Old August 2nd, 2011, 08:02 AM   #1 (permalink)
orangeblossom's Avatar
Boss DD3
Hi, I have bought a used Boss DD3 and need a power supply. It eats 9 volt batteries like crazy. What should I get.
orangeblossom is offline   Reply With Quote
Old August 2nd, 2011, 08:16 AM   #2 (permalink)
As you have discovered, digital effects suck power big time. Any regulated 9 volt power supply with the Boss-style tip should work fine. I use both the Boss PSA-120T and the Ibanez AC-109, and they both work well for powering Boss digital delays. Hope this helps.
Dr. Bill is offline   Reply With Quote
Old August 2nd, 2011, 08:48 AM   #3 (permalink)
k tone's Avatar
One Spot. Then you can power multiple pedals.
k tone is offline   Reply With Quote
Old August 2nd, 2011, 09:04 AM   #4 (permalink)
Thanks for the heads up. I appreciate the help.
Old August 2nd, 2011, 11:25 AM   #5 (permalink)
jefcon1's Avatar
I use a One-Spot with my DD-2 with no issues. Sounds the same as with the Boss PSA or even the ASA adapter. If you have any other pedals, or you WANT any other pedals, the One-Spot quickly becomes the economical choice.
jefcon1 is offline   Reply With Quote
Old August 2nd, 2011, 12:19 PM   #6 (permalink)
I use a 1-Spot into my Boss TU-2 tuner, (which has POWER IN/OUT jacks) and daisy chain to 3-4 other effects, ending with my DD-3
Tele/Tex-Mex Strat/Dano '56 U2>MHP "Stubble Trouble" FUZZ/MHP "perfected" GFS Brownie Classic/Barber Direct Drive/Blues Driver> MORE PEDALS> '68 Deluxe Reverb or blonde Blues Jr. Rock On!
Chiogtr4x is offline   Reply With Quote
Old August 2nd, 2011, 12:35 PM   #7 (permalink)
I use the one spot, all good.
mechanicdave is offline   Reply With Quote
