Old July 20th, 2008, 10:51 PM   #1 (permalink)
Modern OC44 alternatives?
Finished my Rangemaster treble boost clone build, a thread and photos coming soon...
In the meantime, I used a NTE126A. It's a germanium PNP that came up as a modern "replacement" on a local electronic's store inventory computer.
Not that I don't trust the guys - a NTE126 (with NO "A") even popped up on an '03 GeneralGuitarGadgets Rangemaster parts list as an alternative...
Anyway:
1. Is the NTE126A a suitable replacement until I get my NOS OC44 in the mail?
2. Are there better OC44 alternatives?
Old July 20th, 2008, 11:18 PM   #2 (permalink)
caffeinate_ed's Avatar
The NTE126A looks to have the same (or close) Hfe, voltage and current specs as the OC44, so you should be OK.
cv7003 are mil-spec equivalents and are what I use in my Rangemaster clones. I've had great success with the AC128 as well. Of course, these are also NOS items but a bit easier to find.
Ed Bradshaw
Alexandria, VA
caffeinate_ed is offline   Reply With Quote
Old July 20th, 2008, 11:20 PM   #3 (permalink)
The CV7003 is the exact same as the OC44, just in a metal canister instead of a glass/epoxy one, right?
How does the AC128 differ and does it sound any different than OC44's to your ears?
Old July 20th, 2008, 11:33 PM   #4 (permalink)
I believe the CV7003 are made to higher tolerances.
The AC128 sounds different but good in its own right. Keep in mind that germanium transistors vary a good deal. A good AC128 may sound much better than a bad OC44.
I highly recommend the Geofex article on the rangemaster. The secret to making these pedals sound good is biasing the transistor.
Ed Bradshaw
Alexandria, VA
Old July 20th, 2008, 11:49 PM   #5 (permalink)
Damn, I just realized... I built mine as a Negative Ground version... I need an entirely different transistor (NPN).
Oh well.
I'm thinking a 2N388A should do it...
Old July 21st, 2008, 01:12 AM   #6 (permalink)
Oh well.
Not necessarily, you can have a negative ground rangemaster using a PNP transistor. If you want, contact me offline and I'll walk you through it.
Ed Bradshaw
Alexandria, VA
Old July 21st, 2008, 03:13 AM   #7 (permalink)
I PM'ed you.
Any help you can offer is awesome - I'm not the shiniest tool in the shed :)
