Old June 22nd, 2009, 03:50 AM   #1 (permalink)
Chrismo's Avatar
Barber Tone Press - Quiet?
I'm really GASing for a good compression pedal.
I had an MXR Dyna Comp but it was noisier than hell.
I've become a huge fan of the Barber pedals - what does everyone think of the Tone Press? Is it quiet?
Well let me just quote the late-great Colonel Sanders, who said..."I'm too drunk to taste this chicken."
http://thetonechasers.wordpress.com/
Chrismo is offline   Reply With Quote
Old June 22nd, 2009, 09:43 AM   #2 (permalink)
ibodog's Avatar
Might seem quieter than your Dyna Comp when you blend the clean signal back in. Otherwise there should be about the same amount of noise from the compression side.
ibodog is offline   Reply With Quote
Old June 22nd, 2009, 09:56 AM   #3 (permalink)
woodman's Avatar
my Tone Press is a whole lot quiter than my ancient DynaComp. the difference is the Blend knob — all the way down makes it a clean boost; all the way up makes it a full-on guitar compressor (in conjunction with the Sustain knob). of course the more compression, the more noise ... i keep the volume at about unity gain (about 2 o'clock) and the Blend and Sustain knobs below 12 o'clock for just a bit of sweetening and peak control, leaving it on all the time. but if you want to use compression as an effect, you can ramp up the Blend and Sustain controls and get squashed-out compression that sustains for days — plus the noise that comes along with any extreme comp setting.
Old June 22nd, 2009, 05:52 PM   #4 (permalink)
Chrismo's Avatar
See, I really liked that blend knob. Just wanted to make sure that it was quiet enough to run! Thank you! :)
Old June 22nd, 2009, 07:26 PM   #5 (permalink)
guit30's Avatar
The Tone Press I tried was very quiet, but I never got any extreme compression out of it
Jim
Wampler Ego Compressor
Edan Analog Nashville Hot Boost
Jim's Country Reviews
www.geocities.com/guit30
guit30 is offline   Reply With Quote
Old June 22nd, 2009, 08:43 PM   #6 (permalink)
woodman's Avatar
Jim
right, i don't think they're designed for that ... not like a maxed out DynaComp, but plenty unless you want to use it as an extreme effect.
Old June 22nd, 2009, 09:29 PM   #7 (permalink)
vjf1968's Avatar
I think if you adjusted the internal trim pot, it should give that dynacomp sound.
-Mark Mothersbaugh
http://www.theabsinthedrinkers.com/index.html
Old June 22nd, 2009, 10:24 PM   #8 (permalink)
Tele-writer's Avatar
In addition to having a Tone Press set up about like Woodman does, it is fun to kick in an additional compressor to add a bit of "sing" to slide parts. Kinda gives it that Lowell George flavor...
I just love the smell of fresh strings in the mornin'
Tele-writer is offline   Reply With Quote
Old June 22nd, 2009, 10:53 PM   #9 (permalink)
Chrismo's Avatar
I like a little bit of compression, just for some added "pop" if that makes sense.
Old June 23rd, 2009, 12:45 AM   #10 (permalink)
woodman's Avatar
i'd been thinking about tinkering with the trim pot ... not for Dynacomp, but just to round off the edges a little. maybe take it up a quarter-turn and see what happens.
Old June 23rd, 2009, 03:32 AM   #11 (permalink)
guit30's Avatar
Woodman,
In your post above you talk about setting the blend and sustain hi and getting squashed out sustain that lasts for days. The trim pot is to adjust the tone of unit, not compression. I love the Wampler I have, is similar, but has a lot more squash and sustain.
Jim
Old June 23rd, 2009, 10:18 AM   #12 (permalink)
the_existential's Avatar
This pedal ended my compressor search for good, and is one of the quietest compressors you can get.
Blend seems to be the name of the game with the Tone Press. Of course the external blend control on top lets you blend back in your unaffected tone. But the internal trim pot that adjusts the "flavor" of the pedal is great for blending between the tone of a "vintage" compressor (where the high end is comprimised IMHO), and the Hi-Fi, almost Optical compressor tone that the other extreme provides. Best of both worlds.
the_existential is offline   Reply With Quote
Old June 23rd, 2009, 11:40 AM   #13 (permalink)
woodman's Avatar
agree 100% — i'd quit using compressors until i discovered this feature. as i said, i haven't fiddled with the trim pot yet, but will make that one of my projects for the week.
Old June 24th, 2009, 05:49 AM   #14 (permalink)
guit30's Avatar
The glitch of the Ross is the famed 3080 ic, in many different forms, but I have heard today, from a pedal maker that it is the easiest ic to get a compression effect. Some modern compressors are turning to the LMI ic or the optical route, Which I think, shows a lot of promise
Jim
Old July 3rd, 2009, 05:24 PM   #15 (permalink)
I got rid of my Dyna Comp within a week for the same reason. Extremely noisy! I even bought a noise suppressor to try to tame it. Both a waste of money. I am a happy owner of a Barber Tone Press. Even been the Keeley route.
tele-jack is offline   Reply With Quote
Old July 3rd, 2009, 10:58 PM   #16 (permalink)
Del Pickup's Avatar
The Tone Press is the best comp pedal I've ever come across - cos I don't really like compressors!
I tried adjusting the trim pot to get the more vintage comp tones but ended up going back to the factory setting and haven't had any desire to tinker with it since then.
I could happily leave this pedal on all the time.
Someone told me that my tone is in my underpants. I'm not sure if that's good or bad......
Del Pickup is offline   Reply With Quote
Barber Tone Press guit30 The Stomp Box 10 September 8th, 2008 08:24 PM
Barber Tone Press Fab Claxton The Stomp Box 7 February 3rd, 2007 10:39 AM
Barber Tone Press, or... ? JohnnyCrash The Stomp Box 14 November 25th, 2005 01:53 PM
Barber Tone Press kp8 The Stomp Box 9 March 18th, 2005 12:04 PM
Barber Tone Press DerektheDomino The Stomp Box 3 August 21st, 2003 04:40 PM
