#41 (permalink) | |
I tried it last night into my Super Champ XD. I WAS impressed! It's kind of redundant with that amp as there are so many levels of overdrive available, but it played quite well with it. Friday I'll be putting it into my Deluxe Reverb and putting it through it's paces. I found it gave a very nice overdrive sound to it. It didn't really color the amp much when the tone knob was in the middle range. I like it. It won't replace my Fuzz or my OCD, but it will work nicely in conjunction.
John F. TDPRI # 1764 |
#42 (permalink) |
If it is like a Timmy, then try running it after higher gain pedals. It really can goose them into space.
Also, I often use my Timmy to "EQ" everything on my pedalboard. At the end of the line, kinda "Masters" the Tones. Timmy is a Swiss Army Knife of a pedal! So, if the Dano is close, you'll all probably keep it for a loooong time. And every time you decide to get rid of it, you'll find another cool use. Really thickens up a Blackface Amp too. And if you really like the To, you could always call Paul C., and order the real deal! P.S. His Amp designs for Heritage Amps, are also top notch. CHECKEMOUT! |
#43 (permalink) |
I was playing my Dano Transparent OD for an hour. I bought the Drive pedal at the same time.
I have the two Dano's and a Maxon TS9 and a BBE Green Screamers. I'm GAS free where dirt boxes are concerned. I know that it's not a Timmy. At this point I am so happy that I don't care. John
John
#44 (permalink) |
Anyone know how the somehow even cheaper Dano Fab Overdrive compares to Transparent or the normal Drive pedals?
Also, I am not too well versed in terms of chaining pedals, so let me ask this. Currently to keep the noise down at home I am mostly playing through a solid state Fender Frontman 25R. I do have a DS-1 and a Dano Daddy-O from way back, but I am looking for more of a drive sound than a distortion. Since I'm on a budget, which of these Dano drive pedals should I get, and should I bother with trying to insert these other distortion pedals into the mix, or just start fresh with the drive? Is the Transparent Overdrive more used to tweak other effects, or is that going to be awesome on its own? Thanks much. |
#45 (permalink) | |
I'm impressed that I can very easily set it so that there is virtually no difference in my sound with the pedal on or off. With my eyes shut I couldn't tell the difference. Then I could add the little bit of 'something' that I wanted to make solos a bit better. Touch of volume and a bit of gain to take my 'on-the-edge' amp just 'over' at gigs. Looking forward to gigging it next week. |
#46 (permalink) | |
Like I said in an earlier post it's not quite as transparent as I initially heard it to be. There is a slight midrange hump to it but it's very slight. It still allows for the true sound of the guitar to come through.
![]() "Science doesn't prove, it probes." Gregory Bateson |
| Danelectro Cool Cat: Drive vs. Transparent Overdrive? | riolux | The Stomp Box | 16 | July 11th, 2009 02:40 PM |
| New Dano Timmy Knock-Off - Transparent Overdrive | studio1087 | The Stomp Box | 53 | July 5th, 2009 01:49 AM |
| New Dano Cool Cat V2 Transparent O.D. Is (almost) Here | Highway_61 | The Stomp Box | 15 | May 9th, 2009 04:52 PM |
| Danelectro Cool Cat Transparent Overdrive | rotren | The Stomp Box | 17 | April 17th, 2009 10:45 PM |
| Dan Electro Cool Cat Transparent Overdrive. | ramseybella | The Stomp Box | 16 | February 25th, 2009 06:32 AM |
