Old May 27th, 2012, 01:13 AM   #1 (permalink)
PeteMac's Avatar
Looper pedals - The more I learn, the less I understand !
I'm thinking I may need a looper. It's for live applications with a 3 piece band.
I want it simple. . . I want to be able to play a riff or whatever on stage and have the pedal play that back over and over . . . simple.
But, now I'm hearing about using click tracks on stage so the drummer can be in the same tempo as the loop !? Is that right ?
I thought if I was playing in time with the drummer and recorded the phrase I wanted to loop at that same tempo, then it should play back, and loop, at that tempo ?!
How does it work?
Are some pedals different than others ?
"Find what you like . . . and let it kill ya . . ."
(Kinky Friedman)
www.myspace.com/theboneyarsedboys
PeteMac is offline   Reply With Quote
Old May 27th, 2012, 01:23 AM   #2 (permalink)
Just turn off the click track. Play along to the drummer's groove.
Warren Pederson is online now   Reply With Quote
Old May 27th, 2012, 01:29 AM   #3 (permalink)
PeteMac's Avatar
That's what I was hoping to hear. Thanks Warren.
The way it was explained to me, if you don't have the pedal set to a tempo it won't know where the loop finishes to be able to start it again at the right place.
(Kinky Friedman)
Old May 27th, 2012, 01:39 AM   #4 (permalink)
MonkeyKing's Avatar
Yeh, they`re different - usually you step on another button to close the loop - some have the tap tempo too that you set right on the spot. He doesn`t always play guitar, but that Andrew Bird does some pretty cool things with them - might give you some ideas. Or you might want to get a sampler.
MonkeyKing is offline   Reply With Quote
Old May 27th, 2012, 02:04 AM   #5 (permalink)
How would a sampler help the OP?
Old May 27th, 2012, 02:20 AM   #6 (permalink)
PeteMac's Avatar
Would one of the Boss RC pedals do what I want? Just a simple loop of a phrase or riff on the fly ?
(Kinky Friedman)
Old May 27th, 2012, 08:33 AM   #7 (permalink)
Hey Pete, look into the Boss RC-20 XL. The newer versions have come out, so the used prices on these should be dropping.
Great pedal, it will change the way you play guitar
mal paso is offline   Reply With Quote
Old May 27th, 2012, 11:16 AM   #8 (permalink)
AJBaker's Avatar
My advice is always to use a looper with two pedals, or the option to plug in a second switch.
AJBaker is online now   Reply With Quote
Old May 27th, 2012, 01:49 PM   #9 (permalink)
fly135's Avatar
What you were hoping to hear isn't correct IMO. Setting the looper to a tempo is for quantizing to a click or drum track. If you are playing with a drummer he needs to sync to the looper, or the error will accumulate every loop.
The start and end to a seamless loop is all in the pedal press. Quantize doesn't fix that. Quantize ensures the click and loop stay in sync. If you have no click or tempo then quantize means nothing.
**** Tasty Licks **** A collection of my songs.
fly135 is offline   Reply With Quote
Old May 27th, 2012, 02:59 PM   #10 (permalink)
nic'o'caster's Avatar
Your drummer will need a clicktrack or a wedge monitor with your loop very audible !
nic'o'caster is offline   Reply With Quote
Old May 28th, 2012, 03:18 AM   #11 (permalink)
PeteMac's Avatar
I was prepared for having the guitar fairly prominent in the drummer's monitor ( even if it means running a second, small amp for him to use as he wishes.)
That's how I thought it would work; he plays the tempo, I play the guitar riff to match and then loop it; he continues to hear the loop in his drum "monitor" and keeps locked to that. As long as I can get the hang of hitting the footswitch just right all should be swell ? . . . no?
Thanks for all the replies so far fellas. I've learnt more here in a few posts than I had in all the time I've spent in stores and on product websites.
Thanks
(Kinky Friedman)
Old May 28th, 2012, 06:38 AM   #12 (permalink)
GigsbyBoyUK's Avatar
Pete your first paragraph above is the right way to do it... but it is still difficult in reality for this to work. I've tried it and it seems to be hard for a drummer to play along with a loop and not get lost, what with the other stuff going on in the band, even if the drummer has the loop sound loud in a monitor.
But hey, try it and you may find it all works out well - be prepared for quite a bit of trial and error though.
GigsbyBoyUK is offline   Reply With Quote
Old May 28th, 2012, 06:57 AM   #13 (permalink)
In terms of units I would recommend the digitech Jamman Stereo.
Look forward to hearing how you get on, I am hoping to get the guys I play with in to a loop for background rhythm while I solo (3 piece as well)...
Mad Kiwi is offline   Reply With Quote
Old May 28th, 2012, 08:20 AM   #14 (permalink)
greggorypeccary's Avatar
Great idea in theory, but if the band gets a little off from the loop you'll sound horrible. IMO, more trouble than its worth.
Put a glide in your stride and a dip in your hip and get onboard the Mothership.
greggorypeccary is offline   Reply With Quote
Old May 28th, 2012, 08:35 AM   #15 (permalink)
Syclone879's Avatar
+1
Every drummer I've played with has had trouble staying in sync with a loop pedal. I haven't figured out how to make it work.
Syclone879 is offline   Reply With Quote
Old May 28th, 2012, 09:21 AM   #16 (permalink)
Big John Studd's Avatar
I use loopers mostly for practice, and I have found that it's pretty difficult to "close the loop" seamlessly without using the quantize feature. I can get pretty close, but usually I can still tell it's a little off. I think it would be hard to nail it in a situation with other live performers without using a click. Not impossible, but I bet it would take a lot of practice and becoming one with your looper. It would also depend on the length and number of repeats in the loop...if it is a short one/two bar riff that repeats a couple of times then the synchronization of the loop may not be as critical as say a loop that goes for a substantial length of the song.
Big John Studd is online now   Reply With Quote
Old May 28th, 2012, 09:45 AM   #17 (permalink)
I stopped trying to use the looper when there's a drummer unless I use it as a texture maker, but for voice guitar duets it's my handy second guitar player !
Old May 28th, 2012, 03:13 PM   #18 (permalink)
Not sure if this will be of any help. But as someone mentioned above, Andrew Bird uses one a lot, maybe even most songs. With a violin and electric guitar. And - here's the interesting thing - his drummer uses one too. I don't know how they pull it off, but it would be worth looking into.
For starters, they are both really talented musicians. Martin Dosh, the drummer, actually uses two loopers live. But he plays one or two keyboards along with drums so maybe one looper is for keyboards. I talked to him about the loopers five years ago and had the chance to watch their soundcheck and talk to him again a couple of weeks ago when they played in Detroit. He's still using the same looping devices. An Akai Headrush and an EHX 2880. Andrew Bird is still using a Line 6 DL-4.
I've never noticed them having timing issues so it can be done. Maybe playing together for years helps.
tele-vangelist is offline   Reply With Quote
Old May 29th, 2012, 09:09 AM   #19 (permalink)
PeteMac's Avatar
Thanks guys. This is all useful info. Sounds like it may be more trouble than it's worth.
The three piece thing is coming together a lot better now, so hopefully the looper won't be necessary !
(Kinky Friedman)
Old May 29th, 2012, 09:24 AM   #20 (permalink)
Pete, don't give up just yet.
It's nowhere near as much trouble as these guys are making it out to be! I've used a looper with a drummer, I've used a looper with another guitarist using a looper. It's really not that hard. As long as you master when to turn loops on and off, which is basically just accurate timing, it's easy.
Maybe difficulty depends on length of loop, or complexity of the pedal? I use a dual footswitch and find it quite easy to use. And for loop length, that depends on the style of music, but you could just play a measure, loop it, solo over it, and then turn the loop off.
