I think many people would suggest putting the compressor first in the chain. That said, it is personal preference and if you don't like it that way, then don't do it. But if you haven't tried that, I would. Other than that, I think it looks good.
MBP is right, try the OD & Comp both ways & keep it the way you like best. I'd run the volume pedal just ahead of the DD-5, so that when you cut the volume down, the delayed repeats still decay naturally. I'd also run the tuner off of the volume pedal's tuner out, if it has one.
I put the comp last in the chain. If you put the comp first then run thru everything else arent you kind of defeating the purpose of having the comp. I mean I use a compressor to level things out and add a little gain. Take all the signal say OD, Delay and Chorus and then compress that signal going to the amp. But thats just the way I do it works for me.
#5 (permalink) | ||
http://www.jhsmods.com/JHS_Pedals/Volume_tuner.html |
Ernie Volume Pedal's tuner out to the Boss tuner.
Then the volume pedal's output to the the Keeley comp, then to the Tubescreamer, then to the Boss DD5. But that's just me. |
#8 (permalink) | |
#9 (permalink) | |
Tuner > Comp > Loop (Wah) > OD > Chorus > Delay ...works best for me.
The world is full of busy people, might be a better place if some of 'em spent more time on their arses... |
| Opinions on effects chain | Neill Levine | The Stomp Box | 6 | August 30th, 2006 08:39 PM |
| pedal chain | dylanfreak | The Stomp Box | 5 | April 24th, 2005 11:52 PM |
| Who uses an EQ in their pedal chain? | jdfoosh357 | The Stomp Box | 3 | January 29th, 2005 04:09 AM |
| Why does one pedal Hum when others are in the chain? | bj | The Stomp Box | 5 | November 3rd, 2003 07:46 AM |
| Why does one pedal Hum when others are in the chain? | bj | The Stomp Box | 0 | October 14th, 2003 07:14 PM |
