Old July 21st, 2009, 03:28 PM   #1 (permalink)
A.B.Negative's Avatar
I'm an idiot! I thought my Bad Monkey has died!
I've had a Digitech Bad Monkey for a while and it's always worked as it should. I plugged it in today and everything was fine until I switched it on. No sound at all! The light comes on but there's nothing from either output. When switched off, my signal goes through as normal.
Do you think this will be easy/cheap to fix? I haven't looked inside the pedal and I don't have any electronic test equipment.
Help!
"The disgusting stink of a too-loud electric guitar....
Now, that's my idea of a good time."
A.B.Negative is offline   Reply With Quote
Old July 21st, 2009, 04:07 PM   #2 (permalink)
Next time I'll check the volume isn't all the way down before I panic!
Old July 21st, 2009, 04:24 PM   #3 (permalink)
mikfer's Avatar
Sheepishly admits . . .
Many times I've plugged in the pedals, made sure they are on, plugged into the amp . . . no sound or just a loud hum . . .
On yeah, ya gotta put the plug into the *guitar* as well.
Honor Est Omni - "Honor is all"
mikfer is offline   Reply With Quote
Old July 21st, 2009, 04:26 PM   #4 (permalink)
Ha! I feel ya on that one. Last night I cleaned the pc boards on my Rivera and when I reassembled everything to test it today I was sure I killed it. Nothing on either channel with the volume and master for each up loud. Then I remembered that if you zero out the bass, mid, and treble controls you get nothing. Turned those up and the glorious Rivera clean started coming out again. Definitely my "Doh!" moment of the day.
zombuswoof is offline   Reply With Quote
Old July 21st, 2009, 04:33 PM   #5 (permalink)
RodeoTex's Avatar
Heck I was just about to send you my Bad Monkey when I first saw this thread...
Old July 21st, 2009, 05:52 PM   #6 (permalink)
JayDee's Avatar
I can't tell you the number of times we've started to freak out at soundcheck because nothing was coming out of FOH only to realize the channels were muted. It's become a running joke.
JayDee is offline   Reply With Quote
Old July 21st, 2009, 06:13 PM   #7 (permalink)
Ivan's Avatar
thats a new one!
I once thought my amp was broken but it turned out I hadn't plugged my instrument lead in yet!
Ivan
Ivan is offline   Reply With Quote
Old July 22nd, 2009, 05:13 AM   #8 (permalink)
I feel much better now I know I'm not alone!
Old July 22nd, 2009, 05:32 AM   #9 (permalink)
xjazzy's Avatar
A friend of mine had all is cables checked in his weeding band just to find the sound board plug was not connected to energy!!!
Still got the Twang!
myspace.com/jpmartins
xjazzy is offline   Reply With Quote
Old July 22nd, 2009, 11:27 AM   #10 (permalink)
FMA
My favorite -- and I have to admit that this has happened more than once -- is when I'm getting no sound and a bandmate suggests checking to see whether the guitar is plugged in and I say, of course, the guitar's plugged in and when I look down, it's not.
Talk about a d'oh moment.
Always gets a pretty good laugh, though.
FMA is offline   Reply With Quote
Old July 22nd, 2009, 11:49 AM   #11 (permalink)
magicguitar's Avatar
Yup it's those common and SIMPLE mistakes that throw us into a panic... but don't they make life interesting?!?
magicguitar is offline   Reply With Quote
Old August 15th, 2009, 12:39 AM   #12 (permalink)
mwaym's Avatar
I've panicked more than once when something wasn't plugged in. Especially since I put the pickups in my Tele and my Strat myself.... and Im not good at soldering !!!!
mwaym is offline   Reply With Quote
Old August 15th, 2009, 11:23 AM   #13 (permalink)
You name it, I've done it. Again and again and again...
larry
Larry F is offline   Reply With Quote
Old August 17th, 2009, 01:10 AM   #14 (permalink)
Home Grown Tele's Avatar
Been through the same thing with a volume pedal. Freaked out until I finally realized the pedal was in the up position and volume was turned off!
Home Grown's MySpace Page
Chris Leger- "I freeze all the electronic parts of my guitars. It gives them a piquant, morsellated quality, with none of the unctuousness of more garrigue components."
Home Grown Tele is offline   Reply With Quote
Old August 17th, 2009, 04:21 AM   #15 (permalink)
My routine idiocy at sound checks is to plug the lead into my amp, then into my Pedal input, then output to my guitar....on a TB pedal....sound, select the pedal.....silence....PANIC!
Tw*t.
It doesn't mean a thing if it doesn't have that twing!
Tonemonkey is offline   Reply With Quote
Old August 17th, 2009, 06:04 AM   #16 (permalink)
HootieUK's Avatar
Idiot <- too
My fave is plugging in, amps on, tuner off......NADA
I lose count of the times I don't put a patch lead into one of my battery-only ('cos they sound better) ZVex pedals.
Old dog new tricks?..........no way!
Steve / Hootie
HootieUK is offline   Reply With Quote
My boy died jazzalta Bad Dog Cafe 246 April 11th, 2009 06:04 PM
You didn't know they had died Unseen Bad Dog Cafe 46 June 9th, 2008 05:23 PM
Help! My amp died. chickenpicker Amp Central Station 10 July 27th, 2006 05:29 AM
My Amp Died!!! joeman335td Amp Central Station 4 October 26th, 2004 10:32 PM
JCM 800 just died? genelovesjez Amp Central Station 10 August 27th, 2003 08:57 AM
