Old January 21st, 2005, 10:00 AM   #1 (permalink)
txspreacher's Avatar
Am I loco...
...or is there some type of pedal/effect that allows a guitar to simulate a bass? Would like to lay down some simple bass-lines on some home recordings once in awhile. Anybody familiar with this? Am I better off buying a cheap bass?
It ain't the years, it's the miles....
- Greg
txspreacher is offline   Reply With Quote
Old January 21st, 2005, 11:54 AM   #2 (permalink)
Fret Wilkes's Avatar
I'd probably get a cheap bass, but...
I actually played bass for a set on my guitar once when the bass player was late.
At the time I was using an octave divider that adds a synth note 1 octave lower that the note being played. I just turned the mix control totally to the effect...instant bass...if a bit rubbery. I wouldn't want to do it regularly, but it worked in a pinch.
Fret
See, I didn't reconize ya when ya first drove up till ya stuck yer hand out and wove then I seen right off who ya was and knowd ya.
Fret Wilkes is online now   Reply With Quote
Old January 21st, 2005, 11:58 AM   #3 (permalink)
TB72's Avatar
A whammy pedal will work too....
If you select the "1 Octave Down" setting, and have the pedal in the toe-down position, the whammy pedal will give you a usable bass tone with a guitar. It tracks pretty well too.
Later...
Why is easy-listening music so hard to listen to?
TB72 is offline   Reply With Quote
Old January 21st, 2005, 12:23 PM   #4 (permalink)
[/quote]If you select the "1 Octave Down" setting, and have the pedal in the toe-down position, the whammy pedal will give you a usable bass tone with a guitar. It tracks pretty well too.
I wondered about that. Could use a good whammy effect, anyway. I knew there were pedals that would change octaves, but your use of the word "usable" was the trick. I didn't know if it was all just moog-like sounds or got a good bass tone. Any recommendations for a good whammy pedal?
- Greg
Old January 21st, 2005, 12:25 PM   #5 (permalink)
Maaaaannn!!!
I try to get all fancy and see what happens? Sorry for the funky lookin' post...LOL!
- Greg
