Old March 25th, 2012, 10:08 PM   #1 (permalink)
fulldrive-like pedal that cleans up better?
Hey I'm looking for a pedal that sounds like a fulldrive and has two seperate channels but that cleans up better when the pedal's overdrive is set all the way to zero, and that has a seperate volume control for each channel.
Any suggestions?
klasher is offline   Reply With Quote
Old March 26th, 2012, 12:56 AM   #2 (permalink)
Teleworshipkid's Avatar
Two tube screamers!
Teleworshipkid is offline   Reply With Quote
Old March 26th, 2012, 02:17 AM   #3 (permalink)
Nub
Check out the CMATMODS Super Signa Drive... it's an independent OD & boost:
http://cmatmods.com/super-signa-drive.html
If you want a second OD instead of a boost, I'm sure Chad could put 2 Signa Drives into one enclosure for you. He makes killer pedals, and is great to deal with.
Nub is offline   Reply With Quote
Old March 26th, 2012, 02:29 AM   #4 (permalink)
tjalla's Avatar
My non-stacking Menatone Fish Factory does this, hard to come by but their custom shop will build one for you.
Rodenberg make TS variants with flexible switching.
Two ts9s with a looper switcher isn't a bad way to go.
tjalla is offline   Reply With Quote
