Fulldrive 2 Mosfet vs older Fulldrive 2 vs OCD V4
I need to purchase a drive pedal for a recording project i'm doing and I want to try one of the Fulltone pedals.
It's all Tele's through a DRRI or a Bassman RI. Just need an extra gear for a few tunes. No fuzztone-type sounds. If price wasn't a factor, which pedal would you choose? A. The newest Fulldrive 2 Mosfet B. A pre-2005 old-style powder blue Fulldrive 2 C. The newest OCD V4 Hoping someone here would have experience with all 3 Or is there something else I should consider in the $150 or under price range? Thanks in advance for your opinions |
Well I have the exact set up that you just described and I use a FullDrive 2 Mofset. It is a versatile pedal and you can easily switch the Mofset function on or off. I am not sure but I think the difference between the to FD2 is the extra toggle switches replacing a pull pot(?). IIRC, of course someone will chime in if I am incorrect but I really do not think there is that much difference soundwise between the 2.
You really can not go wrong with this pedal, sounds even better with a compressor after it. You can also look into the the Award-Sessions JD10 which can be used as a pedal or as a DI right into the console or PA, its about $189.00 new but for that price the flexibility alone is worth the money. No experience with OCD v.4.
"the cult aesthetic of liking only what's obscure is just as sick of being mindlessly led around by the nose" -Mark Mothersbaugh http://www.theabsinthedrinkers.com/index.html |
+1 on the FD2 Mosfet.
The versatility of this pedal is incredible. You can switch between Mosfet and Standard operation with the mini-toggle. I prefer the Mosfet, it seems a little smoother sounding to me. The other mini-toggle will switch you between "Vintage"- supposedly like the original Full Drive, "FM" - Flat Mid mode, or "Comp Cut" which is basically a KILLER clean boost. My brother has an older FD2, and uses it with a THD Tweed Bassman clone. He loves it, and it sounds great, but he wants the newer Full Drive too. Again, no exp. with the V4.
It's not that I lack focus, it's just that I'm musically schizophrenic... |
I'm a little late posting here, I see. I have a Full Drive II MOSFET and an OCD V3. I really like them both but if I had to pick one it would be the FD II MOSFET because of its greater versatility (it also sounds superb). In my setup, I set the FD II MOSFET for rhythm crunch and milder overdrive and the OCD for heavier overdrive. When I want to really go over the top (for example, the solo in "Time" by Pink Floyd), I'll run the FD II MOSFET into the OCD--the sustain (using a Strat) is unreal with that setup.
I've used the pre 2005 Fulldrive and now the Mosfet, I've also played with an original Fulldrive. The original Fulldrive was a mids machine, and is a GREAT sound for slide guitar, or really any overdrive guitar tone.
I've always used the Fulldrive as a slide pedal, because I like the sounds of those classic blues slide players of years past. If it makes any difference to you, Bo Ramsey, who is a pretty in demand studio and touring guitarist, uses a Fulldrive, and his tone is perfect. |
Hello,
I have an OCD and use it with a Tweed Deluxe and DRRI. I like it because I can get the amp's crunch/overdrive tones at lower volumes using the OCD. It sounds "amp-like". I never was a friend of tubescreamers or similar pedals. Thes somehow don't work for me. Greetings, Klaus |
