Old July 18th, 2012, 08:12 PM   #1 (permalink)
ian_45's Avatar
Help Me Arrange Please
Hey guys,
Just curious, what would you say is the best arrangement for these pedals:
Boss TU-3
Big Muff Pi
MXR Carbon Copy
Digitech Whammy IV
Morley A/B Box (using to switch between two amps and run stereo)
Currently I have it ordered:
Boss
Whammy
Muff
Carbon
Morley
Is this the best way technically speaking? Or does anyone else have another way they would do it? (And yes, I will be trying different orders to see which sounds best, just looking for opinions)
Amp is an AC30 if you care to know, has an effects loop but I'm not using it right now, maybe I should?
Anyways, thanks for your help.
ian_45 is offline   Reply With Quote
Old July 20th, 2012, 04:29 PM   #2 (permalink)
lefty73's Avatar
You say you have "an" AC30, which means one. Unless you're lucky enough to A/B between two AC30s? ;) I wouldn't go for the Vox's effects loop unless you're using the amp's overdrive. If not, just use the Top Boost channel set to the verge of breakup and you'll be just fine (but you probably already knew that).
If you're using just one AC30, you could move the pedals around as such:
Morley A/B
A side to Boss
B side to other pedals
other pedals ordered as Whammy > Muff > CC
This would completely eliminate the tuner from your signal path, which may/may not provide any benefits to your tone.
- Boss BF-2>Joemeek floorQ>Boss DS-1>Fulltone OCD>MXR Carbon Copy>Boss DD-5
- OCD replier to zero-reply topics on Page 1 of TDPRI's The Stomp Box
lefty73 is offline   Reply With Quote
Old July 20th, 2012, 04:43 PM   #3 (permalink)
ian_45's Avatar
Thanks for the input. And I meant I'm using an AC30 mainly Running stereo with a Fender Mustang III on occasion just to try it out a 'bigger' sound. Otherwise just using the A/B box to switch between channels on the Vox.
