Old August 28th, 2008, 09:17 PM   #1 (permalink)
SMurphy28's Avatar
Can a True Bypass pedal affect my tone?
I think the answer is yes but I don't understand how... I recently took my Analogman A/B/Tuner box out of my chain and discovered it is what was taking a lot of treble out of my tone. I know, I know, just turn the treble up but even still it doesn't sound the same.
Can this happen? Is there something wrong with the pedal?
Guitars: 1997 Fender American Telecaster :: Fender '72 Telecaster Custom (reissue)
Pedals: Analog Man TR-2 :: Analog Man King of Tone :: MXR Phase 90 (1977) :: Boss FV-500H Volume Pedal :: Boss DD-7
SMurphy28 is offline   Reply With Quote
Old August 28th, 2008, 09:41 PM   #2 (permalink)
rotren's Avatar
Yes, sort of. If you have several of them and a long cables.
Read this great article for in-depth explanations -
http://www.guitarplayer.com/article/...s/may-08/35211
I am a full time guitar teacher.
rotren is offline   Reply With Quote
Old August 29th, 2008, 09:40 AM   #3 (permalink)
Rick J's Avatar
Very, very interesting article, thanks for the post rotren.
Rick J
"If you want to know what an electric guitar is supposed to sound like, just listen to this." - British DJ John Peel introducing a Roy Buchanan track on BBC radio in the late 60's.
Rick J is offline   Reply With Quote
Old August 29th, 2008, 12:33 PM   #4 (permalink)
Wampler Pedals's Avatar
it's more about impedance and loading than it is true bypass - if you use one 100' long guitar cable, you'll experience TONS of tone loss.
Wampler Pedals is offline   Reply With Quote
Old August 29th, 2008, 01:16 PM   #5 (permalink)
bradpdx's Avatar
Guitar signals are so fragile due to one primary cause: high impedance of passive systems. This property severely limits the reasonable possibilities for cable and effects loads.
I am a strong advocate for the use of well-placed, high-quality buffer amps when using any effects. Boss pedals are a reasonable substitute for a dedicated buffer under most real life conditions, but building a very high quality buffer is very easy as well. Because the buffer is not asked to deliver gain other that 1, many inexpensive op-amp based designs can easily deliver a very high-fidelity signal and a very low impedance; no esoteric parts are necessary for excellent results.
I have seen some construct a tube-based buffer using a cathode-follower, and this works well to drive non-reactive loads. However, if asked to drive a reactive load such as a long cable, cathode and source followers exhibit considerable non-linearity. I'll stick with op-amp designs for this application, as they are better sounding under a wider range of conditions.
With a good buffer, any effects pedals (other than the abysmally bad) can be driven with no loss of treble.
String bender ordinare!
Old September 8th, 2008, 11:39 AM   #6 (permalink)
First off, those boss 3 pedals will really take the soul out of your 1986 Rat. Its really obvious to me but my gal couldn't tell the difference. Just try it once, tele bridge -> your rat set to higher gain -> amp. Brings out more grit and thicker raw sound from your rat. That is how i embarked on the journey to replace all my boss pedals with true bypass pedals.
pinkspider is offline   Reply With Quote
Old September 8th, 2008, 01:25 PM   #7 (permalink)
SMurphy28's Avatar
Just out of curiosity what did you replace your Boss pedals with?
I've only tried the Rat straight into the amp before it was shipped off to ProCo for a new switch. It was cutting out on me and they offered to replace it for free! Now I'm nervous about how it will sound going through all these effects.
I could ditch the Tremolo since I don't use it all that much and the Phase 90 is already true bypass thanks to Analogman. That would technically mean only two Boss pedals - SD-1 and DD-6.
Old September 8th, 2008, 01:28 PM   #8 (permalink)
whitecat's Avatar
Another good read about this very subject:
http://petecornish.co.uk/case_against_true_bypass.html
whitecat is offline   Reply With Quote
