Old June 27th, 2012, 03:34 AM   #1 (permalink)
Best MXR compressor??
Ive been flirting with the idea of a compressor for about 6 months now, because i play a lot of slide and id love to smooth it out and give it some sustain, and i figure im never gonna be completely sold on compression just by youtube demos and reviews, so i think im gonna break down and buy one soon. I think if i decide i really like compression, id probably end up getting a keeley, but i dont want to spend that much money on something im not completely sold on, so im thinking of spending about a third of the price on an MXR compressor, because i trust MXR and have heard good things about their compressors.
my question is, which MXR compressor should i look into? theres the standard dyna comp, super comp, vintage dyna comp, etc., and im just really not sure what the difference is! can i just get the standard dyna comp and be happy?
jswiss is offline   Reply With Quote
Old June 27th, 2012, 06:35 AM   #2 (permalink)
DannyBigShots's Avatar
I dig my super comp
DannyBigShots is offline   Reply With Quote
Old June 27th, 2012, 07:15 AM   #3 (permalink)
i have the super comp & im not impresssed......lots of distortion added & you need to turn the guitar volume down to get rid of it....again, im no expert since this is only the second comp ive ever owned....i use them at gigs for a clean solo boost more then anything....stuff like stray cats i'll turn it on with a slap back delay & leave the guitar volume 1/2 down & for the solo i'll just have to turn the guitar up......thats pretty much the only use i get out of it...they are usless with distortion.....
ive even threw it in the loop & its no differant.....its back in the front of my amp again now....the one thing i never understood about comps is if you take the level down enough to get rid of the distortion it gives off its like its not even on.....
funkymann1 is offline   Reply With Quote
Old June 27th, 2012, 07:49 AM   #4 (permalink)
gitold's Avatar
I have 8 comps including the MXR super and custom. I think the custom is a better comp for the $ in that it will give you a transparent clean comp or a very squishy comp with no attack. My only problem with the custom is that you have to open it up to adjust the attack and tone. That said for the money the super is a good comp.
gitold is offline   Reply With Quote
Old June 27th, 2012, 08:27 AM   #5 (permalink)
What are your settings like? I find it hard to believe that the pedal itself is adding distortion, and if you need a boost, why not use an actual booster and use the compressor as it is intended instead?
Old June 27th, 2012, 10:14 AM   #6 (permalink)
filmix2's Avatar
MXR Bass Comp.
http://www.jimdunlop.com/product/bass-compressor
Hands down their best compressor.
You can't always write a chord ugly enough to say what you want to say, so sometimes you have to rely on a giraffe filled with whipped cream.
-Frank Zappa
filmix2 is offline   Reply With Quote
Old June 27th, 2012, 10:22 AM   #7 (permalink)
waparker4's Avatar
Yes
waparker4 is online now   Reply With Quote
Old June 27th, 2012, 10:40 AM   #8 (permalink)
bossking7's Avatar
Originally Posted by waparker4
Yes
+1
bossking7 is offline   Reply With Quote
Old June 27th, 2012, 12:52 PM   #9 (permalink)
Hows the bypass on these guys?
is there any thats true bypass?
Old June 27th, 2012, 03:51 PM   #10 (permalink)
telebuc's Avatar
There are better options.
RAF Mirage.
telebuc is offline   Reply With Quote
Old June 27th, 2012, 04:13 PM   #11 (permalink)
Lizard's Avatar
After trying out a series of other compressors, I got a Dyna Comp and it is exactly what I was looking for. Can't compare it to other models since I have not tried them, but the Dyna Comp is on my board to stay.
Lizard is offline   Reply With Quote
Old June 27th, 2012, 04:17 PM   #12 (permalink)
waparker4's Avatar
I like the dyna comp and the bypass is fine, tho I don't know if it is true bypass. If you're looking for true bypass clone, I have heard the Biyang Compress X is good, quiet, and otherwise faithful to the DC sound. http://www.tdpri.com/forum/stomp-box...pressor-x.html
Old June 27th, 2012, 07:50 PM   #13 (permalink)
I have the Behringer DC9 dynamics compressor, which is a dyna comp clone. I believe it's true bypass and is actually housed in a nice black aluminum box, unlike many of their cheesy plastic pedals.
Don't have much experience w comp pedals but it sounds great through both my Pathfinder 15R and modded Blues Jr and plays well with my BD-2. About $30.
Shanaynay74 is offline   Reply With Quote
Old June 27th, 2012, 07:52 PM   #14 (permalink)
Sorry, I meant Valve Jr not Blues, of the Epi variety.
Old June 29th, 2012, 12:43 PM   #15 (permalink)
The only ones I have played are the vintage '76 reissue and a block logo, script back. The pots dated it as a '78. The two sound identical. I kept the the reissue because it was modded for led, 9v, and true-bypass.
TheWaker43 is offline   Reply With Quote
Old June 29th, 2012, 01:44 PM   #16 (permalink)
6ixstring's Avatar
I just received my 1980 dynacomp today, loving it. I haven't noticed much of a "noise problem", though I usually only like my comps on low squish settings.
6ixstring is offline   Reply With Quote
Old June 29th, 2012, 01:48 PM   #17 (permalink)
octatonic's Avatar
Script Dyna (original or reissue) is the way to go IMHO.
http://www.jamesrichmond.com
Old June 30th, 2012, 05:59 AM   #18 (permalink)
Tee1's Avatar
What's better about them? Less noise?
Tee1 is offline   Reply With Quote
Old June 30th, 2012, 05:40 PM   #19 (permalink)
schenkadere's Avatar
I have the same issue with my Dyna Comp with higher output pickups...had the same issue with the VS Comp66 and the Marshall ED-1. I just live with it cuz I really like the Dyna Comp otherwise.
Guitar>Boss ST-2 Power Stack>Vox Time Machine Delay>Amp
My music page:
http://www.soundclick.com/schenkadere
schenkadere is offline   Reply With Quote
