Is there a pedal board the doesn't use velcro?
I hate applying velcro to pedals...I'm a flipper and it diminishes re-sale value. Wondering if there is an alternative.
Guitar>Boss ST-2 Power Stack>Vox Time Machine Delay>Amp My music page: http://www.soundclick.com/schenkadere |
Ive seen them with holes in the board and then zip ties are thread thru these holes to fasten the pedals down. Looked a bit ugly to me, and the pedals move a bit in their positions, but no velcro!
I guess you'd need to cut the ties to free the pedals for single use too. I couldnt find a good google pic in my 2 minute search, sorry! |
This is a bit crude to some I suspect, but I unscrew the screws that hold the bottom on, cut some short strips of plastic, about 1/4" wide by 3/4" long from a mike jug. It's low density poly and has nice flex. I poked holes, one on each end on the strip, and put the screws through one hole and put the pedal back together. This gives you four little flexible tabs sticking out from the bottom of the pedal. Then put it on your board and screw it down, using the four holes you have sticking out, with small screws. I used #6, 3/8" long sheet metal screws. It works well for me.
Directions? What directions. No one told me there were directions. |
Boss has several that don't use velcro. It mas pre-cuts for boss style pedals but you can easily customize it to any pedal. The power source alone is worth the money of the board. Very durable as mine as fallen off a back of a truck several times. Urghhh..
- Do you see my Avatar? If you comment on my grammar I will unleash his fury on you. |
http://www.jamesrichmond.com |
Life's a journey, not a destination...and I just can't tell, just what tomorrow will bring. http://www.myspace.com/morrisonmusictown |
I've seen little metal brackets that screw down to the board. Just remove the bottom mounting screws, place bracket, re-install screw then screw down to board. Essentially the same thing as LeroyBlues described. You could easily make them up from a bit of 'all-round' or something similar.
#10 (permalink) | |
#11 (permalink) | |
You could take a look at the Behringer PB1000 pedalboard. It comes with an integrated power supply and has foam inserts that have cut-outs so you can fit Boss-type pedals in them without the need for Velcro. You can also trim the foam to accomodate larger pedals. These go for about $100 USD. ![]() A cheaper and more creative option would be to make your own pedalboard out of an old suitcase. You could get one at Goodwill or The Salvation Army for cheap. Strip out the lining and get some foam boards from your local arts/crafts store to line it with. You could use strips of velcro to keep the foam boards attached to the case and just cut the boards so you can press fit your pedals into them. Then get a 1Spot Combo pack and daisy chain your pedals. |
I'm giving in and going with velcro. The Hardwire pedals have that custom cut velcro that fits neatly on the back of the pedal. These are mass produced pedals, so they're nothing special...I don't really care about re-sale now and don't plan on pedal flipping anymore anyway.
Well, I did it...tore the rubber bottoms off my Hardwires and neatly applied the supplied velcro. I feel like I defiled the pedals...man those skid pads were on there...one took the paint off with it.
I picked up a Roadrunner pedalboard/gig bag on the cheap at GC. Not bad for 30 bucks. I slapped the pedals on along with my amp footswitch and voila. I'm powering it with my Godlyke Power All. It all folds up into a neat little package. Man, that's some pretty strong velcro!!! Just adjusting the pedal positions takes some real pull! I gave in and it is done. I'm happy with it.
#14 (permalink) | |
#16 (permalink) |
I figured most people do use velcro and the Hardwire pedals aren't vintage or anything special, so, why not? Besides, the supplied velcro fits so nice and neat. I'm glad I manned up and did it.
#17 (permalink) | |
Like several people said above...........................
![]() I've got them on my board and love em'. And added bonus, you NEVER have to worry about a pedal disappearing from you board during a break at a gig!!
Home Grown's MySpace Page Quote:
#18 (permalink) | |
I, too, hate to apply velcro to the bottom of a pedal. It usually damages it to some degree; if not immediately, then over time. The only downside to the screws is that it takes a bit longer to change out a pedal on the board than if you were using velcro. However, since I rarely change things out, this isn't a big issue for me. |
#19 (permalink) |
There is one pedalboard maker who makes the board with holes, and you secure the pedals with zipties. It's called holeyboard, google and it comes up.
Anyone know where to get those mesh pedalboards that you can screw then bike chains on to? I got a couple of marshall pedals and I really don't want to rip the back off to be able to velcro. But if I can't find another solution soon, I'm going to probably have to get a pedaltrain and do that. |
#20 (permalink) | |
For all my Boss pedals I order spare baseplates from Boss. I unscrew the original one, keep it in the box and add Velcro to the replacement.
They are quite cheap. I paid something like 35-pence for the older style and 40-pence for the newer model with the thick rubber pad. Here's a previous thread: Quote:
