Old November 20th, 2009, 09:48 AM   #1 (permalink)
Boss RC-2, A Couple Questions
What is the best way to set the RC-2 up on my pedal board? I'm running a Barber Tone Press, MXR Carbon Copy, Barber LTD, Hardwire RV-7 and a BBE Sonic Stomp (for now). I'm running the pedals into the front of a Princeton Reverb (no FX Loop). All of the pedals I'm using have "True Bypass" except the RC-2.
Where do I place the RC-2 in my pedal chain to get the best results? When I'm not using the RC-2 will it suck the tone from my guitar and other pedals? For that matter, will it suck the tone from my rig when I am using the RC-2?
Thanks, Res
resonator is offline   Reply With Quote
Old November 20th, 2009, 11:29 AM   #2 (permalink)
elmatt's Avatar
I would suggest that anything you wanted to include in your recorded loop should run before the RC-2. If you are using other sounds that you do not want to be part of the recorded loop; they should run after the pedal.
elmatt is offline   Reply With Quote
Old November 21st, 2009, 12:44 AM   #3 (permalink)
I run mine last, and I don't notice tone suckage.....but that's just me.
krog is offline   Reply With Quote
Old November 21st, 2009, 01:24 AM   #4 (permalink)
HOBBSTER01's Avatar
Use good patch cables and the suckage will be minimal.
Put the RC-2 at the end of your chain.
The Hobbster
HOBBSTER01 is offline   Reply With Quote
Old November 21st, 2009, 10:52 AM   #5 (permalink)
What would you suggest for patch cables?
Old November 26th, 2009, 09:34 AM   #6 (permalink)
I use a jamman;have it first after guitar. Yes it saps power when connected.
happy2 is offline   Reply With Quote
Old November 27th, 2009, 03:12 AM   #7 (permalink)
the patch cables i get are from a local store and they are the pancake ones. I can only find them in 6 inch but the dimarzzio ones are great but at 12 bucks a peice get pricey
mlweidl is offline   Reply With Quote
couple of amp questions... jeffinwv Amp Central Station 8 June 18th, 2008 09:50 AM
A couple of questions for those who own SX guitars tdu Bad Dog Cafe 4 June 30th, 2006 06:33 PM
A couple of Vox AD questions tdu Amp Central Station 17 March 8th, 2006 05:42 AM
A couple of P-90 questions kickz28 Just Pickups 4 July 21st, 2005 02:31 PM
I got the SF twin. Now - a couple of questions. Scott M Amp Central Station 6 July 25th, 2003 07:55 PM
