fundraiser
Old September 5th, 2008, 01:51 PM   #1 (permalink)
Spare or replacement Boss pedal baseplates?
Does anyone have a source for replacement or spare Boss pedal baseplates.
I'm about to assemble a new pedalboard and I'm intending to use Velcro. A couple of my pedals are the earlier Boss models and staring to show some market value so I want to avoid sticking Velcro to the bases if possible. A couple I've had in the past have lifted the information panel on the base and I want to avoid this if possible.
Any thoughts, suggestions or suppliers?
Thanks in advance.
Peter
PeterUK is offline   Reply With Quote
Old September 5th, 2008, 01:59 PM   #2 (permalink)
Thanks in advance.
Peter
Just cut the velcro to only stick to the rubber and not the pedal's label. Or use the bicycle chain link method for attaching your Boss pedals.
rondillonmusic is offline   Reply With Quote
Old September 5th, 2008, 02:07 PM   #3 (permalink)
Moderator
Tim Armstrong's Avatar
Peter, take off a base plate and take it to a sheet metal shop, betcha they can make you up a bunch of usable flat pieces cut to size, holes and all...
Cheers, Tim
http://www.moodswingers.org
Old September 5th, 2008, 07:02 PM   #4 (permalink)
ASC67's Avatar
Just go to the hardware store get a piece of sheet metal cut it to size , drill four holes and you are done.
Steve
ASC67 is offline   Reply With Quote
Old September 6th, 2008, 10:19 AM   #5 (permalink)
bowlfreshener's Avatar
I don't know if this works or not, but I have heard someone suggest taking the baseplates off, then putting them back on inside out (meaning sticker side in), then screwing them back onto the pedals that way. Another suggesttion, and this is what I do, is that I take a piece of cardboard and cut it into the shape of the sticker on the bottom, then put that over the sticker, then apply velcro. Not only does this protect the sticker, but it gives you a level surface for the velcro to adhere to, and that way you use all the velcro instead of the part thats just on the rim of the sticker indentation. Or search eBay for stuff like this:
http://cgi.ebay.com/Boss-Metal-Zone-...QQcmdZViewItem
RAMA LAMA FA FA FA
bowlfreshener is offline   Reply With Quote
Old September 7th, 2008, 01:56 PM   #6 (permalink)
All great suggestions. Thanks guys!
Cheers, Tim
Tim, this will be my final / ultimate approach. I've made some enquiries over the weekend.
I've tried this and it works OK but the velcro is stronger than the adhesive so it pulls the adhesive off if you need to move the pedal. Great idea though.
Once again, many thanks guys.
Peter
Old September 16th, 2008, 11:24 AM   #7 (permalink)
***UPDATE***
Roland can supply them! I e-mailed Roland UK last night and they replied this morning and invited me to order the parts.
The old type, for pedals like the CE2 with the ACA input, the part number is: 2202711601
For modern/current pedals, the part number is: 22027851R0.
The cost for the older type is 23-pence and the cost for the newer type is a whopping 42-pence. Plus tax of course!
They need to be ordered from Japan and the part numbers are global part numbers. The description is a "cover" and the base refers to the rubber pad. The minimum order for the UK is £3.00 so I ordered a spare one of each!
For UK enquiries get in touch with:
Nick Walsh
Customer Support
Roland (UK) Limited
Tel: 01792 702701
Fax: 01792 600521
Web: www.roland.co.uk
Nick was happy to let me post these details and if it was an item that they received regular enquiries for, they would look to stock them in the future.
Sorted!
Peter
Old October 1st, 2008, 03:06 PM   #8 (permalink)
OK, after not too long a wait, my plates have arrived from Boss. Not quite what I was expecting but something to work with.
The standard plate actually comes with the rubber base, like this:
But the notched ones are just the plate.
I'm going to check with Roland to determine if they can supply the plates only, but I'm happy for now.
Hope this has been useful for everyone else.
Peter
