Old July 21st, 2012, 12:25 PM   #1 (permalink)
(Maybe) A Dumb Pedal Question
Looking for a pedal that will get me a dirty blues sound. I am trying to learn SRV type songs and I know I won't be able to replicate his sound, but if I could get in the neighborhood that would be a great start.
I play a Tele and a Strat, both have humbuckers in the bridge. My amps are a Champion 600 and a Vox Pathfinder 15R and I play strictly at home. I know there are a lot of pedals out there, but don't know if there are ones that are better suited for a tube amp vs. solid state. It would be nice to have one that would play well with either amp. I shop almost exclusively at GC and want to go in there with some sort of knowledge and not be totally at their mercy.
Thanks in advance!
Jim
FenderGuitarFan is offline   Reply With Quote
Old July 21st, 2012, 12:34 PM   #2 (permalink)
6ixstring's Avatar
A tubescreamer and a cranked tube amp(mostly fenders) is SRV.
6ixstring is offline   Reply With Quote
Old July 21st, 2012, 01:02 PM   #3 (permalink)
coldwar1977's Avatar
Hi Jim, a Digitech Bad Monkey (Tubescreamer-type overdrivepedal) would be a good start imho! It sounds great for what you want and is totally inexpensive. And remember to use your neck pickup for that typical SRV thing.
coldwar1977 is offline   Reply With Quote
Old July 27th, 2012, 11:41 AM   #4 (permalink)
Thanks 6ixstring and coldwar1977. I am going to GC this weekend to try a tubescreamer and see if they have the Bad Monkey as well.
Jim
Old July 27th, 2012, 12:24 PM   #5 (permalink)
Jim
I have Pathfinder 15R and a Biyang 'Tube Screamer clone,' and with the Pathfinder's Gain at 11 clock (Boost OFF) volume UP, and the 'Tube Screamer' at low Drive and higher Volume this really gooses the PF into overdrive for a great SRV lead tone with great sustain-I was quite surprised at how good everything sounded with the PF! I play Fender amps, and it just seems that the little Vox just has that slightly hotter Gain running and aggressive tone running thru, so when you push it with an OD, this sucker turns into a pit bull. PLenty of volume and the low end does not fall apart. just keep those Gains low so things don't get too gritty-
Tele/Tex-Mex Strat/Dano '56 U2>MHP "Stubble Trouble" FUZZ/MHP "perfected" GFS Brownie Classic/Barber Direct Drive/Blues Driver> MORE PEDALS> '68 Deluxe Reverb or blonde Blues Jr. Rock On!
Chiogtr4x is online now   Reply With Quote
Old July 27th, 2012, 12:27 PM   #6 (permalink)
bossking7's Avatar
Yep, a tube screamer will get you there.
bossking7 is offline   Reply With Quote
Old July 27th, 2012, 12:38 PM   #7 (permalink)
+1
+ std single coil strat neck..the buckers will take you away from the sound
you are trying to get
A person who won't read has no advantage over one who can't read.....
Mark Twain
uriah1 is offline   Reply With Quote
Old July 27th, 2012, 12:38 PM   #8 (permalink)
waparker4's Avatar
Try the Boss SD-1 as well. It is similar to a TS, but has asymmetrical clipping and I don't know which will sound better with a solid state amp.
You may want to keep your eye out for a pedal that clips in a way you like it at low volumes. What I'm trying to say is, SRV tone to me is a TS type pedal with the drive down low and the level up, boosting the signal with not alot of clipping from the pedal, but overloading the front end of a large Fender tube amp that's already LOUD. The sound occurs at volume levels not possible if you're a bedroom player.
waparker4 is offline   Reply With Quote
