Vibrato effect and tremolo pedals
Not sure if i should be posting this on this thread but it does involve a pedal.
Vibrato on Fender amps - twin reverbs and the like - has a sound that i wouldn't consider modulation. You can set the intensity and depth, but it sounds more to me like the signial is simply getting "chopped up", for lack of a better term, as opposed to the actual pitch being changed to create a similar, but NOT at all the same, pulsating effect. Now, the boss tremolo pedal is also considered a vibrato effect more or less too, but it employs pitch bending. The reason why i ask is i have a quad reverb now and im switching to a bassman as my main amp. The vibrato on the quad is like no other "vibrato or tremolo" effect pedal i've ever heard, they all change pitch. Since i wont have it onboard the bassman i'm obviously going to have to try to achieve it some how. Does anyone know if there is a pedal that can recreate the fender amp vibrato effect? |
#3 (permalink) | |
can't quite tell if you are looking for the big blackface fender trem, or some kind of pitch-modulating pedal. here's the rundown: fender employed bias-vary trem in early (and small) amps. this is volume modulations, but it is very soft and smooth, to the point that, when set right, it can almost sound like a leslie speaker (a bit of doppler effect). next, they gave us the big brownface harmonic vibrato. this "trem" is very hard to describe, but ultimately sounds like a less-psychedelic uni-vibe, or like some cousin of the magnatone amp true-vibrato finally, you have the big blackface amp trem. this is that choppy, helicopter trem that sounds like a spy movie or something. this trem has no semblance of "smoothness" "lushness" or "pitch modulation". it's just on-off-on-off-on-off for sine-wave smoothness: Boss TR-2 can do it, swamp thang, fulltone supa-trem, dano tuna melt for brownface pitch-modulation type effect: Fuchs creme de la trem. for blackface choppiness: boss TR-2 can also do this, so can the aforementioned Fulltone, dano tuna melt, boss pn-2, etc. really, just about any basic trem pedal can give you this, as it is BY FAR the easiest sound to replicate.
My band: The Pointed Firs |
Tremolo = volume up and down.
Vibrato = pitch up and down. Try an EHX Pulsar, they can do lots of crazy tremolo stuff.
I woke up this morning with a piece of past caught in my throat, and then I choked. I woke up this morning with the present in splinters on the ground, and then I drowned. |
It's unfortunate that Fender decided to be technically incorrect and named their
"tremolo" bridge and amp "vibrato" backwards. The Boss TR-2 is technically a tremolo effect, it pulses the volume, as does a Fender amp. It doesn't look like there's a lot of tremolo only pedals. Most tremolos are part of a multi-effects pedal. They differ as to how well they simulate the Fender "vibrato". |
Marshall VibraTrem pedal switches between both kinds of effect and the wave shape is adjustable on both settings . . .
and they're pretty inexpensive !
"Find what you like . . . and let it kill ya . . ." (Kinky Friedman) www.myspace.com/theboneyarsedboys |
#11 (permalink) | |
I've only seen the TR-2 a few times, and thought it only made the pitch modulation. im not much of a techie so just looking at it, i can't tell because i never knew what square or sawtooth wave forms actually meant, but now i have a better understnading of it - the saw wave produces the blackface choppiness (tremolo) and the square wave produces the pitch modulation (vibrato) cool, thanks EVERYONE for the info! i suppose Fender had it backwards because they called their floating bridge design a tremolo? Last edited by TDFiend; June 14th, 2011 at 12:41 AM. |
Dunno what this is - but it sure damn works for the song!
plain bootyfull
....and That's When the Racoon Attacked My Leghttp://www.myspace.com/timebanditsberlin |
I have an old silvertone 4707 6 watt organ amp that has real pitch shifting tremolo. not quite as choppy as vibrato or volume modulated effects, but the difference is pretty subtle more rotory sounding. The trem amps used varistors (dog bones) instead of the usual caps that do a feedback type effect and control the bias of the tubes.
#14 (permalink) |
Um, no, that's completely wrong. The TR-2 only produces Tremolo, i.e., volume modulation. The square wave is choppy, the sawtooth wave is smooth. That pedal does not produce pitch modulation at all.
"I feel my brains like porridge coming out of my ears, and I was anticipating reverie." |
Square- choppy, like fender optical tremolo (Literally a photo resistor in front of a blinking LED, easy pedal project if your up for it). Sound is either on or off, no in-between. Think "In my Head" by Jason Derülo.
Sawtooth- this is where you get the in-between sounds. Still as sharp as square wave, but if you hear the in-betweens, it's sawtooth. Not found in many amps. The other two are easy to recognize, but this one is a little harder (pretty much a mix of the two). Think "Boulevard of Broken Dreams" by Green Day. Sine- nice smooth tremolo, like Vox bias tremolo (literally by varying the bias of the power tubes- not such an easy project). Super smooth, flowing tremolo perfect for ambient stuff. Most often confused for vibrato. Sounds like someone's swiveling the master volume back and forth. Hope this helps. |
#18 (permalink) | |
Tremolo is volume only -So...- Fender "tremolo" bridge is actually vibrato! And A Fender "vibrato" is actually tremolo! -So...- You want tremolo -So..- Get a Boss TR-2!!! |
#19 (permalink) | |
I like the bias modulating ones, very suttle and not to over the top.
Marriage is the leading cause of all divorce. Marriage also contributes to spouse abuse. . |
