fleming is offline   Reply With Quote
Old November 21st, 2005, 11:29 AM   #6 (permalink)
analogmike's Avatar
HI,
It's really not too tough to pull the board up to check the date codes on the pots, see mY FAQ for decoding info.
Earliest Dynas were script MXR logo, '75 - '76 or so.
Mid versions were block logo smooth paint with no LED or Power jack, '77 - 80
Late original MXR pedals had power jack on the side (1/8" plug) and LED, about '81 - '82
Dunlop made reissues just like the late originals in the 90s with hand wired pots and switch.
Current dunlop reissues use board mounted pots and switch.
Have fun!
Regards, mike
analogmike is offline   Reply With Quote
Old November 21st, 2005, 11:37 AM   #7 (permalink)
That would make sense
Then I have one that is a mid version, and one that is a Late orignial.
They sound and work surprisingly different.
Old November 25th, 2005, 02:44 PM   #8 (permalink)
analogmike's Avatar
Re: That would make sense
They used some lousy parts in the later years. Any of the original ones made by MXR can be easily modified with true bypass, LED, power jack etc and we also do a script logo mod on them. The script logo mod uses NOS MXR script logo/Ross compressor transistors which we test for noise and match. Have fun!
Regards, mike
Old November 25th, 2005, 08:36 PM   #9 (permalink)
The number on the pots of mine says "1378102", so it should be from the second week of 1981 (?)
This may be strange, but mine has neither a power jack nor a LED. Or could it be a "late mid version" ?
Old November 26th, 2005, 01:08 PM   #10 (permalink)
analogmike's Avatar
Yes, a very early 1981 is the same as the '77-'80 I guess. have fun!
Regards, mike
Old November 28th, 2005, 08:15 AM   #11 (permalink)
Maybe some flowers and a box of chocolates to start with?
strat_and_tele_guitarist is offline   Reply With Quote
Old November 28th, 2005, 10:10 AM   #12 (permalink)
It depends
It depends on whether it sounds good that day.
