Old August 18th, 2009, 10:53 AM   #1 (permalink)
Sniper1's Avatar
Luther Perkins Style
Aside from palm muting,what is needed to create the L.Perkins sound?
I know how to PM but it sounds like crap,not even close to Perkins sound,I have a Vox AC15CC1 amp,Tele Standard,am I in need of effects pedals?if so what is the recommended pedals for a good country sound?
Sniper1 is offline   Reply With Quote
Old August 18th, 2009, 12:49 PM   #2 (permalink)
Luther Perkins used heavy gauge flatwound strings and lots of treble...and no effects, since they didn't exist then.
davidge1 is offline   Reply With Quote
Old August 18th, 2009, 01:08 PM   #3 (permalink)
Roli's Avatar
Luther Perkins used an Echosonic amp for some time, that had a built in echo.
http://www.scottymoore.net/echosonic.html
Roli is offline   Reply With Quote
Old August 18th, 2009, 04:05 PM   #4 (permalink)
RomanS's Avatar
For Luther sounds you'll just need a slapback echo, no other effects; any delay pedal should be able to do this, but an analog one (or an analog-sounding digital one) would be preferred!
Old August 18th, 2009, 04:12 PM   #5 (permalink)
czech-one-2's Avatar
live he often just used spring reverb.
i'm getting a nice luther tone with the boss frv-1 reverb pedal.
czech-one-2 is offline   Reply With Quote
Old August 18th, 2009, 06:07 PM   #6 (permalink)
Sniper1's Avatar
I have a DIGIDELAY,will this work?
Old August 18th, 2009, 06:13 PM   #7 (permalink)
RomanS's Avatar
Sure, use the "Tape" setting, set the repeats for only one or two at most, and use a rather short delay time, that should work!
Also, use the bridge pickup on your Tele (the middle position, while not 100% "original", might also work well), and a clean sound from your amp.
Flatwound strings would make it perfect, but are not really an absolute "must"...
Old August 18th, 2009, 07:30 PM   #8 (permalink)
Sniper1's Avatar
RomanS you are a daisy,thanks for the advice.
Luther Perkins Robinson Telecaster Discussion Forum 26 June 15th, 2009 07:46 PM
Remembering Luther Perkins AnthonyV Telecaster Discussion Forum 6 August 3rd, 2008 04:28 PM
Let's talk Luther Perkins! Lerb21 Telecaster Discussion Forum 12 February 15th, 2008 04:19 PM
Luther Perkins Stickyfingers Telecaster Discussion Forum 6 September 16th, 2007 01:13 PM
Luther Perkins Fender Anthonyray200 Telecaster Discussion Forum 5 May 15th, 2007 05:58 PM
