Old May 8th, 2012, 11:06 PM   #1 (permalink)
Ecadad's Avatar
Need a boost?
I've been looking at the MXR Micro-Amp, but I;m not sure exactly what it will do. I know that Jack White uses one. So what does it sound like or do?
When you're playing a Stratocaster you’re being an average guitar player. When you’re playing a Les Paul you’re showing off. When you’re playing a Telecaster you’re perfect.
Ecadad is offline   Reply With Quote
Old May 9th, 2012, 08:37 AM   #2 (permalink)
lefty73's Avatar
It's a small boost. :)
Basically it's a like a preamp - it bumps up your signal volume, and when really cranked up it can generate it's own overdrive. That said, in my opinion, it's definitely not meant to replace a distortion or overdrive pedal.
There's a couple of uses for them:
You like loud amps but want a little "more" for solos or heavier passages. Stomp on the Micro Amp when you want more grind.
You like to use pedals but want a little "more" at times. Put a Micro Amp in front of an overdrive or distortion pedal and stomp on it to get more gain and sustain. Or, put the Micro Amp after the overdrive/distortion pedals and get a volume boost for solos. Stomp on the MA for a solo, stomp it off to go back to your rhythm tone.
You have a ton of pedals and you're worried about or are definitely hearing a loss of signal strength or volume when you're plugged into your pedal board. Putting a Micro Amp near or at the end of a long pedal chain can help reclaim lost volume and sparkle.
- Joemeek floorQ>Boss BF-2>Fulltone OCD>Fulltone GT-500>MXR Carbon Copy>Boss DD-5>EHX Hum Debugger
- OCD replier to zero-reply topics on Page 1 of TDPRI's The Stomp Box
lefty73 is offline   Reply With Quote
Old May 9th, 2012, 08:52 AM   #3 (permalink)
clayfeat's Avatar
Originally Posted by Ecadad View Post
I've been looking at the MXR Micro-Amp, but I;m not sure exactly what it will do. So what does it sound like or do?
Boosts the signal to make your sound hotter. More feedback and volume. Step on mine for solos. Having just the one knob makes it easy to turn up and down with the toe of your shoe. I set my amp to right at the break up point. Use the Micro Amp to push it over the top.
Highly recommend it.
clayfeat is offline   Reply With Quote
Old May 9th, 2012, 08:59 AM   #4 (permalink)
Originally Posted by lefty73 View Post
It's a small boost. :)...
This. I use mine near the end of the chain after everything except reverb and set it just past noon. This setting is a great solo boost without altering your tone much at all. It also works great if you find that you run your dirt pedals are a little hotter than your clean tone, step on the Micro Amp and you get a very nice clean signal boost.
_______________
MIM Strat / Agile AL-2000 > Korg Pitchblack > Boss CS3 > Fulltone Fulldrive 2 Mosfet > Fulltone OCD > Morley Volume Pedal > Line6 DL4 > MXR Micro Amp> TC Hall of Fame > Frenzel FM-5E3 Deluxe Plus
mrothe is offline   Reply With Quote
