Right now I'm very happy running a MI Audio Blues Pro into a DRRI; I add a little dirt with it and it compresses the tone somewhat, has a slight mid-hump that I like with the scooped mids on the DRRI and the tone control works pretty good. At the moment it's the only pedal I use when playing out (partscaster - BP - DRRI).
I did change the chip for a LM1458 btw. |
I only go with amplifier distortion, no pedals for that. I prefer onboard reverb to pedal reverb as well. Same with tremelo. So I'd have to say a delay pedal because that's one thing a real tube amp can't do on its own.
Somewhere between saturation and satiation. |
#7 (permalink) | |
I always see that answer but unless you have an amp for every application and every size venue, in my experience you can't get the best sound with one amp. If you can, I would very curious to know what amp you use. Not being a wise guy, but I have been looking for an amp that can sound good in every situation for over 40 years, with no luck. |
It would depend on the guitar and the amp... but if someone challenged me to use just ONE pedal, I'd start the experimentation with my Fulltone Fulldrive 2.
These experiments always surprise me, though, so I cold easily see the winner being my Bad Monkey.
"It looked like a giant green gum drop to me." |
+1 on the Fulldrive. Comp-cut mode on the neck pickup of a tele (or strat) is heaven!
"I've got callouses, from all those nights, spent playin' a Telecaster, 'till my fingers bled Bud Light" - Travis Tritt |
I have no idea what Jelle is talking about? I don't use a pedal of any sort but think I want to try one hence my question, but maybe I didn't pose it correctly.
I have a CRATE VC50 and VC20, the 50 don't think I need a pedal as it is pretty darn nice as a stand alone amp. I don't play out either and never will just play for enjoyment. The VC20 is a great little amp but would like to add depth to my sound with a bit of grit. The reverb on the amp works very well, so bottom line want a pedal that will add some presence and depth with a bit of bluesy grit. I wish I knew what scooped mids were but don't. Don't even know what a DRRI is either and for the chip you change that is beyond my realm also. Thanks though. |
#14 (permalink) | |
I keep a handful of amps around and match to application/venue. Ampeg Jet (J-12-A from '64, 6SL7's + 7591's + 5Y3) seems to be covering most all of my needs right now. I keep a kit-built 5F4 Super clone on hand for anything where I need much more clean headroom. Couple smaller, larger amps, some w/ reverb (none of which are particularly high $, some a good deal less than a few pedals in this thread) round out my options. And YES, I'll use a pedal or two with the 5F4 or the Jet when needed (eg Boss OD-3 or DOD OD/preamp 250)... but it's got nothing on using the right amp + right guitar for the situation. Granted, I don't have to cover a wide range of tones, so in my case it's a workable, simple solution. Not for everyone, for sure. Edit: I find that pedals are another variable that has to be well-matched to both guitar and amp to get workable results. I've tried several options mentioned in this thread with lackluster results... but other folks like what they hear. Nothing right or wrong about that. My point is, I don't think you can't just stick a pedal in between a guitar and amp and make all the other application/venue variables less relevant... it adds another variable. IMHO is all I'm saying.... |
#16 (permalink) |
I use my Hot Rod Amp for everything... of course "everything" means clubs and bars and the occasional outdoor stage. I mic the amp and we always use a board anyway,
The only pedal I use is a dunlop crybaby. |
#19 (permalink) | |
I'm not jumping on anyone but I still don't know of a practical answer to avoid pedals and I do feel that there are pedals out there that sound great, when you find the right pedal for the right amp and are a good solution to the problem. Some of the newer amps, equipped with "Power Scaling" will be the answer for some but the price for those start at about $1,500.00+ and not everyone will want to do that. |
#21 (permalink) | |
#23 (permalink) | |
#24 (permalink) |
Dig the Blues? Check out the Blues Republic! http://www.bluesrepublic.org "Life is just a tire swing" |
#25 (permalink) | |
"6. 1970's Marshall Master Volume-> in--> G1 --> volume --> G2--> G3--> EQ--> master volume---> Marshall, taking ideas from amp techs who were already modifying their amps, and from Mesa's new Boogies, decided it should manufacture a master volume amp. Guitarists wanted more distortion from their amps, and they wanted it at lower volumes. Marshall's solution was to add one extra gain stage, which gave its 1970's Master Volume amps a lot of crunch. Not the super saturated gain demanded by metal players in the late 1980's, but perfect for crunchy 70's riffing. Notice that Marshall didn't simply clone the Mesa-Boogies. They kept the EQ at the end of the preamp, not the beginning, like in Boogies. They also didn't use as many gain stages. 7. Early JCM-800's with diode clipping in--> G1--> EQ--> gain--> G2--> DIODES--> volume--> G3--> loop--> Phase Inverter--> master volume---> This complex circuit was Marshall's first attempt at mixing tube and transitor distortion in its larger amplifiers. The mix of tube gain and diode clipping produced more distortion, but some players thought the sound was too "buzzy" and "thin" and "cold" compared to Marshall's all tube designs." Mine is a 1976 model and doesn't have any solid state diodes so it probably sounds quite a bit different than the ones you had.
#26 (permalink) |
i'd go with a tubescreamer type pedal that does something 'more'. right now i'm using a sparkle drive and its cool with the clean blend variable. i used to use an ibanez ts-7 which is really a good sounding and cheap $$ wise but well built pedal..it has a regular ts808 and a 'hot' mode that gets in the territory of the old green 'sonic distortion'. another good one would be a visual sound route 66...someday i'll find a deal on one and give it a go.
#27 (permalink) | |
#29 (permalink) |
i'd go with a volume pedal, use the tube amps natural breakup for od, then you can use both the vol and tone knob on your tele for tone/od control.
...took the tube out of the v1 spot and replaced it with a dilithium crystal (like on star trek)... |
#30 (permalink) |
Desert Island, I'd bring a tuner.
If I were allowed one more, I'd do a Fulltone OCD. I am generally a one-pedal pony, and I used to use the Boss Super Overdrive...which is still a great pedal imo, but the OCD is way more versatile. It's a great tone without having to push your amp to the breakpoint, and with the amp jacked it's even better. As a straight boost pedal with no gain, it breaks up ever so slight, and really lets your amp sing. Dial in drive to taste, and mess with the peak setting. It's a fun pedal. And using it with your guitar's volume is great...it's nice and responsive to that as well. |
#31 (permalink) | |
#32 (permalink) |
Honestly if you have a tube Amp, go for the Tubescreamer.
the only reason mt Poor Man's 808 has asymmetrical clipping, is because I'm using solid state. If I had tubes I'd go full blown 808.
"Born Free to Be" |
#35 (permalink) |
one stomp
Seymour Duncan SFX-03 Twin Tube Classic. I don't have a tube amp and this pretty much fills the bill. I'm guessing a good tube amp would be the same but this is ~ $200 !
"If I had only known, I would have been a locksmith." --Albert Einstein |
#36 (permalink) |
Of course it is okay. There is no reason to be offended. I doubt that we like the same amount of salt on out steaks either. I am happy for you that you are are are satisfied with the sound you get. You may not like the sound I get either. I am only giving one person's opinion on the subject.
