Please explain to me...
...what's the difference between distortion and overdrive ?
I'm new to pedals, I've got a cheap distortion box but I've never had a chance to try overdrive. Thanks in advance. |
Overdrive is more soft. It's when you are pushing an amp a bit with a bit of gain but not so much as to get the sound really "distorted"... Think of blues! If you add a bit more gain, you get more "crunch" à la Eric Clapton! Yet, it's not very dirty. There is not a lot of distortion.
Distortion is what you get when you add a lot of gain, from (Hard rock - metal songs..., etc) Overdrive pedals are (usually) not going to give you a lot of gain. You won't rely on them to play metal. You'll need more gain for that! You'll need a distortion pedal! Or think of it like this: Clean ---------- A bit dirty----------- A bit more dirty ----------Distortion!! Clean ---------- A bit less clean------A bit more crunch-----------Dirty!!! Clean-----------A bit of overdrive--------Overdrive----------------Dirty!!! --------- Edit: here is a good explanation, I think: http://www.dolphinstreet.com/blog/di...-overdrive.php Last edited by Grandma's Tele; November 13th, 2009 at 03:06 AM. |
#4 (permalink) | |
"I'll have to get an [Insert pedal name here] pedal now...you know, just to make SURE I understand... |
An overdrive pedal in its strictest sense is a pedal that pushes (overdrives) the preamp tubes of your amp into distortion. Some overdrive pedals have a degree of distortion to add to this mix adding to the already overdriven tubes but generally their use is to act like a additional gain stage in front of the amp specifically overdriving the preamp tube section. I.e. "tube screamer", making those tubes scream!
A distortion pedal generates it's own flavor of distortion, not really designed to rely on tube preamp distortion. Generally paired up with an amp that is clean at louder volumes. It too can have enough boost to push your preamp into overdrive but is generally used for it's own characteristic distortion. |
You can get some nice OD sounds out of your Cube without pedals. Just dial down the gain. That's a nice amp...very versatile. I've had the Micro Cube for years and am still amazed how great it sounds. I've used it direct for recording too...good stuff.
Jackson Soloist Archtop/Washburn A20>MXR Dyna Comp>SRB808+>MXR Classic Distortion>Guyatone MC-3 Micro Chorus>Tech 21 Boost D.L.A.>Tech 21 Boost R.V.B.>Modified Crate V5(for now) Some rough tunes: www.myspace.com/schenkadere |
i've always thought of overdrive as pushing the signal till it looses its clarity. I think of distortion as scrambled eggs, its scrambling the signal.
USA Ovation MIA Standard Telecaster * Vox AC15CC Martin 000C-16RGTE Aura ISP Decimator - MXR Super Comp - Wah - Keeley TS9 86 Pro Co Rat - Volume Pedal (Boss TU-2) - Boss DD6 Some people sing in the shower, I play guitar... |
#12 (permalink) | |
The world is full of busy people, might be a better place if some of 'em spent more time on their arses... |
#13 (permalink) | |
"How do I know that the color blue "to me" is the same as the color blue "for you" mannnnnnn? I can't tell you how much that post made me smile. Nice! John
John
#14 (permalink) |
I'll give my goofy explanation......
With overdrive you can still hear the the tone of the clean-ish guitar. With overdrive the warm jangle tone of the guitar still sparkles through. Distortion is almost fuzzy......It's so heavy and thick that the jangle and sparkle of the guitar is nearly gone. REM, Tom Petty = Overdrive System of a Down, Metalica = Distortion
John
| Can somebody explain... | jimd | Bad Dog Cafe | 1 | July 23rd, 2009 01:35 PM |
| Someone Explain This To me.... | Andy Summers | Bad Dog Cafe | 24 | May 22nd, 2009 10:18 AM |
| Please explain why | benbo | Tele Home Depot | 16 | April 20th, 2009 08:36 AM |
| Can't Explain | HighTower | Bad Dog Cafe | 1 | January 4th, 2009 12:28 PM |
| Could some one please explain this... | The String King | Bad Dog Cafe | 8 | July 29th, 2006 06:49 AM |
