MXR carbon copy help
I just picked up a carbon copy delay today. I started messing around with it using long delay times but when I try to do short and fast it just feeds black like crazy.
What am I doing wrong here? I was trying to play Police Truck by the DK but i can't even get the delay close. |
The pedal oscillates if the feedback is set too high, especially with shorter delays. Try starting with the feedback low, and then turning it up.
Edit: By feedback, I mean the regen knob, sorry for this.. Last edited by vagstad; May 12th, 2012 at 01:36 PM. |
#7 (permalink) | |
That sounds faulty if it's feedbacking at that setting. You should probably return it if you can't get it to work. I'd recommend getting a ehx memory toy if you don't want to try the CC again. Exact same specs and controls, and I haven't had any problems with mine. Good luck!
#10 (permalink) | |
I'm on my way out to the shooting range. But when I get home I will post the results |
