Old June 4th, 2012, 03:58 PM   #1 (permalink)
ToneShark's Avatar
Everyone stop what you're doing and locate your nearest EP Booster!
Seriously. Best $120 or so I've ever spent on a pedal, probably. With a Tele, it's a no-brainer. Does a great job of fattening things up ever so slightly. It's a great always-on pedal to put in the front of a pedalboard, or even by itself into the amp. I run mine with the knob all the way down, which is just a slight bump over unity, and it's amazing how much better I've felt about my sound and playing the last few gigs with it.
I never, ever thought I'd find something that does this slight boost/sweetening thing as well or better than my Klon for anything but stupid money, but it turns out I was wrong. And now I get to use my Klon as a solo boost instead of an always-on clean boost, which is an added bonus.
Originally Posted by cnote View Post
Good lead player gets the girls...sometimes. Good rhythm player gets the gig and the paycheck...everytime.
ToneShark is offline   Reply With Quote
Old June 4th, 2012, 04:13 PM   #2 (permalink)
Looks like my board, which also has a Klon (almost the exact same settings) and an EP Booster (knob turned all the way off). Love 'em both. Nowadays the EP Booster is the one to get. Affodrable, simple and it sounds great!
Teleglide is offline   Reply With Quote
Old June 4th, 2012, 04:14 PM   #3 (permalink)
stevieboy's Avatar
That's not too hard to do, they generally have them at Guitar Center even.
Great pedal, the only one I use--but I have tried it with some different ODs and it worked very well with each of them. It just occurred to me one day, "Wait a minute, I don't really need an OD, the EP Booster is fine by itself!"
"... I'm gonna show you the inside of me." Albert Collins
stevieboy is offline   Reply With Quote
Old June 4th, 2012, 04:28 PM   #4 (permalink)
Already did. Then I sold it.
I wasn't anywhere near as taken
with the EP boost as others.
I've since built two versions of
the Madbean Fat Pants EP pre-amp
style booster. The FP is what I was
hoping the EP would have been.
Now back to your program already in progress.
Dr. Pants is offline   Reply With Quote
Old June 4th, 2012, 05:07 PM   #5 (permalink)
artdecade's Avatar
Dr. Pants and I are on the same page. It was kind of a "Meh Experience" after all of the hype.
artdecade is online now   Reply With Quote
Old June 4th, 2012, 08:10 PM   #6 (permalink)
Rich_S's Avatar
I haven't tried the EP, just because it's more money thatn I'll spend for a non-exssential. I built a Fat Pants with a 3-position EQ switch.
"This is not acceptable behavior in a jazz club." - Mark Gane
Rich_S is online now   Reply With Quote
Old June 4th, 2012, 08:30 PM   #7 (permalink)
MASONish's Avatar
Agreed on the EP. If you love it try a Voodoo Lab Giggity. This is "the one" to get. Very very versatile preamp.
MASONish is offline   Reply With Quote
Old June 4th, 2012, 09:42 PM   #8 (permalink)
gtrguru's Avatar
I love my EP Booster.
-Music is only heard by those that listen.
gtrguru is offline   Reply With Quote
Old June 5th, 2012, 12:28 AM   #9 (permalink)
TB72's Avatar
Had one of the early models, and sold it. I wanted to use it for a solo boost, but even with the knob at minimum, it was too much of a volume bump.
The newer ones will do unity gain at minimum settings, so I picked up another one. I'm enjoying it a lot more now.
Later...
Why is easy-listening music so hard to listen to?
TB72 is offline   Reply With Quote
Old June 5th, 2012, 07:13 AM   #10 (permalink)
Lance's Avatar
I also started with the first version and traded to a new unity gain model. It's always on....just makes the amp sound better. Mine is last in the chain before the amp.
Lance
Guitar Gear FAQ: Blog Facebook Page Twitter Page
Old June 5th, 2012, 08:06 AM   #11 (permalink)
schenkadere's Avatar
How does it work with humbuckers?
Guitar>Boss ST-2 Power Stack>Vox Time Machine Delay>Amp
My music page:
http://www.soundclick.com/schenkadere
schenkadere is offline   Reply With Quote
Old June 5th, 2012, 08:34 AM   #12 (permalink)
Lance's Avatar
I have a bunch of different guitars (gibson/gretsch/fender/prs)....it doesn't seem to make a difference. They all sound better. It's a high frequency response thing...the EP seems to take wool off your signal and make it crystal clear....but not in a harsh way.
So, I use mine for a slight boost to add clarity. There may be difference between single coils/humbuckers when using it for a higher level of gain.
Lance
Old June 5th, 2012, 08:50 AM   #13 (permalink)
blowtorch's Avatar
Don't have a EP Booster, but I love my Nocturne Atomic Brain!
blowtorch is online now   Reply With Quote
Old June 5th, 2012, 08:55 AM   #14 (permalink)
Tomlin_Guitars's Avatar
Most single JFET boosters will do the same thing. I built a kit from General Guitar Gadgets of a Stratoblaster booster and it does the exact same thing as the EP booster as far as my ears can tell. The kit is only $38 but you must build it yourself but it was a relatively simple and quick build.
Tomlin_Guitars is offline   Reply With Quote
Old June 5th, 2012, 09:00 AM   #15 (permalink)
Lance's Avatar
Axis29 has one. Great pedal....but different than an EP. It's much more aggressive and gritty.
Lance
Old June 5th, 2012, 09:01 AM   #16 (permalink)
Lance's Avatar
Yeah....I know what you're saying. This is somewhat different. There's some EQ stuff happening in the EP beyond the boost part.
Lance
Old June 5th, 2012, 09:11 AM   #17 (permalink)
JohnK24's Avatar
Unless you play through a VERY bright amp, I'd say no. I had v2.0 of the EP Booster and even with the treble boost internal dip switch "on", the pedal added too much bass to my P90 Les Paul (into a Hot Rod Deluxe) this was with the external knob set around 9 o'clock. It adds a really nice 3D shimmer to teles and if I had the Hot Rod working with the bright switch "on" and the bass rolled back to around 9 o'clock, the EP Booster was great.
I returned mine, doesn't couldn't deal with the bass boost...if they would give you the option to limit the bass boost, this would be a really cool pedal. I emailed Xotic and asked if version 1 would be better as it has an internal switch for bass boost on/off. I was told, no, version 2.0 is designed as having the bass boost "off". So....a bright Vox or fender black/silver faced amp and a thinner sounding tele/strat...this would be a great pedal. imho
JohnK24 is offline   Reply With Quote
Old June 5th, 2012, 10:12 AM   #18 (permalink)
I was curious about the giggity..especially the voicing and dynamic eq...hard to voice properly neck p/u with most preamps...out there..
A person who won't read has no advantage over one who can't read.....
Mark Twain
uriah1 is offline   Reply With Quote
Old June 5th, 2012, 11:22 AM   #19 (permalink)
dalandan's Avatar
EP is for realz
dalandan is offline   Reply With Quote
Old June 5th, 2012, 11:48 AM   #20 (permalink)
Modern Saint's Avatar
Love mine!
~Go For What You Know!~
~There are no bad notes, just bad resolutions! - RLH~
~Make Everyday Your Masterpiece. - John Wooden~
Modern Saint is offline   Reply With Quote
