Old August 8th, 2008, 04:00 PM   #1 (permalink)
Barber Tone Press - country chicken pickin'?
I've spent quite a while searching this site for compressor reviews/threads, and I see that the Barber is very often recommended because of its ability to do the blend thing and yield a more subtle compression effect. What I didn't see is whether or not it's capable of the more pronounced compression that is used for the typical chicken pickin' stuff. Can it do this with the blend 'off'?
This right here is my signature.
Ignatius is offline   Reply With Quote
Old August 8th, 2008, 04:59 PM   #2 (permalink)
woodman's Avatar
sure, you can give it as much or as little comp as you like -- with the blend knob, it's easy to dial in the "sweet spot" -- even onstage. positively the most versatile comp i've ever used!
Old August 8th, 2008, 05:58 PM   #3 (permalink)
WickedGTR's Avatar
There's a trimpot inside the box that can be adjusted for more of a traditional compressor feel (more squashed)....
WickedGTR is offline   Reply With Quote
Old August 8th, 2008, 06:59 PM   #4 (permalink)
I was once a Tone Press user. Ended up selling it. Recently revisited the world of compressors with a Diamond Compressor...and what a sweet pedal. Much better than the TP, even with the TP having a blend knob. It can go from subtle compression to full on squash. Well, not as much as a DynaComp would provide....but enough for some nice chicken pickn' tones.
rondillonmusic is offline   Reply With Quote
Old August 10th, 2008, 10:18 PM   #5 (permalink)
CLAZ's Avatar
why not just use a Boss or a Dynacomp ??
C'mon
CLAZ is offline   Reply With Quote
Old August 10th, 2008, 10:32 PM   #6 (permalink)
garytelecastor's Avatar
I use a Carl Martin and a Tone Press. Either one will produce enough squash to sound like a yard bird.
Remember though that if you use it on stage and you are miked, check your tone through the mains.
I found that what I felt was appropriate for the stage with compression was WAY overboard when it was coming through the mains.
éí 'aaníígÓÓ 'áhoot'é
What in the world do I know????
Redd Volkaert is a Jedi Knight at one with the Force!!!
garytelecastor is offline   Reply With Quote
Old August 10th, 2008, 11:01 PM   #7 (permalink)
woodman's Avatar
because you can't mix the compressed and uncompressed (direct) signals. the Blend control of the TP is what sets it apart. i'm sure there are other units out now that do that, but the TP was the first one i discovered, and it found a permanent place on my board.
Old August 11th, 2008, 02:36 AM   #8 (permalink)
guit30's Avatar
I have decide to get either A barber Tone Press or A Diamond Compressor, or the new one that Brent Mason is using, made by Brian Wampler
Jim
Wampler Ego Compressor
Edan Analog Nashville Hot Boost
Jim's Country Reviews
www.geocities.com/guit30
guit30 is offline   Reply With Quote
Old August 11th, 2008, 02:50 AM   #9 (permalink)
guit30's Avatar
Got my sig customized
Just got an e-mail from a mod, I had a Bible verse removed from my sig that had been there since I joined last Dec, I didn't mean to offend anyone, but it was a short verse, nobody ever mentioned it, they said that it was a proseliteing verse. (excuse spelling) I better not say anything else or I'll be banned, love the stomp box forum, I have the same verse on my HCAG sig and no one has ever said anything
Jim
Old August 11th, 2008, 01:16 PM   #10 (permalink)
CLAZ's Avatar
double post..sorry
oops
C'mon
Old August 11th, 2008, 10:54 PM   #11 (permalink)
Del Pickup's Avatar
Just wondering whether anyone else has noticed their Tone Press sounding different if running on the battery rather than mains power?
I was fiddling about today and dug out my old Marshall compressor and was trying to decide whether to sell it or not and was A/B'ing it with the Barber so I was using batteries in both pedals. I had to play with the settings on the Barber to get it to sound the same as it did when plugged into my pedalboard mains supply.
Someone told me that my tone is in my underpants. I'm not sure if that's good or bad......
Del Pickup is offline   Reply With Quote
Old August 12th, 2008, 12:46 AM   #12 (permalink)
guit30's Avatar
How did the Marshall compare?
Jim
Old August 12th, 2008, 03:36 AM   #13 (permalink)
Tele-writer's Avatar
Nope, mine sounds the same powered either way, & I like it!
Tele-writer is offline   Reply With Quote
Old August 12th, 2008, 07:43 AM   #14 (permalink)
Del Pickup's Avatar
The Barber's a much nicer pedal with more transparency and it doesn't give the same exagerated snap at the start of each note that some settings on the Marshall do. The Marshall is also a bit noisier.
But having said that, the Marshall is a well made robust pedal that is a lot cheaper than the Tone Press and I intend to keep it as it can do some of the more extreme compression tones that the Barber can't do (which is why I like the Barber so much - it just enhances your tone and doesn't add its own sonic signature to yours).
Old August 31st, 2008, 10:53 PM   #15 (permalink)
hamhock's Avatar
Has anyone ever tried the Guyatone ST-2 Compressor/Sustainer? I read some pretty good reviews on Harmony Central...can anyone here offer any feedback?
The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs. There's also a negative side.
Hunter S. Thompson
hamhock is offline   Reply With Quote
Old August 31st, 2008, 11:46 PM   #16 (permalink)
guit30's Avatar
The Guyatone ST is excellent, I found it better, than anything in that price range, I didn't try the Marshall Compressor which I hear lots of good stuff about.Had a guyatone for a couple of years. I love the Barber ,is a great comp, but am not sure if I'm going to keep it, it compresses well, but it doesn't give a lot of sustain. probably nothing better for the money
J
