Old September 1st, 2011, 12:44 AM   #1 (permalink)
Do Solid State Reverb Units still use Springs?
I just ordered a Gibson Reverb III from the 60s and found out it is solid state and not tube. Will it still use Springs or is it different in some way? Thanks.
highwaycruiser is offline   Reply With Quote
Old September 1st, 2011, 06:14 AM   #2 (permalink)
photoweborama's Avatar
It should use springs. Only time they don't is when it's digital.
Originally Posted by photoweborama
photoweborama is offline   Reply With Quote
Old September 1st, 2011, 08:43 AM   #3 (permalink)
chrisgblues's Avatar
It's almost certainly a spring reverb unit if it's from the 60's. Either that or digital, but I am pretty sure they didn't have digital reverb units in the 60's at all...much less built into a guitar amp.
Spring units can have the signal driven by solid state or driven by tubes, but the actual units still use springs to get the reverb effect. That's my understanding.
JMHO.
The best thing you can do to increase your value as a guitar player is learn to sing. But most guitarists don't want to hear that, so we mod instead...hoping it will compensate.
chrisgblues is offline   Reply With Quote
Old September 1st, 2011, 09:11 AM   #4 (permalink)
bigp7099's Avatar
were there "digital" effects in the 60's? when i first read the op the original thought was that a "digital" reverb from that era would be as big as a fridge and run on punch cards, but then i thought about it some more and i'm not sure that would be true. so were there what we think of digital effects back then or were they all analog?
bigp7099 is offline   Reply With Quote
Old September 1st, 2011, 10:36 AM   #5 (permalink)
Digital delays and reverbs were first developed in the 1980s. So, if it's from the Sixties, it's not digital, and it has springs.
1300 E Valencia is online now   Reply With Quote
Old September 1st, 2011, 11:19 AM   #6 (permalink)
jefrs's Avatar
First electronic delay I came across (analogue) was in the 70s.
Prior to that you could have springs, tape loop, room or plate delay/reverb.
Old September 1st, 2011, 12:56 PM   #7 (permalink)
bigp7099's Avatar
how about all that stuff that keyboard players used to use in the 60's and 70's, especially the crazy atmospheric free form guys, was that digital, was it considered "effects"? if you walked into a high end studio in 1975 would they have had some hugely expensive closet sized thing that we would consider a "digital" effect?
Old September 1st, 2011, 01:08 PM   #8 (permalink)
BigDaddyLH's Avatar
Now this is a reverb!
“The problem with the world is that the intelligent people are full of doubts, while the stupid ones are full of confidence.” -- Charles Bukowski
BigDaddyLH is online now   Reply With Quote
Old September 1st, 2011, 01:35 PM   #9 (permalink)
Daddy Hojo's Avatar
I've even heard of studios having long coiled pipes under the floor to create reverb/echo effects. Like talking through a garden hose.
Daddy Hojo is offline   Reply With Quote
Old September 1st, 2011, 02:00 PM   #10 (permalink)
vjf1968's Avatar
Another type of reverb is created by a rotating drum filled with fluid. Fender had a reverb/echo unit that used this tech in the 60's
Old September 2nd, 2011, 01:24 PM   #11 (permalink)
Daddy Hojo's Avatar
For that "wet" reverb...
Old September 3rd, 2011, 06:30 PM   #12 (permalink)
jefrs's Avatar
Abbey Road had a long room the length of the studios, speakers at one end and mics at various places along it :- room reverb.
We didn't get digital until we got computer microprocessors. When was that - late 70s/early 80s ?
