boost pedal=more volume?
So does a boost pedal make more volume come out of your amp than normal?
With the pedal more volume than without?? Hmmm??? |
The pedal boosts(amplifies) the signal being sent to the amp. The more signal hitting the amp, the more volume comes out. The extra signal also can push the tubes into overdrive.
Things I've learned over the years. NEVER eat anything cheaper than dog food. Every day above ground is a good one. It's easier to get into jail than out. |
#5 (permalink) | |
If it is before any overdrive or distortion it may add gain, but the volume ceiling of the pedal after will determine how much louder it will sound. Whatever is last in the chain has the "final word" as it were... |
I recently purchased a Boosta Grande pedal; a clean boost. It's very cool. It retains the amp's signal very well; keeps all the dynamics of the amp in tact and just adds volume until you turn up the knob some, then it overdrives the amp beautifully.
#8 (permalink) | |
#9 (permalink) | |
Most solid state amps will NEVER break up - at least, not in a good way... |
It really depends on how you set your amp as well as its size. If you set it clean then it'll take more pedal knob turning. If you set your amp dirty then kick in the boost pedal you won't have to turn it as much. The pedal adds a substantial amount of volume though.
#12 (permalink) | |
I recommend going to a store and checking some out for yourself so you can judge how much power you need and what sounds good to you. I love my amp but you may not like it. |
#14 (permalink) |
It's all about the amp's headroom. If you take a boost pedal, put it at the end of your pedals, and hit the front end of the amp with a boosted signal, different amps will react differently.
For example, when I owned an AC15, my boost pedal pushed the amp into a natural overdrive, along with increasing the volume a bit. Now that I have an AC30, it's mostly just a volume increase. Certainly a little volume but not as much as before. It also depends on where the boost is in your chain. If you run your boost in front of your distortion pedals, it will just hit those harder but your overall volume will determined by the pedal you're running into. Basically, I look at it as this: If you want a gain boost, boost goes before any drive pedals. For a volume increase, it should be last in line. Hope this helps! |
#15 (permalink) | |
If your trying to get your amp turned up to max to get louder, then no, it probably won't work. Chances are you'll just get more compression and distortion. With a tube amp, boosters are useful for finding a sweet spot at different volumes, and getting different kinds of overdrive. For example, a turned up booster will get you more pre-amp gain. |
#17 (permalink) | |
I guess I've never really used a dimed amp as my main tone, because I'd have figured that out years ago. And I've never had an amp thay had the "right" amount of overdrive. It was either not quite enough(BF Tremolux) or way too much(a lot of amps I've owned actually). Having an amp now that does is cool. Clean to crunch lies between 6 and 10 on my guitar's volume knob. But there's the fine line between totally clean and kinda clean. |
