One buffer? Two buffers?
I'm trying to understand the application of buffers. I think I understand what they do - they drop the impedance of the guitar's signal and compensate for cable capacitance, thereby getting the tone of your guitar more completely to the amplifier.
Based on that I would think that you'd want one buffer between the guitar and the amp, even if you were using no effects. But what about with pedals? Should you use two buffers? Put one buffer at the front of the cascade of pedals, and then another at the end (to compensate to some degree for the electronic shenanigans that the pedals impose on the signal). Arrange the switching so that one buffer is in the line even if the entire pedal chain is switched out of the circuit. If someone knowledgeable in electronics could enlighten me, I would be grateful. |
I'm working with this issue now. I'm planning on building a loop box with two buffers - one in front of the send, one running out to the amp, even if the loop is out. The issue is where to best put the 'permanent' buffer, and what the input impedance should be. It may be that a single buffer is enough, in front of the whole deal (this is the way I'm leaning).
I'm planning on useing the GGG buffer: http://www.generalguitargadgets.com/...=74&Itemid=104 steven
"When you have to kill a man it costs nothing to be polite" - WSC |
Here's an interesting article about Brent Mason's pedalboard that discusses using a line buffer.
http://www.premierguitar.com/Magazin...edalboard.aspx
"I'm not responsible for anyone's gruntlement" - Lt. Col. Henry Blake |
| buffers and true-bypass | hedegaardo1 | The Stomp Box | 7 | May 28th, 2009 05:53 PM |
| Too many buffers? | SMurphy28 | The Stomp Box | 5 | May 14th, 2009 04:46 PM |
| Anyone use buffers on their boards | BellyBoy | The Stomp Box | 2 | November 20th, 2008 03:37 AM |
| Switching pedal buffers | Darcy Hoover | The Stomp Box | 2 | July 28th, 2008 03:43 PM |
| True Bypass Boxes and Buffers. | russpurdy | The Stomp Box | 2 | December 4th, 2007 12:21 PM |
