Old April 27th, 2011, 04:34 PM   #1 (permalink)
E5RSY's Avatar
Scratchy Crybaby pot: Clean or Replace???
Should I just spray some cleaner in there, or take the plunge on one of those new sealed units Dunlop has on their site???
Thanks for any and all input.
Scott
"Out here in the middle, where the buffalo roam,
they're puttin' up towers for your cell phone..."
--James McMurtry, via Robert Earl Keen
E5RSY is offline   Reply With Quote
Old April 27th, 2011, 04:45 PM   #2 (permalink)
clayfeat's Avatar
Try to clean it first. It is easy to do and obviously cheaper. Mine is from the 80's. I sprayed some Deoxit in there a few times when it got scratchy and it seemed to help for awhile. When that stopped working I swapped out the pot.
clayfeat is offline   Reply With Quote
Old April 27th, 2011, 04:52 PM   #3 (permalink)
bo
bo's Avatar
What clayfeat said. The old one will obviously get dirty again, but with a little maintenance it should work fine.
bo is offline   Reply With Quote
Old April 27th, 2011, 04:54 PM   #4 (permalink)
E5RSY's Avatar
Clayfeat, which DeoxIT product would you recommend:
Contact Cleaner, Gold, or Shield???
Thanks,
Scott
Old April 27th, 2011, 05:06 PM   #5 (permalink)
dan1952's Avatar
The new pot is not that much money - replace the old one and you're good for a couple more years.
dan1952 is offline   Reply With Quote
Old April 27th, 2011, 05:06 PM   #6 (permalink)
E5RSY's Avatar
Never mind. Looks like it should be Contact Cleaner, then followed by Shield, perhaps.
Scott
Old April 27th, 2011, 05:07 PM   #7 (permalink)
E5RSY's Avatar
The newer sealed ones had better last longer than that.
Old April 27th, 2011, 05:16 PM   #8 (permalink)
Thighbanez's Avatar
Just did a swapout on a wah and a volume pedal today.
I vote swap.
Charlie Christian Squier '51 -> H.A. Tiki Drive -> MHP-BD2 Boost/OD -> Rogue Vintage Comp -> Behringer RV600 -> Rogue Analog Delay -> Dano Tuna Melt Tremolo -> TC Electronic Flashback Delay-> Fender Princeton 650
Thighbanez is offline   Reply With Quote
Old April 27th, 2011, 05:27 PM   #9 (permalink)
dan1952's Avatar
You would hope so, but I don't have much faith in any electronic parts being built today.
Old April 27th, 2011, 05:34 PM   #10 (permalink)
E5RSY's Avatar
Well, there is that...
Old April 28th, 2011, 03:20 AM   #11 (permalink)
octatonic's Avatar
There are several high quality 'boutique' pots available- just be prepared to pay through the nose for them.
http://www.jamesrichmond.com
Old April 28th, 2011, 06:49 AM   #12 (permalink)
11 Gauge's Avatar
I was going to mention a better quality pot, but the price difference between a truly better one and something you typically find will probably cause a bit of price shock.
The truth be told, older mechanical components that are "serviceable" tend to be more durable. It wouldn't hurt to give a shot of contact cleaner first.
Old April 28th, 2011, 08:10 AM   #13 (permalink)
6stringelectric's Avatar
When mine gets scratchy, I use the contact cleaner - but I also order a new one at that point, because I've found the contact-cleaner fix doesn't last too long.
Curt
The Lone Ranger and Tonto were ridin' down the line
Fixin' everybody's troubles - Everybody's 'cept mine
Someone must have told them I was doin' fine...
6stringelectric is offline   Reply With Quote
