Can anyone compare the Analogman Comprossor to the Keeley--n
I'm wondering which one is quieter regarding residual hiss. I use a compressor at the beginning of the chain so it wouldn't be amplifying any other pedal's noise--just the hum from single coils :-)
| Sponsored Links |
I have only tried...
The Analogman comprossor and did not find it to be noisy at all... definitely less noisy than my CS-3 and clearer toned when A/B'ed. I really liked it A LOT... That being said I have not tried the Keeley(but boy do I want to) as I'm sure you know the reviews are always great and I remember people specifically recommending it as "quiet."
I personally think you can't go wrong either way, I'd even guess that they are probably similar sounding (just a guess!). |
I have the Analogman and...
found it to be noisier (hiss) than I would have thought, based on it's revered status. It's at the beginning of the chain so the noise is definitely coming from its circuit. Controls are Sus.-11:00, Output-11:00.
The Keeley stresses its low noise but I wonder if it's really true--I'm not suggesting that it's BS, just that these descriptions are subjective. I had a Carl Martin and it was definitely quieter than the Analogman. |
#4 (permalink) | |
Re: I have the Analogman and...
Radio--Carl Martin-yeah...
Mine did that too, which is why I sold it. Right after I did, I was told of a simple fix for the problem--starting to wish I hadn't let it go now. I'm running a BD2, a Bad Bob, DL4 and a MM4 after the CompROSSor. The Bad Bob BTW is wicked quiet, but because it's after the CompROSSor it boosts its noise as well.
#6 (permalink) | |
Re: Radio--Carl Martin-yeah...
I have Keeley experience...
having said that, I haven't had the priveledge of hearing first hand the aNaLoG.MaN... but I've had my Keeley running on stage next to guitar players with the CS-3, CS-2 and the Carl Martin. Compressors inherently add a bit of noise, half of their job it to bring up the "noise" floor, but it isn't bothersome at all. We all know what Boss does to your tone when they're off and both the Keeley and the aNa... are true bypass. To my ears, the Keeley is the most transparent of the lot. Oh, yeah, no radio stations in my amp.
Adam |
#8 (permalink) | |
Thanks. |
keelely comp
FWIW, I have the Keeley compressor, Keeley BD2, and a Bad Bob by Robbie Wallace. The only one that makes any noise is the BD2, and it's slight. I can't imagine a compressor could be any quieter than the Keeley. This nothing against the Analogman comprossor, but nothing can be quieter than no noise at all.
Noise Measurements
Howdy!
I took a stock, off-the-shelf Keeley Compressor and my analogman bi-compressor and measured noise with an oscilloscope. Test conditions were using the same fresh carbon zinc battery, inputs shorted to ground through a 6 foot George L cable plugged into what else but a Telecaster. Both the Sustain and Level set to maximum. No load on the output except the scope. Granted, noise is hard to read because it's made up of many frequencies, changes with time, etc... Both units measure the same noise value. 5 divisions at 5mV/div = 25mVpp of noise. When amplifing a signal, the Keeley Compressor produced slightly more output. The Keeley put out 0.67 Vpp with a 1khz sine wave input (forgot the input voltage) and the analogman put out 0.65 Vpp. So, the Keeley produced an insignificant amount more amplification while at the same noise level. For a reference to these noise figures: A stock SD-1 MIJ produced only 10mVpp of noise with Level, Tone and Drive cranked. All compressors do produce noise, especially when there is no input as the comp is amplifing to its maximum potential. As soon as someone would play a note these noise figures would be greatly reduced. Those figures represent a worst-case, idle situation. Hope that helps! Rk |
About you test...
So based on your test criteria, if the controls were set say to S-11:00 and V-11:00 for both pedals, then the noise levels would be identical? Or, do the level settings have some exponential quality that causes the noise level to shift as the they're set lower--if you get my drift? Is the noise (hiss) in your pedal noticeably audible at those settings? Thanks for your input.
#12 (permalink) | |
I have a Carl Martin compressor, and like it a lot. On rare occassions, I've heard some RF noise, and wonder what the "fix" is for this. Could someone email info or a link on this?
thanks in advance, Dave Patterson Quote:
thanks in advance, Dave Patterson I was told that a 40pf cap from the + side of the input jack to ground will filter the RF--I haven't tried it though. If you do, let us hear your results. Thanks. |
#14 (permalink) |
A 40pF cap might not be a bad idea at all to stop the occasional RF. I have seen many pedals with up to 220pF on the front end. With 220pF you notice just a slight loss in high frequency, so 33pF-56pf should be small enough to keep the gear hi-fi.
Thanks, rk |
