Inatall a Foot Switch
It's an anchient MXR 6 band EQ (70's). I bought it new and it still works perfectly, but it was battery only and has no on/off switch.
With TDPRI members help I successfully eliminated the battery and got a power jack installed. Now I would like to install a foot switch. There is room for it where the battery used to be, and I see that Small Bear Electronics has them: http://www.smallbearelec.com/Categor...ches%2C+Relays I'm assuming the first one on that page would be the one to use? I just need a wiring diagram for hooking up the switch. Any ideas where I could find that? Thanks, Jeff
Huntin, Fishin, NASCAR & Country Music - Life's Good! https://www.facebook.com/ATCoBand Last edited by OlRedNeckHippy; April 10th, 2012 at 10:37 AM. |
Edited for clarity.
Huntin, Fishin, NASCAR & Country Music - Life's Good! https://www.facebook.com/ATCoBand |
Thanks PT. Wow. A vertual plethora of info on the 3PDT wiring. I especially liked the 3D images.
Small Bear offers this item I just discovered: PC Wiring Board For 3PDT Switch http://www.smallbearelec.com/Detail.bok?no=870 Which it seems would attach directly to the switch and your wiring would attach to it. Seems simple enough....
Here is a wiring diagram with Led-indicator,true bypass and the input will be grounded in the "off" position.
http://www.generalguitargadgets.com/..._tb_gi_dcj.pdf |
Wow! That is Perfect Limbe! Thank You!!
I'm sure I'll have more questions, as for this project I had to go buy a soldering iron......that tells you my level of experiance. But I did build a 100 watt Heathkit Sterio back in the 70's, with my dad, so technically it's not my first ever electronics project. Already have a question: Can you direct me to where I can purchase the LED Indicator and resistor (as indicated in the wiring diagram linked to above)? Can't seem to find the complete kit at Small Bear or G G Gadgets.
Huntin, Fishin, NASCAR & Country Music - Life's Good! https://www.facebook.com/ATCoBand Last edited by OlRedNeckHippy; April 10th, 2012 at 08:31 PM. |
