The essential pedals
In your mind what are the essential pedals every working guitar player should have, Like overdrive, wah, ect. Im just tryng to build a pedal board that has just enough to get by not alot of cray stuff just a the bare bones!
I've always got a compressor, buffer, mosfet booster, low gain overdrive, and delay/reverb.
Current set-up Guitars: Squier JV Strat or CIJ Fender Telecaster Effects: Doobtone Micro Buffer, Cmatmods Compressor, Digitech Whammy, Tubeworks Realtube. Amps: Kustom Defender or EVJ |
You've got to honestly determine what kind of music you 'like' VS what you're
going to be playing - or they might be the same. i.e. For delta blues you could go into a low watt tube amp without pedals... if you know the venue sizes you'll need to be sure you don't overpower the room with too many watts trying to push a larger amp into overdrive. for heavier stuff you may want to add OD's, fuzz etc... |
#9 (permalink) | |
That's the great thing about alt.country through Bruce. It's all based in roots music so you don't need piles of pedals and junk to make it happen. One of my many bosses fronts an alt.country/americana band and just plugs his Esquire into an AC15 - no need for anything fancy. He's also the biggest Bruce fan I know if that means anything.
I go with tuner-boost-OD-tremolo-delay. I play country and rockabilly mainly and that does it for me. If it wasn't for Duane Eddy tunes I could do without the trem.
Life is better when you just make it up as you go along. |
Essential for me would be an OD and an analog delay. I can do what I do straight in but would lose a lot of very cool stuff and textures for different songs without the delay. Even though my current group tends to do pretty pop-y sort of songs (As chosen by our pop-loving lead singer and her boyfriend the drummer) they let me put in psychedelic accents pretty generously (considering) and I simply could not do that convincingly without my delay.
#12 (permalink) | |
Practice make permanent!!!!....Perfect practice makes perfect!!! Chris B. www.neonjones.com |
OD - Verb - Wah (forum threads with 'show me your pedal' seem to have at least one pedal, sometimes the volume flavor-important to note, if you're not headed for a gig, you might forget the tuner, and keep it simpler/more economical), that said, my Boss Flanger is fun, YMMV...
#14 (permalink) | |
One Channel Class A old tube amp, straight in cranked, roll it off with your volume! You don't need no fangled 2 channel amp. Jeez...get back to true tone.
It doesn't mean a thing if it doesn't have that twing! |
Essential pedals? None, just straight into a Champ, Deluxe or Bandmaster depending on the size of the venue, the need for cleans vs. crunch et.c.
Fun? A low gain OD, Wah, Verb, Tuner and Trem.
We shall not cease from modifying our amps. And the end of all our modifying will be to arrive where we started and know the circuit for the first time. |
#16 (permalink) | |
Just don't forget to cap (.022) that axe off, to keep from losing the highs..... FWIW.... PEACE |
#17 (permalink) |
#1 - Tuner
If your amp is too loud to crank, then a basic OD pedal, like a tubescreamer. Then, a Delay, which I use for slapback, but at shorter/quicker settings you can sometimes get chorus and reverb sounds out of some of them. I like clean for the rockabilly and country I do, so I'm fine with just a tuner and delay, and I'll sneak in a tremolo when the band ain't looking |
#19 (permalink) |
SO after reading all these i decide maybe ill go with a tuner, a od and a delay! Any suggestions on what ones to get? i got a boss dd3 and a zakk wylde overdrive in a package deal on Craigslist but i think i might be able to do better! maybe tube screamer and a line six dl4? what do you think?
#20 (permalink) |
No need to get such a fancy delay as the Line6 for those types of tones (though this one would work, of course...) - anything slightly analog/warm-sounding will do, like one of the inexpensive Danelectro models, or the Artec SE-ADL; if you want to spend more, i'd get something like the MXR CarbonCopy, BBE TwoTimer, Cmatmods Deeelay, or one of the Malekko Echos, maybe the Marshall Echohead - the Boss digital delay would be the very last one on my list, I'd get anything but that one for alt.country; you might also want to wait a bit for first reports about the brand-new Electro Harmonix Memory Toy to come in...
Tuenr: that's the easy one: Korg Pitchblack, absolutely no need to look elsewhere, nothing comes even remotely close in its price-range! OD: For alt.country something Tubescreamer-ish, like a Digitech Bad Monkey (as the budget option that sounds pretty good), or at least soemthign that's focussed on the lower to mid gain levels (Barber LTD, Danelectro CoolCat Transparent Overdrive, Marshall Bluesbreaker II, Fulltone Fulldrive II, etc.) For me a tremolo pedal is also essential for alt.country playing (but not for Bruce!). |
#21 (permalink) |
Huh, funny....I go Wah > OD > Delay as well.....cool!
To the OP.....first and foremost decide between digital and analog delay. I love the sound of analog delay and I don't think it would be too unfair to generalize and say that digital delays are more flexible/versatile but analog sounds better (WAY better). I use a Carbon Copy and love it to death. |
#23 (permalink) |
marcbc,
Stick with the DD3. I had an Echohead and then a SMMH on my board and they got replaced by my old MIJ DD3 for long delays. Straightforward, nice repeats, industry standard, it really rocks. I do have a MXR CC on there as well for slapback. I also like my Bad Monkey alot for OD (price is nice as well). |
#24 (permalink) |
Depends. Wah, couple of dirt pedals to move from cleanish to dirty and a delay and a tuner. Currently I use a Turbo Tuner, 535q, Screw Driver, Lunar Module, Dirty Little Secret, Top Fuel and DD7.
Guitars: Teles, LP, others. Amps: Bassman LTD, Richter 5E3, 5E3 Head, Traynor Bass Master II, Epi Jr Head, Gretsch, 60's Univox and others. Current Board-Guitar>Tuner>Java Boost> Huckleberry>Fuzz Head>Top Fuel>SFX-03> Keeley Comp>Clone Chorus>FL3> Amp |
#28 (permalink) |
my current essential pedals go:
- Digital delay (DD-7) for clean passages - Analog delay (Carbon Copy) for dirty tones and solos - Tremolo (Coolcat trem) for loads of things - Dirtbox (FulldriveII) for boosting amp or standalone overdrive - Tuner (Pitchblack) These 5 pedals change every time, but most of the time I will be happy with just a dirtbox. Stick to your DD3 and zw overdrive and move on from there. Would recommend the Pitchblack too for your tuner choice. Carbon Copy also gets my recommendation as I really love using it with dirty tones, sits beautifully in the mix. |
#30 (permalink) | |
OD: Bad Monkey, ts808 reissue, Dan Electro TOD, THrobak OD, Barber LTD Delay: MXR Carbon Copy
"You released the ******* fury!" |
#31 (permalink) |
See my post today: "Proven guitar/pedalboard/amp set-ups"
Essentials: Korg Pitchblack tuner ($80) Fulltone OCD ($143) Boss DD-7 Delay ($160).
![]() Don't die with the music still in you! Psalm 150 |
#32 (permalink) |
essential for me...
1-compressor (HBE retro CPR)
2-sometimes low gain OD (Transparent OD) sold my 808! 3- Delay (Carl Martine red repeat) at other times I will use another pedal..vibe..tremolo..chorus..wah...phase..but rarely..if a tune calls for that effect... but my current sound is based on Comp and delay at very subtle levels...with some amp reverb. iggy
I must have had music lessons...." Reverend Jim from Taxi |
#34 (permalink) |
Whatever is essential for your sound. All LOVETONE pedal names make me think of FABIO. * Meatball - envelope filter/follower * Big Cheese - fuzz * Brown Source - overdrive * Doppleganger - dual LFO phaser/vibrato * Wobulator - dual LFO tremolo and stereo panner * Ring Stinger - ring modulator, octave fuzz, simple analog synthesizer * ? (Flange with No Name) - stereo flanger, multi-function time/stereo modulation effect, simple analog synthesizer * Cheese Source - combination of the Big Cheese and Brown Source in one unit ![]() If you think about this question in a wider context most pedal manufacturers have models that cover this basic range. They are kind of essential. Just like Fabio. |
#35 (permalink) | |
You can use it as a volume boost on the clean channel, for solos or when switching to a guitar with low-output pickups, to OD the input of the drive channel, or, at higher settings, to boost the drive and volume of a drive channel. One pedal can effectively turn a two channel amp into a 4 channel amp. Very handy indeed. While your there, you may as well get something with independent boost and drive, like a Box of Rock. Apart from a tuner, the most useful pedal I've ever used, and the one I take off my board and put in my guitar case when I'm going to have to use someone else's amp. It also effectively turns a single-channel amp into four channels if everything is set up right. |
| Your essential blues pedals | cowie86 | The Stomp Box | 33 | March 25th, 2009 12:03 AM |
| which pedals are absolutely essential for a smooth jazz/blues/fusion board? | dtfan4ever | The Stomp Box | 3 | February 12th, 2009 11:01 PM |
| Essential pedals.................... | Blewbyou | The Stomp Box | 141 | April 23rd, 2008 05:44 PM |
| Essential pedals for home studio | JohnnyCrash | The Stomp Box | 27 | December 15th, 2006 06:07 AM |
| Q: Essential Haggard | ne4tt | Telecaster Discussion Forum | 3 | July 11th, 2005 03:19 PM |
