Old August 29th, 2008, 12:32 PM   #1 (permalink)
cartier's Avatar
My Stomp Box Rig Help
Here is how I have set my rig up. I am curious if anyone has any recommendations or suggestions as to the order of the pedals, etc. I play Beatles, Stones, Springsteen, Pink Floyd, Clapton and a ton of blues. Rig is Right to Left- Guitar Cord goes into Boss-TU 2 Chromatic Tuner; Boss-CS 3 Compression/Sustainer; Boss-CE5 Chorus Ensemble; Beheringer RM600 Rotary Speaker Modeling; Boss-FDR 1, ‘65 Deluxe Reverb Amp; Boss/Roland RE 20 Space Echo; Dunlop-Cry Baby Wah-Wah GCB95, Fender Foot pedals for Hot Rod Deluxe, Fender Blues DeVille 410 & Vox Cambridge (Not shown).
[IMG][/IMG]
"...Boxing is a sport, where only the ring is square"
cartier is offline   Reply With Quote
Old August 29th, 2008, 02:53 PM   #2 (permalink)
bradpdx's Avatar
Me, I couldn't play that rig without a volume pedal after the Boss FDR-1. But that's me.
What is the problem? Are you not happy with the way it works?
String bender ordinare!
Old August 30th, 2008, 01:30 PM   #3 (permalink)
franchelB's Avatar
Are you using one or 2 amps together?
There are so many ways your rig can be set up! Personally, I'd set it up like:
Guitar>cord>tuner>compressor>"FDR1">crybaby>amp. Then in the amp's effects loop, I'd start with Rotary Speaker, into the Chorus, then stereo out, and into the Space Echo.
Unless you decide to run everything "in-line" (bypass the effects loop). Then you have the option of running 2 amps "in stereo" with the Space Echo's 2 line-outs.
Good luck, and have fun experimenting!
Feel free to visit my homepage!
http://www.myspace.com/francisbalagtas
franchelB is offline   Reply With Quote
