Old November 29th, 2009, 04:16 AM   #1 (permalink)
ttl100's Avatar
Battery Pack power for pedals
I'm tired of the hum from using multidrop power supply to power my pedals. I'm thinking of building a battery pack with 6x D batteries for 9V and wire to all my pedals. Will this reduce hum? Is it a workable solution?
ttl100 is offline   Reply With Quote
Old December 1st, 2009, 09:58 PM   #2 (permalink)
SackvilleDan's Avatar
By using a battery, you're not grounding the pedal in two places anymore (the adaptor and guitar jack), so this will help you cut down on noise.
Let us know how it works!!
Tele/Strats->Huckleberry Fuzz->Pitchblack->Diamond Compressor->Timmy->Marshall Jackhammer->Cool Cat Vibe->Outlaw Supply Big Blue Tremolo/Boost->Eventide TimeFactor->Boss RV-3->Boss RC-2-> Marshall 1962 RI w/ KT66s
SackvilleDan is offline   Reply With Quote
Old December 4th, 2009, 11:16 PM   #3 (permalink)
Joe-Bob's Avatar
I've never had hum occur from pedal power. Makes me wonder what you guys are doing.
The lone voice screaming in the wilderness might be wrong, but that he is alone is never the reason why.
Old December 6th, 2009, 10:52 AM   #4 (permalink)
I don't have any issue using a Voodoo Labs Pedal Power 2+, but I can hear a big difference in the amount of buzz with a 9V battery vs. a wall wart.
Case in point: I picked up an old MIJ DS-1 a few years ago, and didn't have an adaptor handy, so I threw in a battery, and was impressed at "how quiet this beat up old Boss" was.
Once that battery croaked, I plugged it in with an ACA adaptor, and I heard humming like you wouldn't believe! So I checked a couple other pedals, and sure enough, same thing.
It could have been dirty power in the room, but plugging in to an unregulated/unfiltered power supply always adds hum IMHO. By using a battery, your signal is being grounded through your cable, connected to your amp, which is essentially the one point of ground (where its third prong is in your wall).
By using an adaptor, you're grounding your signal through through that as well as through your amp; and it's this loop I'm assuming creates the buzz.
Old December 6th, 2009, 11:31 AM   #5 (permalink)
yonie's Avatar
My experience is that it can also be a crappy adapter causing noise. Aka use specific adapters made for powering pedals instead of generic ones, especially avoid the ones that can be set to multiple voltages.
yonie is offline   Reply With Quote
Old December 6th, 2009, 11:36 AM   #6 (permalink)
Honestly, until right now it hadn't dawned on me that the adaptor could have been crappy
The adapter I used was the right voltage, so I assumed it was appropriate. In order to not use batteries, I just ended up buying a Pedal Power 2+, and the problem was solved.
Old December 7th, 2009, 01:20 PM   #7 (permalink)
winny pooh's Avatar
I was using 3 boss adaptors to power my rig but the pedal power 2 is much quieter, it may be my imagination but it even sounds cleaner (which may have to do with the fact the the older boss pedals are now running on the correct 12v)
my afro ambient side project:
http://www.myspace.com/theswyambusessions
I play dancy bass here: http://www.myspace.com/casabellamusic
winny pooh is online now   Reply With Quote
Old December 13th, 2009, 04:56 AM   #8 (permalink)
ttl100's Avatar
Finally done! No more hum and buzz and all those yucky unwanted noise. Very happy with the result. Cost me also nothing.
Old December 13th, 2009, 08:57 AM   #9 (permalink)
jefrs's Avatar
Battery pack do-able but expensive hobby. Use re-chargeables.
A decent mains power supply has feeds isolated from each other, no hum. The only earth point should be your amp, the supplies should have floating earths.
jefrs is online now   Reply With Quote
Old December 15th, 2009, 01:10 AM   #10 (permalink)
ravindave_3600's Avatar
You're running 5 pedals off 6 D's. How long will this last before you run out of juice?
Want my guitar to sound like BBQ tastes!
Check out the band at www.brightredtie.com
ravindave_3600 is offline   Reply With Quote
Old December 15th, 2009, 01:33 AM   #11 (permalink)
beep.click's Avatar
I've run into it occasionally. I can always trace it to a combination of a certain pedal with a certain power supply... but not always that one specific pedal, or always that one specific power supply!
Bottom line, if I carry enough wall warts, I can swap out until the hum goes away.
Also: I've never had hum when using a 1 Spot (yet).
beep.click is offline   Reply With Quote
Old December 15th, 2009, 02:18 AM   #12 (permalink)
guit30's Avatar
Put it in a fancy metal box , call it the humdrummer and sell a few hundred
J
Wampler Ego Compressor
Edan Analog Nashville Hot Boost
Jim's Country Reviews
www.geocities.com/guit30
guit30 is offline   Reply With Quote
DE-7 Really uses this much battery power? Massimo636 The Stomp Box 9 January 21st, 2009 12:33 AM
Why Do some pedals sound better with a battery. tele-martini The Stomp Box 10 February 7th, 2008 11:58 AM
Thoughts about Waves Native Power Pack Kurt Recording In Progress 5 November 3rd, 2007 10:59 AM
Battery power for stomp boxes JDC The Stomp Box 2 September 30th, 2007 08:51 AM
Can any power supply be as quiet as battery? Ivan The Stomp Box 8 July 13th, 2007 08:55 AM
