Dan Armstrong Orange Squeezer - Anyone try it out yet? Opinions? - Telecaster Guitar Forum
Old October 23rd, 2008, 12:51 AM   #1 (permalink)
Jenix's Avatar
I know the old ones are famous but what of the new ones? I know these are relatively new. I'm going to have some money from my birthday coming up and this (or another compressor), a wah pedal, or a loop pedal are all in the running. But the purpose of this thread is the Dan Armstrong Orange Squeezer. Any word on how it is and its best uses?
http://guitars.musiciansfriend.com/p...dal?sku=150598
USA Ovation
MIA Standard Telecaster * Vox AC15CC
Martin 000C-16RGTE Aura
ISP Decimator - MXR Super Comp - Wah - Keeley TS9
86 Pro Co Rat - Volume Pedal (Boss TU-2) - Boss DD6
Some people sing in the shower, I play guitar...
Jenix is offline   Reply With Quote
Old October 23rd, 2008, 08:33 AM   #2 (permalink)
never used one, but Analogman posts this on his web site:
"There is also a "reissue" of the 1970s Dan Armstrong OS available made by by WD products. The circuit is similar to the original but suffers from a few problems like a different chip which does not sound good and the use of several other different components (cheap diode, FETs, and CAPs). The original used a 4558 chip while the reissue uses a higher tech chip which uses different pins and just does not sound right. They also suffer from poor construction and quality due to being assembled cheaply in a third world country. I talked to Dan Armstrong in England about the WD and he said they can not even be made to work right, he has nothing to do with them."
I built a clone of the Orange Squeezer on a GGG board and like it very much, it adds a nice boost and just a little bit of squeeze and grit, sounds great on a tele. You might want to consider an Analogman Juicer or a Pedal Doctor Tangerine Squeeze. Not much more than the reissue.
rpjones is offline   Reply With Quote
Old October 24th, 2008, 10:13 AM   #3 (permalink)
I use one (a clone) first in my pedal chain. I've found the OC to be the best of all the stomp comps I've used over the years. They have a fast attack and fast release with more than enough boost to send an amp into overdrive if you want to push it to do that. I don't know if I would mess with something that looked that cheap. Like rpjones said for not much more money you could get a Baja Tech Da Squeezer (I'm using) or an Analogman Juicer and have a really well made pedal.
mojoming is offline   Reply With Quote
Sponsored Links   #
Old October 27th, 2008, 12:26 AM   #4 (permalink)
guit30's Avatar
I have heard that these are junk, made by Grafton Electronics in USA
Jim
Wampler Ego Compressor
guit30 is offline   Reply With Quote
Old October 27th, 2008, 02:20 AM   #5 (permalink)
Guitar_Ninja's Avatar
I built one awhile ago, and it's about the only stompbox compressor I can stand. Be forewarned that it's a very subtle compression effect. A lot of people who have built them actually think there's something wrong with their units, since they can't seem to hear it compressing, just boosting the signal. But it's working. Both subtle and smooth.
"I just sang a song parody, Dad. Like Weird Al Yankovic."
"Son, Al Yankovic blew his brains out in the late 80s after people stopped buying his records."
Guitar_Ninja is offline   Reply With Quote
Old October 27th, 2008, 10:47 AM   #6 (permalink)
You can make it really squash your signal usually via a trimpot inside the unit. I agree you can make it be very subtle and smooth. I think it is its best feature. It's one of my favorites too and if you've never tried one and you're a compressor user you have to check one out. Make sure you adjust it to your likings before you write it off. You'll never pickup another compressor they are that good.
Old October 27th, 2008, 02:36 PM   #7 (permalink)
I just built an OSQ (Orange Squeezer clone) from General Guitar Gadgets. I was amazed and pleased when not only did it work on the first try (my first attempt at building a pedal) but it sounds fantastic -- in fact it sounds better and quieter imho than the AnalogMan Juicer which is also a Dan Armstrong clone.
sugarinthegourd is offline   Reply With Quote
Old October 28th, 2008, 11:53 PM   #8 (permalink)
guit30's Avatar
Orange Squeezers are great especially for country music, My favorite is the Hartman Compressor
Jim
PS- has a 73 Raytheon 4558 opamp instead of the jrc4558 and it uses a silicone signal diode instead of germanium, so many variations.
Here's from his site
http://www.theohartman.com/comp_faq.htm
Old October 29th, 2008, 05:29 PM   #9 (permalink)
I used the one from Analog Man. I liked the effect, but it was just too noisy for me. I e-mailed Mike for advice, but he said they are noisier than some other compressors.,
Bopcat is offline   Reply With Quote
Old October 30th, 2008, 11:39 AM   #10 (permalink)
If I can ever find it, I have one of the originals....
somewhere in my garage that I'm trying to find. I'd forgotten all about having it until this thread came up. I don't have the guitar anymore but I originally bought the OS to slap right on the front of my 335 which really put the juice to that guitar. I also used it on an old ShoBud pedal steel for awhile. I always wished they'd had the adjustments outside the box instead of having to take them apart to adjust anything.........JH in Va.
Ralph Mooney rules!!
J. Hayes is offline   Reply With Quote
Old November 3rd, 2008, 08:59 PM   #11 (permalink)
I had an original one in the 70's jeez I seem to have lent, lost or given away all of them I had the Orange Squeezer, Purple Peaker, Yellow Humper and Red Ranger.
Anyway I concur the GGG boards are fine. I build all my own pedals anyway. I might build an Orange Squeezer for old times' sake but I already have a AMZ Compressor (SSM-2165P) which is better anyway. I have an old DOD Milk Box which is a mighty fine compressor if you like to tweak settings it has 4 knobs on it.
I play old school because I am old school.
wnorcott is offline   Reply With Quote
Old November 4th, 2008, 12:51 AM   #12 (permalink)
guit30's Avatar
I have a 20 year old DOD that is the best compressor I have ever used for country music period!!!!
Jim
Old November 5th, 2008, 01:10 PM   #13 (permalink)
Big Lug's Avatar
Originally Posted by guit30 View Post
Orange Squeezers are great especially for country music, My favorite is the Hartman Compressor...
I just got one the other day. Me likes
Finally, a comp that I can work with instead of fighting with. It is subtle, immediate in attack, and can send an amp into overdrive territory if that suits your fancy.
“To be is to do” – Socrates
“To do is to be” – Jean-Paul Sartre
“Do be do be do” – Frank Sinatra
Big Lug is offline   Reply With Quote
» Random Photo for Guests
026
» Recent ThreadsGuests
Fender Logan Custom Guitars
