Old July 16th, 2012, 07:11 AM   #1 (permalink)
blackkeys's Avatar
OD Suggestion for Fender Bassman RI
I have an old Fender Bassman RI with the blue Eminence Speakers from 91/92 with a Telly.
I´m looking for an new OD Pedal which delivers me the Black Crowes/Stones Crunch Sound.
I tried a Catalinbread Formula No5 but it doesn´t sound very authentic through the amp.
Any suggestions but not Les Lius, Wampler Tweed 57....
And no... I coundn´t turn the amp all the way up
Suggestions for a good OD Pedal which fits to the Bassman?
Thanks.
blackkeys is offline   Reply With Quote
Old July 16th, 2012, 07:44 AM   #2 (permalink)
Gringo13's Avatar
I always loved the FN5 through my Bassman, but I see you've already gone that route. Did you try running the pedal on 18v? It tightens up the bass and sounds pretty authentic to my LTD, but ymmv. The Wampler sounds pretty good to me, but I haven't played one. A lot of folks seem to like the Red Llama for the tweedish vibe as well. I'm currently intrigued by the Zvex Box of Rock. The lower gain settings seem pretty close to the Bassman distortion, so you may wanna try it out as well.
"You'll never lose your mind as long as your heart always reminds you where you left it."- Mike Cooley
"I've always been crazy; it's kept me from going insane."- Ol' Waylon
Gringo13 is offline   Reply With Quote
Old July 16th, 2012, 11:46 AM   #3 (permalink)
A bit strange in English but the rest of you wants to know too.
Theres the Distortron from ZVEX which is the Box of rock without boost, but the sound
goes straight in the Marshall field. My bandmate has a Cmat Brownie in front of his
Bassman and is as happy as can be, expensive though. I'd go in the Boss Corner and
try the Bassman or Deluxe reverb pedal in front. The FDR1 even has reverb and vibrato
on board. 119 each.
Rydell is offline   Reply With Quote
Old July 18th, 2012, 05:21 PM   #4 (permalink)
Del Pickup's Avatar
I was always pretty happy with the overdrive tones I got from my old Bassman RI using a TS9 or Crowther Hotcake - particularly the TS9 for that Keith Richards/Black Crowes gnarly sort of grind.
Someone told me that my tone is in my underpants. I'm not sure if that's good or bad......
www.reverbnation.com/delthomas1
www.myspace.com/delthomas
www.myspace.com/manalishinz
Del Pickup is offline   Reply With Quote
Old July 18th, 2012, 06:05 PM   #5 (permalink)
artdecade's Avatar
Rat. Set the gain low and the volume high. It pounds the hell out of the front of Fender preamps and gives you some sweet sustain.
artdecade is offline   Reply With Quote
Old July 18th, 2012, 06:12 PM   #6 (permalink)
Gringo13's Avatar
I may be crazy, but I could swear I saw a picture once of Keith's rig and it had two tweed Twins driven by a hidden TS pedal. If so, then that would be a good place to start. I have a Green Screamer that I have never liked too much through the Bassman, but I'm about to try it again. Haha
Old July 18th, 2012, 09:24 PM   #7 (permalink)
JTM45blues's Avatar
Try out a Fulldrive, Rich Robinson has used one of those for a long time.
For Keith tones turn the amp up to about 6 or so and smack the strings hard. Or possibly consider a clean boost like a Zvex SHO or Fulltone Fat Boost. You can also dial in some Keith like grit with a Crowther Hotcake into a tweed amp.
Also of note both these guys are tape delay users which helps thicken their tones and add some space.
JTM45blues is offline   Reply With Quote
Old July 19th, 2012, 12:33 AM   #8 (permalink)
Del Pickup's Avatar
I should have said in my previous post that I tended not to run too much gain on these pedals, using them mostly as a clean-ish boost instead.
Old July 19th, 2012, 12:38 AM   #9 (permalink)
The blue collar works pretty well.
"One man gathers what another man spills."
deadicated is offline   Reply With Quote
Old July 19th, 2012, 04:00 PM   #10 (permalink)
cousinpaul's Avatar
I used to play those amps. The speakers can make a lot of pedals sound a little nasel. I had my best luck with a TS-5, and later with a TS-9. The TS mid hump actually works well with the BMRI and can help you get some of the tones associated with the other tweeds.
cousinpaul is offline   Reply With Quote
Old July 19th, 2012, 06:00 PM   #11 (permalink)
Leep Dog's Avatar
Isn't Keith Richards known to use a Fulltone OCD?
Leep Dog is offline   Reply With Quote
Old July 19th, 2012, 06:08 PM   #12 (permalink)
Fuzzblaster's Avatar
EP booster maybe?
Fuzzblaster is offline   Reply With Quote
Old July 19th, 2012, 06:23 PM   #13 (permalink)
This. Or a Barber LTD. Or, in my case, both.
SarahThustra is offline   Reply With Quote
Old July 19th, 2012, 06:58 PM   #14 (permalink)
Maxwell Street's Avatar
TS 9 sounds good, in the old "ask keith" feature on his site, he says he plugs straight into the high power twins live...stadium volume helps..
Maxwell Street is offline   Reply With Quote
Old July 19th, 2012, 11:49 PM   #15 (permalink)
Pants's Avatar
Red Llama for sure. Cheap and furry.
They booked a gig in South Dakota and a tractor pull in France/Sent the post office our photo and they're learnin' us to dance
-Paul Westerberg
Pants is offline   Reply With Quote
Old July 20th, 2012, 06:18 AM   #16 (permalink)
tele salivas's Avatar
HIgh Volume is the best, but if you want that high volume OD at low volume dBs, get a boost pedal, something like an MXR Micro Amp, Seymour Duncan Pickup Boost, Bad Bob, on and on and on. just don't spend too much, cause for the most part you are just pushing the amp's natural characteristics. It's just waiting there. Bassman has fantastic drive sounds.
"So I says to Mable, 'Mable', I says...."
tele salivas is offline   Reply With Quote
