Old March 18th, 2012, 12:10 AM   #1 (permalink)
slap dat's Avatar
Any love here for the Fulldrive II Mosfet?
I purchased a Fulltone Fulldrive II Mosfet today on the advice of a much respected player/friend and I am quite simply blown away. In 30+ years of playing, this is the best overdrive tone I have found.
Any love (or otherwise) for it here at TDPRI?
Looking for my missing piece of mind ...
http://www.myspace.com/robertflury
slap dat is offline   Reply With Quote
Old March 18th, 2012, 05:23 PM   #2 (permalink)
Just-Jim's Avatar
I think a lot of people here would agree that the Fulldrive is a great pedal. I had one but no longer do, but not because it was not any good. I just wanted something different. Many people feel it's best OD out there. I am awaiting my Timmy and curious to see how it matches up with the Fulldrive.
Just-Jim is offline   Reply With Quote
Old March 19th, 2012, 11:34 AM   #3 (permalink)
I am very happy with the sounds of this pedal.
The only thing I still find puzzling is the boost switch which doesn't make any difference in that direction. So you still need to use another pedal as a booster.
If this pedal would have been the size of a standard BOSS pedal it would have been perfect.
pinkfreud is offline   Reply With Quote
Old March 19th, 2012, 11:48 AM   #4 (permalink)
Love it, i have the Anniv Edition in Red. Really great sound, it just ROCKS!
I have the OCD as well, between the two i'm always satisfied and am constantly tweaking and playing with them.
Congrats on a great buy!
phblues is offline   Reply With Quote
Old March 19th, 2012, 04:45 PM   #5 (permalink)
Hey phblues,
How is the Fulldrive working together with the OCD?
I'm thinking to buy an OCD to use it as a pedal for solos.
Old March 20th, 2012, 10:43 PM   #6 (permalink)
Jay Isler's Avatar
I like mine but I primarily use it with just a touch of gain to boost my MPH 72 degrees and Marshall Blues Breaker.
Jay Isler is offline   Reply With Quote
Old March 21st, 2012, 12:52 PM   #7 (permalink)
Cooper Black's Avatar
NC, United States 03/21/2012 8:20 A.M. Out For Delivery
Cooper Black is offline   Reply With Quote
Old March 21st, 2012, 01:22 PM   #8 (permalink)
ruger9's Avatar
The FD2 PRE-mosfet is my favorite OD of all-time. Didn't get on with the mosfet version, it's quite a bit brighter than the pre-mosfet, too bright for me. (still a very good OD).
Old March 21st, 2012, 04:26 PM   #9 (permalink)
boost button
The boost switch certainly boosts on mine. What do you mean it doesn't make any difference? You are aware that the boost only works when the overdrive is on aren't you?
Fear less, hope more; Eat less, chew more; Whine less, breathe more; Talk less, say more
Steve McGinnis is offline   Reply With Quote
Old March 21st, 2012, 06:39 PM   #10 (permalink)
Teleworshipkid's Avatar
I have an FM Push-Pull and I actually find it too dark. I love the clipping, just not the EQ-ing. So I'm probably going to make the switch to MOSFET soon.
Teleworshipkid is offline   Reply With Quote
Old March 21st, 2012, 07:04 PM   #11 (permalink)
ruger9's Avatar
You'll probably love it!
Old March 21st, 2012, 07:23 PM   #12 (permalink)
e44crowe's Avatar
I love my fulldrive2 MOSFET. I use it with the mosfet switched on and the other switch in vintage mode most often. The boost isnt much but it definitely does just what it says. I will typically have the boost set pretty far over clockwise and will use it when I'm playing an already crunchy part and the next part needs just a bit more oomph. The boost is not like a whole other gain stage, it is just a bit more what ya already have. Great pedal that plays well with both humbuckers and single coils.
diff'rent strokes for diff'rent folks
e44crowe is offline   Reply With Quote
Old March 22nd, 2012, 09:09 AM   #13 (permalink)
I just has to do with where the BOOST section is placed inside the FD2. It comes before the main OD section, so it pushes into the OD, creating more volume and more dirt.
If it were after the OD section it would add volume, but not any more dirt--which really could be great for pushing your amp into its own OD, but the FD2 doesn't work that way.
The catch is, you really can't push the OD any further than it already goes at 12:00 on the DRIVE dial. If you have dimed the DRIVE, the BOOST is effectively negated because it simply has nowhere to go.
Per the current TDPRI protocol, I have nothing more to say until my cooling-off period has expired.
Old March 22nd, 2012, 09:44 AM   #14 (permalink)
Jakedog's Avatar
Love the FDII Mosfet. Some say it's too bright, I never found that to be the case, even with bright amps, and I don't really like bright tones.
I find the original FDII to be a little muddy by compasrison. I think the Mosfet is "cleaner" sounding for lack of a better word. Better note definition and clarity. But not bright. It certainly can be, if you set it up that way, but it doesn't have to be unless you want it to.
The boost, is a gain boost, not a volume boost. I like it.
I run mine in line with some other boxes, so I have several cascaded gain stages to use alone, or in combination with one another.
First in line I have a BBE Boosta Grande clean boost. Then the FDII Mosfet, then an OCD. The different combos available are fantastic.
I bought my FDII Mosfet about four or five years ago. I liked it ok, but it didn't really knock me out, so I sold it to a friend. He never used it. I went through a butt load of OD pedals trying to find the "right" one for me. Eventually, I bought back my FDIIM, thinking I'd try it again. I loved it from the word go, and haven't looked back in almost two years now. DOn't know why i wasn't totally tickled with it the first time out, but ever since I got it back, it's been teenaged, weak in the knees, stars in my eyes, love love love. I'm not sure I could live without it.
It's not a mini-van, it's a manly van, and it's awesome.
Jakedog is offline   Reply With Quote
Old March 22nd, 2012, 10:09 AM   #15 (permalink)
paulvcarter's Avatar
Yes I love mine.
Keep Calm, Ramble On
Band: www:theprudes.com
Gear: Danocaster Tele, Fender B bender tele, Brian May Super, Les Paul Custom, Atelier Z Stratocaster, Eric Clapton Strat, PRS CE24, Vox AC30, Fender Vibro Champ EC.
paulvcarter is offline   Reply With Quote
Old March 22nd, 2012, 12:22 PM   #16 (permalink)
11 Gauge's Avatar
Originally Posted by Cooper Black View Post
It just has to do with where the BOOST section is placed inside the FD2. It comes before the main OD section, so it pushes into the OD, creating more volume and more dirt.
The boost function in the FD isn't really a boost at all.
It does not come before the main OD section.
The FD is merely a tweaked TS/SD-1 - there is only one OD section.
All that the boost function is with the FD is a second switchable drive/gain control - it simply toggles between a setting of more or less overdrive.
For a slick low tech "boost" function, a combination of different clipping diodes that compress/limit the signal less would have worked better IMO, but then you have these issues of the mosFET version being too bright, original blue being too muddy, etc.
...Because that is ALL that the mosFET function is - a different combination of clipping diodes that gives a bigger threshold before clipping occurs (what is called the "forward voltage" of the diodes before they start affecting the signal). The transistors IOW aren't even used as transistors (mosFET's have internal "body diodes").
Something that is similar to the mosFET setting is any TS that has a switch that lets you select LED clipping diodes - you get a huge boost because those diodes compress and limit so much less. The mosFETs and other diodes in the FDII have a "threshold" that is somewhere in between the one that the "old blue" had, and what a pair of LED's has.
Don't get me wrong - the FDII is a cool pedal, but the boost and mosFET settings are really misunderstood by a lot of users. This isn't the user's fault, because their description is either misleading or doesn't describe anything definitive at all. What is a "mosFET mode" supposed to mean, seriously? I suppose there could be a "germanium mode."
Old March 22nd, 2012, 05:10 PM   #17 (permalink)
ruger9's Avatar
it.
I'm not saying it's TOO bright, just quite a bit brighter than the pre-mosfet version, making it too bright FOR ME.
Old March 29th, 2012, 01:53 PM   #18 (permalink)
I've been playing around with the BOOST vs OVERDRIVE lately and have noticed something cool (I think).
When I'm using my volume knob to control gain, the BOOST allows me to "boost" into overdriven-tone-range even when I'm rolled back pretty far on the volume knob.
That is ... if I've already rolled back into clean-tone-range using my volume knob, with OVERDRIVE engaged, I can move from there into overdriven tones at the same volume-knob spot by hitting the BOOST.
It sounds thicker and better to my ear than if I had simply rolled up the volume knob, or set my initial gain higher on the OVERDRIVE channel and rolled back from there.
So, even as just another gain control, it does seem to allow me to reach new tonal areas.
I'd love to hear any "why" explanations for the tone changes I'm hearing.
Cool pedal.
