Old June 25th, 2012, 06:18 PM   #1 (permalink)
Question regarding noise in my set up
My current board is seen here in the picture, its a work in progress, but so far, I am getting some unwanted noise, I believe from my dyna comp or Boss FBM-1, Anyone have any remedies to get rid of the noise? My buddy suggested a mini buffer to place after the TU-2 before the rest of the chain? I was thinking of getting a loop bypass strip from loop masters to run everything through.
Other thoughts? Will be doing some re-modeling, will be adding a Line 6 M9, EHX Catherdal, POG 2 OR MICRO POG, and a decent delay unit. (Timeline, nova Ib modified etc.) Also, will be adding a DD-3 for slap delay.
brucefan12 is offline   Reply With Quote
Old June 25th, 2012, 06:33 PM   #2 (permalink)
jonhart's Avatar
What is powering it ? It could be your power supply. If it isn't the power, I don't know what to do.
As for the other pedals, you don't realy need a DD-3 and a TC Nova. I'm actualy going to sell my DD-3 to upgrade to the Nova. The Nova has slapback settings. You get 9 presets and I'd just give one up for slapback rather than spending $140 on another delay.
jonhart is offline   Reply With Quote
Old June 25th, 2012, 06:41 PM   #3 (permalink)
First thing would be to check the power supply. If that doesn't work, get a Noise Reducer pedal, that was one of my best purchases. I have the Boss one, just make sure you run your noisy pedals (pretty much all of yours) in the loop. There is also a mod you can get on the EQ that will get rid of the noise that those produce.
6Shotsdown is online now   Reply With Quote
Old June 25th, 2012, 06:42 PM   #4 (permalink)
I am using a Voodoo Lab Pedal Power Plus mounted under the board.
I have the DD-3 already, but just was holding off putting it on the board, because I don't know if I will need it with a NOVA or equivalent pedal as you said. I think I will end up with the Nova Delay as much as having a Timeline would be surreal, It is very expensive.
I also, have the Line 6 M9 already as well.
Old June 25th, 2012, 06:44 PM   #5 (permalink)
6Shots- Where in the chain would the noise suppressor go?
Old June 25th, 2012, 07:01 PM   #6 (permalink)
sacizob's Avatar
Try using a seperate power supply for the pedal in question.
Buddy Holly Lives!
sacizob is offline   Reply With Quote
Old June 25th, 2012, 07:26 PM   #7 (permalink)
I thought it could be the Tuner, so I removed it from the chain and suffered tone loss and volume drop. I was starting the chain with the Dyna Comp. I definitely feel I will be getting a loop strip from loop master. Should I still get a buffer or noise suppressor? I will be plugging in the Drives, COmp and EQ into the Loop Strip and then use a Boost before modulation, verb and delays to boost signal a bit. Will having the drives and noiser pedals in the Loop strip take care of my problem?
Old June 25th, 2012, 10:39 PM   #8 (permalink)
The buffer won't do anything to combat noise issues. Beside, you already have a decent buffer in the Boss tuner, so you're good to go. First mess around w/ your Dyna Comp, based on the settings in the pic, that could impair some noise.
I doubt it would be the PP2, since the taps are isolated. Going back to the Dyna Comp, comps in general can create noise issues and when running it w/ other pedals can definitely give you more noise. But I would seriously play w/ the comp and the settings to see if that may have an impact in your noise issues.
jnepo1 is offline   Reply With Quote
Old June 25th, 2012, 10:41 PM   #9 (permalink)
All the Boss pedals are buffered, so your signal should be fine w/o a dedicated buffer since you have a few Boss pedals there. A true bypass loop strip is really not necessary because of the buffered pedals.
Old June 25th, 2012, 10:52 PM   #10 (permalink)
garytelecastor's Avatar
Hey Bruce.
I had the same trouble and my guitar guy suggested years ago to buy an A/B
box. Run your effects through one side and the TU-2 through the other.
One quick question: For what purpose are you using the Fender pedal?
“Don’t stop believing, unless your dream is stupid. Then you should get a better dream.”-Kid President
Redd Volkaert is a Jedi Knight at one with the Force!!!
garytelecastor is offline   Reply With Quote
Old June 25th, 2012, 11:04 PM   #11 (permalink)
I will mess around with the Dyna Comp and see if the settings change anything. If that doesn't work then perhaps I follow the A/B box suggestion below, but then that takes the TU-2 out of the loop again.
Old June 25th, 2012, 11:53 PM   #12 (permalink)
Take the eq out of the chain. I just bought one and its noisy as hell. I will be doing the mod when I have time. I have read this is a noisy pedal.
pt1911 is offline   Reply With Quote
Old June 26th, 2012, 12:13 AM   #13 (permalink)
OK I will try removing the EQ as well, I thought it was Dyna comp, but since EQ is right after, could be that as well. I will mess with the Dyna Comp settings and remove the EQ, which I really don't need. Gonna get an MXR Micro Amp or MXR-CAE 401 BOOST LINE DRIVER to put after the dirt pedals so that will give me the extra push I was using the EQ for.
Old June 26th, 2012, 11:22 AM   #14 (permalink)
I run out of my tuner into the noise suppressor and then I go out of the loop into my compressor and ODs back to the return of the NS and out to my Delay and Mod pedals.
Old June 26th, 2012, 11:48 AM   #15 (permalink)
By the way just to add a little off topic... I own both the EHX cathedral and the TC Electronic Nova delay (IB modified) they both do great slap delays ;-) (IMO) Before getting a delay I did a lot of research and thats the one I like best... I was actually able to get the Ib modified version for under $180 new ;-) So keep a look out and find a deal :-)
(oh and with the noise issues... you could just get a Polytune.... sorry I had to suggest) but it is a good tuner and best of all no tone suck and no noise
rugrat is offline   Reply With Quote
Old June 26th, 2012, 01:07 PM   #16 (permalink)
I am searching for an Ib modified Nova, but it seems like the limited run is over, where did you get yours?
Old June 26th, 2012, 02:16 PM   #17 (permalink)
Martin R's Avatar
I'll bet its the EQ. But do the obvious, take each pedal out of the line one at a time. It just takes a couple of minutes.
Also, you didn't say what kind of noise. Any chance you've got a bad cable somewhere? And since this is a Telecaster site, is your guitar near a computer monitor or fluorescent light? Single coils are noisy.
FWIW, I tried a noise suppressor once. It was a cheap Boss pedal. It really changed the tone and sounded odd as it kicked in and out. I kept the hum.
Martin
___________________________
E. Christina Herr & Wild Frontier Americana Motel
Martin R is offline   Reply With Quote
Old June 27th, 2012, 12:51 AM   #18 (permalink)
Well your going to hate me... they only sold them through PGS I saw the price (of the ib modified) drop down to $200 (which was/is the normal price else-wear for the regular nova delays although PGS kept the price at $250 with their ib modified) anyways when I saw that I knew they must be getting rid of them and so I got one with a 15% off coupon... so I got it way cheaper than a normal one... I would have paid a few extra bucks for the ib modified, but not $50.... if you can't find one I would say just get a normal one they are still very good pedals... I am not sure how much the noise mods actually do anyways.
