Old August 15th, 2009, 04:07 AM   #1 (permalink)
Chrismo's Avatar
Does this even exist?
If so, what is the name for it?
I need to squeeze one more pedal in on my One Spot chain, and I don't want to buy another chain just for one more pedal. The end I need to connect to is the negative end that typically connects into the AC adapter; I'm trying to run the AC adapter into the new tuner pedal, then from the second "out" power jack on the tuner pedal run this "patch" into the One Spot daisy chain (negative end) and power up the other pedals.
This is probably a really stupid question, but I had to ask anyway.
Well let me just quote the late-great Colonel Sanders, who said..."I'm too drunk to taste this chicken."
http://thetonechasers.wordpress.com/
Chrismo is offline   Reply With Quote
Old August 15th, 2009, 10:17 AM   #2 (permalink)
TB72's Avatar
I have one of these. It was an accessory that came with a Godlyke Powerall (their version of the one-spot).
I've actually made a bunch of these as well, in varying lengths. (It's both cheap and easy...check out any electronic supply store for the parts. You just need 2.1mm male and female ends, and some 2 conductor wire.)
Later...
Why is easy-listening music so hard to listen to?
TB72 is offline   Reply With Quote
Does this bridge exist? ten56gibby Tele-Tech 7 August 15th, 2009 01:03 PM
Does This Amp Exist? Highway_61 Amp Central Station 22 June 11th, 2009 09:03 PM
Does it exist? swampscott Telecaster Discussion Forum 3 March 21st, 2009 04:46 PM
Does this amp exist? jazztele Amp Central Station 8 October 28th, 2007 11:29 PM
Does such an amp exist? TieDyedDevil Amp Central Station 13 December 23rd, 2006 04:59 PM
