#42 (permalink) |
I've palyed with a TS-9 for over 15 years and also a boss OD-1 the boss is cleaner than the I banez
but I love the mid peak of the TS-9 for blues and Country really makes the tone I like |
#47 (permalink) |
Blues? Though a tube amp with a tele, strat or LP?
The only pedal you need for blues is that little silver one that comes with Fender tube amps (the only blues amp, Brits notwithstanding), the one that turns the "Vibrato" on and off. If you made me use a pedal it would be a delay to get a little of that '50s Memphis/Chicago slapback. Max
Become who you are! -- Nietzsche |
#48 (permalink) | |
#49 (permalink) |
Depends...
If I have an amp that I can crank to get those power tubes cooking then I would consider using a booster, like RGW's Bad Bob, to push it into total tube saturation nirvana. Otherwise, I'll go with Paul Cochrane's Timmy which IMHO can emulate a very, very close approximation of the above.
"Get your facts first and then you can distort them as much as you please." - Mark Twain |
#50 (permalink) |
Hermida Zendrive.Smooth and sustaining.Peace.
Dean
www.myspace.com/deanjohnston5 Suhr Standard,Suhr Classic "T" Two-Rock Custom Reverb Signature DR.Z 2x12 Celestion G12-65,G12H Eventide Time Factor |
#53 (permalink) |
+1
I just rediscovered mine when klaus told me that he uses one quit often. so I set it free from the drawer where it spend some years just like an innocent in guantanamo, schlepped it to the proberaum and stepped on it while doing the solo on lilly's daddy's cadillac. YES!
Throw away your dirt pedals! |
#58 (permalink) |
+1 proco rat- my hot rod deluxe does blues overdrive fine on its own, but needs abit of a push sometimes.
Although, realistically, if I could only take one pedal on stage it would be a tuner (although I'll see your TU-2 and raise you one Korg pitchblack) |
#63 (permalink) |
Thanks for all the responses. I ended up getting a TS7 but it is modified from the factory to get the TS9 sound out of it. It has a tone, level and drive pots on it with a switch for TS9 and hot. I don't know why they call it a TS7 if it only has the TS9 config with the hot setting but I bought it for cheap and it does exactly what I want it to do. My VC50 is still in for repairs so I am using it through my VC20. Holy crap it does make it freakin loud I'll say that.
I have an SX tele that I rewired using the diagram for a 3 way switch in the reference section here and eliminated the cap on the vol pot and used a smaller cap on the tone pot. The pup in the bridge is a humbucking wound I guess as it is noise cancelling in the center pos so it is super quiet. Man the grit sound I get out of it with the settings on the TS at 9, 12, and 9 respectively is down right excellant. I can roll off the tone on the guitar or add tone and volume and it is the best sound I have heard that I have had come out of the guitar and amp combo. So thats it, thanks |
#64 (permalink) |
One pedal blues = Fulltone Fat Boost 1
A few pedals = TU-2, Fulltone Fat Boost 1, Fulltone FullDrive mosfet, volume pedal, keeley compressor, analog delay
'The best guitar players in the world are in Nashville, Tennessee.' -- Jeff Beck |
#68 (permalink) |
I'll give my vote for the FullDrive II MOSFET or the Xotic BB Preamp. Both are great overdrive pedals. I've seen discussions on The Gear Page that claim that different versions of the FullDrive (pre-MOSFET, different circuit boards and housing colors, etc.) sound different, but I never got into that level of research and I'm perfectly happy with my FD II MOSFET.
#71 (permalink) | |
"All the knobs all the way to the right." Frank Zappa
I feel more like I do now then I ever have before. |
#74 (permalink) |
+1 Fulltone Fulldrive 2 (pre-mosfet).
Guitars: 1997 Fender American Telecaster :: Fender '72 Telecaster Custom (reissue) Pedals: Analogman TR-2 :: Fulldrive 2 :: MXR Phase 90 (1977) :: Boss FV-500H Volume Pedal :: Analogman DD-6 |
#75 (permalink) |
This is a tough one...
Either the Durham Electronics Sex Drive or the RGW Bad Bob. Johnny Isaacs
Myspace music page I've never trusted a guitar player who hasn't licked a few 9volts... Famous last words...... after this one, no new Tele's! |
#76 (permalink) |
I use a Jacques Overtube going straight to my Garnet Lil Rock, with a EHX small stone ahead of it, and my prts-esquire-tele before that. I get pretty much all the sounds I want from this combo, for country up to blues and classic rock. I only just ordered a reverb, a van amps sole mate....
The answer, my friend, is pissin in the wind! |
#77 (permalink) |
Eden Analog Nashvilee Hot Boost or Wampler Ego Compressor(depending on my mood)
Wampler Ego Compressor Edan Analog Nashville Hot Boost Jim's Country Reviews www.geocities.com/guit30 |
#78 (permalink) | |
#80 (permalink) |
If you're looking for adding anything from a barely-cranked sound to a full-on crunch to a clean amp on a budget, I'd go with either of these BYOC kits: Overdrive 2 (Tubescreamer clone plus an additional footswitchable boost, 3-way fatness switch, and a switch to change the clipping stage) or a Shredder (Marshall Shredmaster). I use the tubescreamer model in my Line 6 M13 unit, but I drool over the idea of building BYOC's. I did build their Shredder and it's dead-on with my friend's real Shredmaster.
The Shredmaster clone may sound like a completely far-out idea for what you want, but it's not. I really think it captures the breakup sound of those early Marshall combos and is terrific in the low-gain territory. It also has a darker sound (although you can swap 1 cap to change this), but it's like instant neck-pickup blues. |
