Old January 18th, 2012, 01:52 PM   #1 (permalink)
ADinNYC's Avatar
Recommend a Boost Pedal please
I just need something to kick up the volume a little during solos.
A boost goes at the beginning I presume?
Here's what I'm running.
Boss TU3 Tuner
Wampler Ego Compressor
Wampler Paisley Drive
Hardwire CR-7 Stereo Chorus
BBE Sonic Stomp
Wampler Faux Analog Echo
Hardwire RV-7 Stereo Reverb
Thanks
He said to the music store clerk - "Do you have a pedal that makes it sound like I'm plugged straight into my amp?"
ADinNYC is offline   Reply With Quote
Old January 18th, 2012, 01:53 PM   #2 (permalink)
FMA
This comes up regularly and like clockwork, you'll get the usual list of suspects. Of course, my usual is the Boosta Grande.
Check out my new novel, Don't Be Cruel, here.
FMA is offline   Reply With Quote
Old January 18th, 2012, 02:01 PM   #3 (permalink)
Charlie Davis's Avatar
Fatboost, Catalinbread Super Chili Picoso, and Pigtronix Class A Boost.
Depends on if you want something that is just for volume, driving an amp, or adding a gain boost.
Charlie Davis is offline   Reply With Quote
Old January 18th, 2012, 02:23 PM   #4 (permalink)
Solo sustained lead...analogman OD808 (silver upgrade)
Solo louder - (any booster)
"Guitar>stomps>Amp"
uriah1 is offline   Reply With Quote
Old January 18th, 2012, 02:26 PM   #5 (permalink)
Brandon mac's Avatar
the boosta grande!!! it gives you your sound, just louder/more. can be had for a song used too.
MIM FSR BSB tele with reversed control plate with forrest lee jr. b bender>boss-tu-2>wampler paisley drive>modded ts-9>rockett animal>ego compressor>boss super chorus>pepperoni phaser>tuna melt tremolo>Wampler Analog Echo>Boss DD-6>Dr.Z Maz 38sr 212.
Brandon mac is offline   Reply With Quote
Old January 18th, 2012, 03:30 PM   #6 (permalink)
TB72's Avatar
Boss TU3 Tuner
BBE Sonic Stomp
Thanks
If you're looking for a volume boost for solos, place the boost after your gain pedals (comp and overdrive in your case). Placing the boost before them in your chain will give your gain pedals more grit and sustain (which can be a good thing), but you won't get much of a volume bump.
As for which booster, there are many good ones to choose from. I have a few that I use, depending on my needs (and my mood, for that matter). They are:
-Xotic RC Boost
-Xotic EP Boost (nice option if you don't have much space left on your pedalboard...doesn't take up much room at all)
-Homemade double boost. (two Jack Orman mosfet boosters in one box...similar to a Zvex Super Duper)
Later...
Why is easy-listening music so hard to listen to?
TB72 is offline   Reply With Quote
Old January 18th, 2012, 03:37 PM   #7 (permalink)
PraiseCaster's Avatar
I use a BBE Boosta Grande and am very happy with it!
PraiseCasters G1 using TDPRI App
Later!
PraiseCaster
Guitarists Praise and Worship Forum!!, My Facebook,
Incident Sound
PraiseCaster is offline   Reply With Quote
Old January 18th, 2012, 03:52 PM   #8 (permalink)
schenkadere's Avatar
Boosta Grande!!!
Jackson Soloist Archtop>MXR Dyna Comp>Ibanez JD9 Jet Driver>BBE Two Timer Delay>Peavey Transtube 112 EFX
My music page:
http://www.soundclick.com/schenkadere
schenkadere is offline   Reply With Quote
Old January 18th, 2012, 04:07 PM   #9 (permalink)
ce24's Avatar
couple of ways....MXR micro amp or a graphic eq set flat but boost the vol slider.....
ce24 is offline   Reply With Quote
Old January 18th, 2012, 04:16 PM   #10 (permalink)
T Prior's Avatar
well this will definitely get the job done..maybe more than definitely...
www.tprior.com
T Prior is offline   Reply With Quote
Old January 18th, 2012, 04:22 PM   #11 (permalink)
gwjensen's Avatar
Xotic EP Booster. Love it. The other Xotic suggestions are good to, but more expensive... Don't know anything about the Boosta Grande, but it appears to be very popular.
gwjensen is offline   Reply With Quote
Old January 18th, 2012, 04:28 PM   #12 (permalink)
gwjensen's Avatar
Meant to add that the Boss GE-7 makes for a mighty fine boost, with the bonus of giving you a ton of EQ options. I have both, but if I had to choose, I'd probably go with the GE-7 for the added versatility.
Old January 18th, 2012, 06:48 PM   #13 (permalink)
Not trying to turn this into post your favorite pedal thread but I'm going too because out of the everything I've tried I really just like a mxr 10 band with a flat eq and just bump the level a bit. doesn't change my tone and I place it after my od's before delay and reverb. Just makes me louder doesn't push the pedals this way. didn't like it in front of the od's. But im curious about this grande?
fenderdfs is offline   Reply With Quote
Old January 18th, 2012, 07:03 PM   #14 (permalink)
EP booster works for me!
Vox66 is offline   Reply With Quote
Old January 18th, 2012, 07:07 PM   #15 (permalink)
bossking7's Avatar
+1 the class a boost is great but the ge7 is better and has a volume slider
bossking7 is offline   Reply With Quote
Old January 18th, 2012, 07:44 PM   #16 (permalink)
Frank B's Avatar
Was using an mxr micro amp that was good, I now use a Suhr Iso Boost which is amazing.
Frank B is offline   Reply With Quote
Old January 18th, 2012, 09:04 PM   #17 (permalink)
It's a clean boost, right? For the price difference, what makes the Suhr that much better than the MXR...just curious.
My music page:
Old January 18th, 2012, 10:47 PM   #18 (permalink)
studio1087's Avatar
BBE Boosta Grande
John
"The rock and roll business is pretty absurd, but the world of serious music is much worse." - Frank Zappa
Old January 18th, 2012, 11:17 PM   #19 (permalink)
Lefty138's Avatar
another vote for the boosta grande
Lefty138 is offline   Reply With Quote
Old January 18th, 2012, 11:19 PM   #20 (permalink)
telefunken's Avatar
Keeley Katana Clear Boost
AT THE END OF THE CHAIN!!!!!
Lord, protect me from my friends; I can take care of my enemies. --Voltaire
telefunken is online now   Reply With Quote
Old January 18th, 2012, 11:20 PM   #21 (permalink)
valvestate's Avatar
Basically any pedal labeled boost will get you there.. it's just a matter how much are you willing to shell out.
I'm personally using a Visual Sound True Tone Clean Boost after all my effects (last in my chain). It just makes everything loud and clear... the tone knob really works a lot as well if you need to darken up your leads in soloing. VS Support is also top notch,.. HIGHLY RECOMMENDED
Psalm 150
Praise God with strings and pipe, loud cymbals, with clashing cymbals! Let every living thing praise the LORD!
valvestate is offline   Reply With Quote
Old January 19th, 2012, 04:43 AM   #22 (permalink)
Dave_O's Avatar
What he said, but with an EQ stompbox- (GE-7 or equivalent) sometimes I pull a little (3-6db or so) of the very top and very bottom out. Usually boost the level overall by 2 notches on the volume slider (roughly 10db). Effective, and won't cost you first-born son.
My old Dad used to say-------------
"People- they're not worth the paper they're printed on."
Dave_O is offline   Reply With Quote
Old January 19th, 2012, 04:47 AM   #23 (permalink)
GigsbyBoyUK's Avatar
If it really is just a boost in volume do what I did - make a simple 'unboost' pedal with a simple volume pot. You just switch it on when you don't want the boost and off to take the pot out of the circuit when you need the boost. Costs about ten bucks to make and works like a dream.
GigsbyBoyUK is offline   Reply With Quote
Old January 19th, 2012, 09:50 AM   #24 (permalink)
ADinNYC's Avatar
Thanks for all the great advice everyone. The Boosta Grande name got thrown around so many times I think I'll give it a try.
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
