Distortion Pedals: Fender Strat/Tele & DRRI
Guys, I tried the Barber Direct Drive LG Custom Shop overdrive pedal with my Fender Strat and DRRI. It just didn't get it done for me - not enough gain/crunch.
I want to cover Blues and Classic Rock, and I want to keep the costs under $150, so I chose the following 3 overdrive/distortion pedals: Barber Direct Drive Fulltone OCD MI Audio Blues Pro Do you have any experience or thoughts regarding these pedals? Thanks. Last edited by FenderGuy53; September 1st, 2008 at 12:43 PM. |
Have a listen to the various video demos of the pedals on Proguitarshop.com . I was listening to them a couple of days ago and it sounded like the the Direct Drive had plenty gain available for most blues/classic rock tones.
Someone told me that my tone is in my underpants. I'm not sure if that's good or bad...... |
First a question:
Are you looking for a "distortion" pedal that gives you breakup when your amp is turned down? OR are you looking for an "overdrive" - that will push the amp (specifically a tube amp) into natural overdrive/saturation when the amp is already cranked? They are completely different animals...fuzz being a third one. Many players try to use "overdrive" units on something like a Twin turned up to "3" and wonder why it sounds so bad. That's because a true overdrive adds very little breakup on its own - it's designed to push the AMP into breakup. A "distortion" pedal, however, is just that - something that provides a distorted signal at any volume level. The lines have become somewhat blurred over the years, but *most* overdrives are meant to be used with a cranked-up tube amp, or one running at least loud enough that it's starting to bloom and get a full, warm tube sound. Probably the best know of the true overdrives is the Klon Centaur, which will provide some distortion at low amp volume but really doesn't sound very good that way - however, in front of a cranked-up amp it really shines (and into a clean amp with the controls set flat it's a fairly transparent "clean boost"). This is one reason web-based "sound bites" can be good...but mostly bad. Unless you know what every setting is and what amp is used, you'll have NO idea how an overdrive demo'd that way will sound with *your* rig. And even if all the settings are given, amps vary - you really have to try overdrive and/or distortion units with your own equipment; it's not as critical with distortion units, but is essential with overdrives. Back to "distortion" units, though; the best one I've found is the BJF Dyna Red. I've used it with everything from a DR to a Twin, and amp volume levels from "3" or so to dimed, and it consistently gives you warm, strong, tube-like distortion sounds. It'll even pull it off with SS amps, although you lose some warmth right out of the starting blocks due to the amp. Hope that helps.
“No Chops – Great Tone” © |
#6 (permalink) | |
Can you offer any solutions under $175? Thanks. |
#8 (permalink) | |
I'm curious, FenderGuy53, what's the rest of your rig & what other OD/Dist pedals have you owned (or tried out)? That info will help folks with their recommendations... but in the end, you just need to try out a bunch of pedals with your rig, keep what you like & get rid of the rest! |
#9 (permalink) | |
My current setup is Strat > DRRI. My other amps are a Fender SCXD and a Fender BJr, which are both Master/Volume amps, so I'm accustomed to getting my grit from the amp. I like simple and I prefer a Strat > amp rig. This pedal thing is actually quite new to me. The only pedal that I've tried with the DRRI is the Barber Direct Drive LG (which is headed to San Fran in the morning). Today, I picked up a Bad Monkey for $40 at GC's Labor Day sale, but I haven't had the chance to try it. I ventured to the DRRI based on rep alone, never having played one. Had I known that the Normal and Vibrato channels were not switchable and that the footswitch has to be connected to get Vibrato, I probably would have steered clear and went in the direction of a BDRI. I still may do just that. Keep your eyes peeled for a 6-month old DRRI for sale! :-( |
#11 (permalink) | ||
Also, when I bought my used DRRI, the Fender footswitch was plugged in & laying in the back of the amp; I've never taken it out. I leave the reverb & vibrato both switched on all the time, and I just set them with the knobs on the front (I very seldom use the vibrato); I don't switch between the channels, usually just plug into the vibrato channel. The DRRI is a great amp (and loves Strats!), don't give up on it too quickly. |
#12 (permalink) | |||
I want to believe it, too. You're a good guy, Nub. Thanks for the encouragement. |
#14 (permalink) | |
I usually have my DRRI on 3-4 at home, 5-6 at a gig & most of the time I mic it. At 6, it's still clean unless I hit the guitar hard. I have an Emi RWB speaker in it, too, which helps. So, did you try the Monkey yet? |
#15 (permalink) | |||
I won't be trying the BM until later tonight. I got it late yesterday afternoon and when I got home, the wife and I went out to dinner, then picked up my mother-in-law and went to the river for an evening of Big Band music. :-) I'll send my report on the BM later tonight... In the menatime, I have an opportunity to snag a MI Audio Blues Pro for a nice price. Would the Blues Pro pick up where the BM left off and get me to higher gain, crunchy classic rock land? |
#17 (permalink) |
In my opinion, the OCD was cool, but didn't really cut through the mix. I've tried to like it...had all the different versions, and it had either too much treble or too much bass, or not enough of something. IN any case, it just didn't work for me.
The Direct Drive is a great pedal. Barber makes some cool stuff, but I think the DD is just a glorified Tube Screamer. Way too much compression. Some call it a Marshall in a box....but I disagree. I love the Blues Pro's EQ. It's flat. There's no mid bump or scoop. You can go from light breakup type overdrive to some really nice thick overdrive tones and nice crunch. It's got a fuzz switch on it...but I've never used it that way. Running it at 9v was cool, but I've been running it at 18v lately. It gives me a little more headroom. It actually cuts though the mix nicely, and it stacks well with the MI Audio Blue Boy Deluxe. It stacked well with a Crunchbox as well....but I actually prefered the Blues Pro over the Crunch Box. Again, it's the most usable in my opionion, esp at 18v. Cranking it up give you more OD, but it's not harsh. It can actually get "throaty" if that makes any sense. There's a little compression in the pedal....but not too much, making it usable for my music. Play in a worship band and do alt-country stuff on the side. Guitar is a Tele Custom into a Bassman LTD. |
#19 (permalink) |
I just saw you want distortion, and not overdrive. If that's the case, I'd look into the MI Audio Crunchbox. Lots of gain available in that little box. LOTS. When I had mine, again I ran it at 18v as well.
#20 (permalink) | ||||
I like the crunch of the Crunch Box at the lower gain levels, but it doesn't go far enough at the upper levels, IMHO. Thanks for sharing, brother. <>< |
#22 (permalink) |
First off, MI Audio pedals don't have different voltage versions. I think they've tested each pedal up to 25v. You just buy the pedal, then run it accordinly. I have Y cables for my 18v pedals that plug into 2 outputs on my PP2+.
Anyway.... The Crunchbox is more of a JCM800 type of high-gain distortion, where IMO the OCD is voiced more towards a Plexi/JTM45 sound depending on if you're running it in HP/LP mode. What I liked about the CB, and all MI Audio pedals, is the ability to cut through the mix. I never had the gain past 9 oclock when at 9v or when at 18v past 12noon. There's LOTS of gain in that pedal. It's also got an internal presence control. I REALLY loved this pedal, but for me loved the Blues Pro more. It was too much gain for what I needed, even at a higher voltage. Not that alot of gain is bad....just for my needs, it was too much. Lots of harmonic overtones with the crunchbox. I'd say it would do Classic ROck covers really well. Even with my Tele, the sound was full. Not full like a Les Paul...obviously....but the tone wasn't thin, that's for sure. You can score a Crunchbox used for between $90-$105 right now on various forums and ebay. Another pedal you might want to try out is the MI Audio Tube Zone. VERY versatile overdrive, but it does get into Mesa Recto distortion territory, and it does it well. The bass response on this pedal is incredible. Very tight bass, even with an open-back combo/cab. Not sure if it's what you'd want....but still another pedal to look at if you want versatility. Some are intimidated by all the knobs....but it just takes some time to tweak, but once you figure out the pedal...you're golden. Again...it's an OD pedal...but its circuit will get you into distortion territory. |
#23 (permalink) |
I am adoring the Durham Sex Drive at the moment, but it is more of a clean boost- not sure how it will work with a DRRI.
Keeley modded RAT is lovely also.
"A jazz musician is a juggler who uses harmonies instead of oranges." Benny Green |
#24 (permalink) | |
#25 (permalink) |
I would think so. I've never tried a BM, but everyone seems to love them. The Crunchbox is always a win, especially when you need nice thick distortion. Worse case scenario you get the Crunch Box and don't like it, you can always sell it. But, I'd try to buy used, as you can save a few bucks....as long as you can find one.
#26 (permalink) |
Wanted to also mention that the online demos of the CB don't really show what the internal presence control can do. It's on v2 of the pedal. I know some guys that dime the internal control, or roll it back a bit, so their tone is affected a little differrently with the pedal's tone knob. I use to run it with the internal trimmer turned up a bit, and the tone knob at about 10 oclock.
#27 (permalink) | |
Which OD pedal would match up best with the Crunch Box: Bad Monkey, Blues Pro or Direct Drive? I haven't tried the Bad Monkey yet, but I have 30 days to return it. Thanks. |
#28 (permalink) | ||
#29 (permalink) |
If you're going to get the CB, I'd say get the Blues Pro to stack with it. The Direct Drive MIGHT be cool with the CB, but since the DD is really compressed, much like the CB, I'm not sure how they'd work together.
#30 (permalink) | |
Robben Ford Tone then click "Video" in the menu, then click "He Don't Play Nothin' But The Blues". Now, THAT'S what I'm talkin' about... How can I get THAT sound AND cover the crunchiest Classic Rock with the fewest amount of pedals? |
#31 (permalink) | |
All I want to do is get from Blues to Classic Rock in 2 pedals or less, and under $260! |
#32 (permalink) |
The Crunchbox can begin to sound "squishy" at certain gain levels. The Direct Drive is "squishy" by nature....so IMO putting the 2 together might give you an overcompressed signal, which is why I recomend the Blues Pro. Far less compression than the DD, with a flatter EQ. Trust me....the 2 pedals together sound amazing.
#34 (permalink) | |
Also, you might check out a Rat pedal for your higher gain sounds. The Rat definitely has it's own sound, but with the gain below 1 o'clock, it crunches with the best of them. And with the gain cranked, it gets into fuzz territory... lots of classic rock tones in it. |
#35 (permalink) | |
I think an old Rat (or vintage reissue rat) can do more than just one trick...people tend to overlook them for low-to-mid crunchy sounds, but I think they're useable for that. Of course, with the gain cranked, like Nub says, they'll do distortion/borderline fuzz, too. There's quite a range in the gain and "filter" (ProCo's term for tone) sweeps. In addition to the Zendrive, the Jetter GainStage Red might be worth a look for something in the smoother Dumble-ish OD category. They seem to pop up on TGP used fairly often. |
#36 (permalink) | |
The Zendrive sounds great, but won't cover all my tone needs. Now... I checked out Jetter's web-site. Wow! The new GS3 looks and sounds awesome, not to mention its versatility, and it's not too expensive, at $289. I'll have to look further, but it looks like it will do soup to nuts. Thanks for the heads up! Last edited by FenderGuy53; September 4th, 2008 at 11:27 AM. |
#37 (permalink) | |
I don't know anything about the GS3, but a quick look at the website description confirms that it's essentially 2 pedals in 1, which could be really handy. Good luck in your search! |
#38 (permalink) |
Great stuff here, guys; it's all filed in my "steel trap" memory banks! ;-)
I'd like to kill this thread, since I've now started a new one, seeking a "one pedal" answer to cover my needs. Thanks for all the help. |
